Everything posted by amateur
Yes and no: I had my ratlines at -on average - 4 mm apart (at 1:100) scale. I changed it to 3.5 mm (again, on average), just because it looked better. Your eye picks up tenth's of milimeters, especially in the case of ratlines, as larger spacing results in fewer ratlines. So the question between 11" and 15" is not just an academic question. Jan
Oh wait, of course not: you have to add all the gunport tackles before going to the next level Jan
I see. Sounds reasonable. What's you planning? More destruction on the lower deck, or fixing the beams, and start working at a higher level? (btw, the diners: will they get some colour?) Jan
Congratulations,( again ) Do you have pics of Montanes? Jan
- 50 replies
- cannon
- le fleuron
You're getting predictable btw is that an ill fitting seam, on the quarter gallery? Jan
Did you already made the little clamps to prevent the woolings to slide down the bowspeit? Jan
Most of the lines for the spritsail were guided towards the more reacheable parts of the ship. Most of the times there was a line fromthe top to the forestay, as a kind of railing. Btw furling the mainsail high above the deckwasn't funeither, I guess... Jan
No, he does not laminat ethe frames. He glues two pieces of wood together to fabricate a double frame. Jan
Sorry, I meant that he uses not one single piece of wood for the larger frames, but three smaller strips, so that the direction of the grain is parallel to the futtocks. Jan
second thought: is that perhaps the reason that Reed uses compound blanks for hislarger frames? (he claims that it is for minimizing on the amount of wood needed, but.....) Jan
McNarry is stacking thin slices of boxwood to each other to a sloid hull. Next he carves the hull from the block. Soon as the hull is 'perfect' the slices are taken apart, there inside is removed, and parts of it are removed in total, to get the timbers/futtocks-effect. The same method (with a small twist) is used by Reed. He remarkes that it depends on the quality of your wood to get crisp results. Boxwood is the way to go he writes..... Jan
Loking good! However, looking at the rendered version, i wonder whether the bands along the hull are correct. As far as i know the pictures, these are just rubbing strakes, or simple doublings of the hull. Going by the shadows visible in your modelthey are to large. Jan
Again a question: you used thread for the rigging. Did you glue the ratlines,, sewed them, or did you use proper knots? Jan
Somehow it looks very familiar. She's not a random trawler in disrepair. It looks a bit navy but with a civilian remake... Jan
Always messing that up with the r's in red and green.... knowing which side is which doesn't help you with the colours... Jan
Ah, that one again. This thing is around for some time..... Jan
I'm not quite sure what you mean: when you build at twice the size, everything should be multiplied by two. Or did I not quite get your question?? Jan
