Everything posted by amateur
I find the book of Hoving (on the ships of Abel Tasman) a great help. It is for a slightly smaller ship, but as almost everything in Dutch shipbuilding is supposed to be scalable, it is a very good startingpoint. Problem is that I should have started using that book earlier in the proces: Not all belayingpoints are were they should be. All
- 139 replies
- corel
- prins willem
Hi Piet, Too much letters without meaning. English has some, but should we remind you of the common pronunciation of the Dutch place of Gorinchem? I like the ding(h)y. You could try to deceive rear admiral Sjors, and just post a second pic of v1.0, claiming it is V2.0. He wouldn't notice I guess. (too busy eating popcorn and marsepein and chocoladeletters) Jan
It has been a long time. Lots of other things to do, but now the fore-yard is ready for hoisting. As soon as it is in place, I will try to install the parrels. It's fiddly work, as almost all blocks are slightly oversized, it will be quite crowded down at the mast... Besides, I do not have a straightforward rigging plan: I skipped the Corel version long ago, and are somewhat stumbling about, using various sources. That doesn't add to the speed Jan
- 139 replies
- corel
- prins willem
Hi Kees, Didn't see that one coming. I thought you were up to a good oldfashioned solid hull... Jan
- 205 replies
- kw49 antje
- trawler
What is the white stuff between the mdf-layers? Second question are you going to simulate hull-plating? I like your choice of model. Not many models of these ships around. Jan
- 205 replies
- kw49 antje
- trawler
I would be very happy if my version 3.0 turned out like this. Can't wait seeing your version 3.0 Jan
hmmm...given the type of men aboard I wonder whether that would be a wise thing to put on your cupboard ... But then, the alternative might shock the mods Jan
6 cm, that s really small to do it as a real pof-model I would have gonefor the plug-method, or even total fake Btw it's great to hear your major medical problem has gone! Jan
LOL I guess there should be antoher one on the sheet: "to be used only under close adult supervision" Jan
You;re right, compared to the tictac, the stove is exceptionally large. I'm still wondering: if this thing is a furnace, that means (almost open) fire. Therefore, you expect it to be secured to the deck. However, securing it, implies that it is no longer mobile.... Although, you could use the three fire-man to get the thing to the next deck Jan
Don't blame us for not noticing, you've "only" showed pics of ugly bacteriae since then Jan
Hi Daniel, In your last pic, there is something on the right side (slightly out of focus). It escaped my attention till now. It looks like a small furnace. What is it? Jan
Batavia by *Hans* - FINISHED
amateur replied to *Hans*'s topic in - Build logs for subjects built 1501 - 1750
Sure she will turn out as beautiful as this one! Jan -
I think it differed quite a lot. Many ships were not build with a crows-nest, and were fitted out with one during WWI, to spot for U-boats. I guess all versions were used. I also saw pictures of a metal crowsnest with a hath in the bottom (and a ladder fixed to the foremast) -ofcourse: google will not reprocduce my search-results... Jan
glowing after oil
amateur replied to michael101's topic in Painting, finishing and weathering products and techniques
Hi Michael, No you can't glue anything onto line-seed oil.You have to remove the oil wehre you want to glue. It depends a little bit on the type of wood you have. Linseed oil does not always pentrate deep into the wood. In that case first scraping off the oil, second giving it a sanding with sandpaper, and third step rubbing the spot with metyl alcohol should remove enough of the oil to make it possible to glue the decorations. Jan -
In Dutch shipbuilding, the answer usually tends towards: 'we always did it this way'. Alternatively: 'we know the other alternative is better, but this is cheaper.' btw. I don't know whether or not the dinghy was wooden build. It could have been steel. Jan
IJN Fuso (Halinski) Card Model Review by Captain Slog
amateur replied to Captain Slog's topic in Card and Paper Models
In that case, we will look forward to your tictacs Jan -
On msw1 we also had a guy called martanek (also czech, i think) he did these large card models of battleships. Absolutely stunningdetail. He is still somewhere around in the internet, but unfortunatedly, not amongst us.... Jan -
What was wrong with the staining? In the pics it looks OK... Jan
- 28 replies
It took me a few moments to realize that your new signature-picture is not the original..... Jan
No you can't give likes to yourslef, you need us to do so. Jan -
next will presumably be destruction, of some part hitherto unknown Give him a decade or so, and his lower deck will be better than the original. Jan
The rigging of the stay with two deadeyes is like the Dutch way of rigging a (secondary) stay on smaller ships. (pic of the reconstructed statenjacht Utrecht)
- 1,051 replies
- cheerful
- Syren Ship Model Company
