amateur
Everything posted by amateur
  1. Yeah, you're a snob, but we don't mind As a 13 year aged kid I did a couple of small-scale solid hull models. I wasn't too impressed by the result, mainly because it proved quite hard to get the hull in good shape (the kitmaker in his wisdom made the hull slightly over-size, but did not provide a full set of lines to use as a template). And unless you set youself the goal to show the ship as it was actually build, no-one will ever bother whether there are bulkeads or a solid block of wood behind the planking. Jan
  2. Hi Piet, It's a fantastic model. The railing adds to the realistic appearance, especially whuile you took no shortcuts in the top ends of the stanchions. You disappointed us (well, some of us, and only a little) by just simulating turnbuckles. Jan
  3. Real beauty is on the outside Jan
  4. Again two questions: Q. Are the carvings carved from wood, or made of something else Q2 is it all gold that is shining? Jan
  5. I was awate of some people trying to calculate the load using basic integral calculus, but i wasn't aware of the use of matehematics in hull design. Could you tell me where you found info on how they did it? I know the books by witsen and van ijk, but they do not give any design-rules, apart from rules of thumb, and "it should be done this way, as we always did it this way...." Jan
  6. Is it thrad you usedfor the rigging, or is it copper wire? Jan
  7. It puts things in perspective. There aren't that many small modells around here. Showing how you did it will be appreciated. At least by me Jan
  8. I am still wondering: the title of the post states scale 1:96. But is 28 meters not very small for a 70 gun ship. I guess it is not 1:96, but 1:192.... Jan
  9. As Chris states: 'length' has various meanings. There are a couple of options: 1. length overal (i.e. including bowsprit etc) 2. length between the perpendiculars (which is what you indicated in your sketch) 3. length over deck, which is more or less the length of the deck (between the sterns) 4. length over the waterline, which is the the distance between the points were the sterns 'hit the water' 5. keel length. Sometimes only the lenght of the keel is mentioned, which is consierably shorter that the other lengths. One of these lengths corresponds with your stated length. As Lady Nelson is a hypothetical ship, modelled to a more or less standard design, there is no reason to be 'off scale'. I suspect that the 16 meter refers to something else than the length between the perpendiculars. Jan
  10. There is another site: bestscalemodels. Is that a valid one, or is it also a site to avoid? Jan
  11. I thought youdid only model the resin part. The railing will not be resin, i think. Jan
  12. Hi David, I think your post landed in the wrong log.. There is no kit to be seen here for miles around. Hi PIet, I was already wondering where those fish-mouth ends would come in. Now I understand.... You don't leave any detailed unmodelled Jan
  13. The woodshown is what italians call walnut. I have the same stuf in my prinswillem kit. The strange thing isthat in proper strips, the wood called walnut has amuch,much closer grain, and is qlso slightly differently colloured. What the italian kitmakers call beach definitely has a punkish glos (especially the heat treted, flexible versionof it. ) Jan
  14. That's strange.pretty sure that beefwellington had the correct answer yesterday....... Where has he gone? I can repeat his answer, but that's just plain piracy Jan
  15. We had a thread on this firm at "MSW1" in which some said that this firm (and some other firm, using almost the same name which I now forgot) was selling plans of which they did not have the copyrights, had a somewhat sloppy service, and was to be avoided.... They have a phone-numer on their site, you could give it a try.... Jan
  16. Can you use decals on cloth? I've also seen thin metal foil as a base for flags. The miniature-scale guys use it: no problems with any fabric structure that is too coarse. Jan
  17. Chatham, Portsmouth? HMS something.... Jan
  18. It's fun, those little ropes. Although quite time-consuming. I'm not going very fast, as I try to be a little bit more historically accurate than the Corel-drawings. i.e more variety in block-size, rope-thickness, and a slightly more 'dutch' rigging practice. Therfore, progress is slow, and as I have large interuptions in my work, startup-time is long, the next time I start (first problem is always: how did I do that last month....) Jan
  19. My summer didn't go completely unspent... (sorry for the quality of the pics, they were taken wth a not so goog cmera...) All running riggin gof the bowsprit is more or less present. I 'only'' have ot belay the loose ends. One of the problesm at this scale is taht the rope is quite springy, and the yards not heavy enough to prevent teh rope going everywhere. I also redid the crowsfeet at the foremast, the rather whitish rope started to anoy me. Actually, I still think the crowsfeet should go altogether. It does look a bit out of place and period for this ship.... Jan
  20. Naja, bockwurst oder currywurst, ist mir ganz egal...... Jan
