Everything posted by KeithAug
A wheely good start on that paddle Eric. It does seem like quite a tedious job.
- 393 replies
Nils - Nice work - what is the resin you are using?
- 299 replies
- lightship
- Feuerschiff Elbe 1
Steve, Glen, Tom - thank you for your feedback. More plankers progress:- Not a lot to tell this time. In the majority this update is pictorial. Finishing off the last update - here is the clamping arrangement for glueing on the stern piece. Aren't those elastic bands a great invention. The stern piece makes terminating the planks much easier as they just tuck up under it. And so planking continued. With morę planks installed it is clearer how the stern piece aids the neat termination of the planks. And so ever onwards:- Being now quite close to the keel I started checking the side to side symmetry of the plank runs with a set of callipers. The maximum error across the entire length of the hull was a maximum of 1/3 of a plank which was quite pleasing. This I adjusted out over the next 2 plank runs by inserting slightly narrower planks on one side. The callipers are defying gravity in the next photo. Onward again. I was now getting close to the area of the prop shaft so I had to start thinking about filling in that area. I did some shaping of a thicker plank by machining a curve where the plank meets the prop shaft. I glued this in place and accepted that some heavy duty sanding would be needed in this area to smooth the external surfaces of the planks. That's all folk's. Thankfully the end of the plankers progress is in sight.
Good looking logs Ras. The winch sides look just the job - that was a bit of luck. The winch looks great.
- 128 replies
- zulu
- sternwheeler
Sorry but it now looks better than the original. Needs a bit more bodging!🙂
- 174 replies
- Vigilance
- Sailing Trawler
Nicely done Nils. You didn't say much about your carving method and I would be interested. For instance did you use templates or just freehand it?
- 299 replies
- lightship
Eberhard - Very nicely done. Are all the bases port bottle corks? If so how much port did you have to drink to create the crew?
Ah! it is a wobbler engine. If you ever want to try something a little more efficient - double acting, self starting and reversible you can always try this on your next model. https://www.machinistblog.com/downloads/paddleduck/04_building_a_model_steam_engine_from_scratch_chapter_4_567_418.pdf I built one and it works a treat. Nice work on Miranda. You should do a build log on the boiler and engine build. You seem to be living on a boat?
