Posts posted by Angarfather
- Sjors, mikegerber, qwerty2008 and 8 others
- 11
Thanks, Patrick!
There are to projects. First will be the Statenjacht Utrecht. I have got two wonderfull books over this ship and scratch building the modell from SeawatchBooks.
Furthermore, I do research on plans for a galleon from the time of Queen Elisabeth1.
Cheers Hartmut
- IgorSky, Omega1234, Doreltomin and 1 other
- 4
- firdajan, qwerty2008, Sjors and 7 others
- 10
Hi Nils,
I think that your way of rigging will be an exampel for masterwork at my next projekt!
Hartmut
- Mirabell61 and Martin W
- 2
- tarbrush, Dimitris71, kees de mol and 12 others
- 15
Thanks to Nils, Sjors and all "likes"
Best regards. Hartmut
- qwerty2008, mtaylor, aykutansin and 3 others
- 6
Hello Sjors!
Good workmanship you show there!
I think that you are right. It's a long way to masting and rigging the Aga. But I will get up my chair and wait for the next pics.
Best regards Hartmut
- Sjors, popeye the sailor and GLakie
- 3
- Landlubber Mike, mikegerber, Sjors and 5 others
- 8
Congrats on finishing the two Mayflowers. Marvelous work!
And good luck to you for building the Soverein ! What a ship, and what a lot of work!
Regards Hartmut
Hello Sjors! She comes very good,I must say.I have try to remove the chimney but I think I will be having more damage .
So I'll keep it this way.
When someone ask me about it, I can always say that it is standing on a spindle.......
You can turn it any time you want !
How about that solution ?
Sjors
About the chimney: as I know the chimney can be turned. That.'s fx to be seen on HMS Victory. So it will be ok to show it in the position you choose on your Aga.
Regards Hartmut
Hello Dave!
What a nice group of ships!
best regards Hartmut
- SawdustDave and GLakie
- 2
The boomtackles of the mizzen boom.
The anchorshanks and arms are made from 3mm PVC foam
The anchorstocks are from wallnut and the hoops from 1,7mm soldering wire
The served anchorrings
The blocks of the latinyard hallyards: seven sheave blocks at main and fore mast, trebleblocks at the mizzen
Pincos crew are only six hands and the skipper. Therefore they used such big tackles to work with the latin yards.
Regards Hartmut
Well, Cristiano,
I am thinking about the next project. There are two favourites: a statenjacht or a xebec. I am searching for a good plan of xebec.
Regards Hartmut
Altough Gianna is a smal ship 110 blocks are needed.
I made the violin blocks konventionel from one piece of wood.
The others are glued up from layers of 1mm walnut stripes.
One of the ready single blockstripes
The result is a smal frame from walnut.
The slices for the smal blocks are made from 3mm soldering wire.
The slices for the other blocks are made from 4mm brass.
Milling the groove for the blockstrops
The results after some times of sanding
Regards Hartmut
Hello Dave,
thanks for showing your way of makeing the pins. Very good! Next week I have to make 30 pieces. I will try it in your way.
Best regards
Hartmut
- SawdustDave, NenadM and GLakie
- 3
Pinco Genovese by Angarfather - FINISHED
in - Build logs for subjects built 1501 - 1750
Thanks to all!
Some pics from the dinghy.
Cheers Hartmut
