russ
Members-
Everything posted by russ
Cross-section by russ - FINISHED - 1/48 scale
russ replied to russ's topic in - Build logs for subjects built 1751 - 1800
Sinan: Thank you for those very kind words. However, I think that there are several of the Triton cross sections that are far better executed. We have some really good builders around here. Russ- 69 replies
- frigate
- cross-section
The shop looks good. I find it is a good thing to tidy up a bit every now and again. It helps me focus. Have a great day. Russ
- 2,215 replies
There is usually a natural tendency for strakes to be wider at midship, then narrow slightly, especially in the underbody, as they pass along the 2/3 mark of the hull, and then widen out a bit at the stern. This will happen mostly in the lower belt, but it can happen anywhere below the turn of the bilge. Is this what you are seeing? Russ
Nice paint job. The red lead underbody is very good. Russ
- 45 replies
Mario: Nicely done. This is coming together very well. Russ
- 45 replies
Pete: There is no need to dilute. The treenail should be an easy fit, with just a hair's bit of play. The glue coating on the treenail will take some space in the hole as it dries. I usually ream out the treenail hole ever so slightly to make the treenail a slide fit so that the wood glue coating will make it fit perfect. I wipe off the excess glue that squeezes out afterwards. Your framing is coming along nicely. Russ
Guy: That is included in the keel. The keel and rising wood are NOT separate pieces in the Triton build. We designed the keel to be done with the keel and rising wood all together for ease of building. Remember, the framing and structural details for the Triton build are simplified from what you would see on the actual ship. It is still POF, but not the actual POF like the Echo or Swan class builds. Russ
Deck planking looks very good. I would not paint it, but this is an individual choice. Do what makes you happy. Russ
- 135 replies
- willie l bennett
- model shipways
Everything you need should be in the drawings that were created for this build. Russ
There is no online link for those tables. I would strongly suggest you get a copy of the Ship Modeler's Shop Notes. It is available from used bookstores through sites such as ABE.com and bookfinder.com. You can also check to see if your local library can get it for you on loan from another library. I would think you can buy a new copy from the Nautical Research Guild as well. I think that most gunport sills would be parallel to the keel and that the sides of the ports are penpendicular to the keel. However, that is what I can see from looking at plans of British and American frigates and ships of the line. Without knowing what vessel, nation, time period etc you are building, it is difficult to try and help. Russ
From your list, cherry and beech would be good choices. Maple can also work very well, provided it does not have a lot of figure or spalting. If it has a clear grain and texture it will be fine. I prefer cherry. It can go from a light tan to a dark, reddish brown. The lighter color is the sapwood and the darker stuff is heart wood. I prefer the heart wood. Cherry can have some wavy grain areas and knots, but these should be avoided as much as possible. Hope that helps. Russ
John: There were a lot of differences between French and British guns and ships. It is apples and oranges. Even when the British "copied" French designs, they would fit them to what the British Navy wanted and used. They used British guns, different gunport spacing, British carriages, etc. As for French designs, they rarely used a French design without altering it, even if only subtly, to get a ship that they wanted from that process. Russ
Very nice work. The standing rigging looks excellent. You have done a good job of making everything look taut and nothing pulled out of line. Russ
