Everything posted by kurtvd19
Actually the hose if of adequate length does a good job of removing pulsation as a problem. The test is - take the hose off the compressor and if it doesn't have a tank there will be some pulsation evident. Reattach the hose and w/o an airbrush check the air flow from the hose. The pulsation should not be evident. This works better the longer the hose, but the 6 or 10 ft braided hoses work fine (not at all sure using the thin plastic hoses). If there is pulsation evident from the end of the hose then adding a tank can help. In all my years of airbrushing using a decent air regulator off the compressor like the photo below with a 8 ft hose I have never had a pulsation issue regardless of the airbrush being used. The regulator acts as an in-line pressure control valve and I would never attempt to use any compressor for airbrushing w/o a pressure regulator. Don't use a regulator in-line closer to the brush but some do but my set up is compact and easy to adjust at the compressor. I now use a TC910 - below that has a tank but I got it more for the slightly extra capacity than for a tank. If you have a pulsation issue putting a storage tank in-line would solve any pulsation issue. Kurt
Don't worry about the names for the photos - one needs the model name and the view - per the list of required photos. Make sure you have renamed the photos to match one of the naming descriptions Eric mentions above - from what your files list it as - a bunch of numbers that might include your name. I am forwarding Eric's post to our web master to check out and fix.
Badger Airbrush Co. is making a special offer for a limited time. This offer will be repeated again - watch their Facebook posts - in case I don't get them posted. Read the info in the box below - note the dates and the requirement that orders from outside the US will need to respond to the email that will be sent upon receipt of the order - limited time to respond. Badger is making this offer because they have not and will not be attending any shows during 2021. The prices shown are what the products would sell for at the shown - prices include shipping & taxes (except foreign supplemental mailing charge). Note the compressor prices - many here have been shopping for a compressor. I have the TC910 unit and it is quiet and will handle any airbrush. Also have the TC908 and it's pretty darn quiet too. http://www.badgerairbrush.com/Special_Offers.asp http://www.badgerairbrush.com/images/NonCon20202021header.jpg
There doesn't appear to be much of frame 11 there now. I would plan to reinforce both forward and aft edges of the joint of frame 10 to the hull planks with epoxy - fill in the gaps. As this is obviously a r/c boat and the outside planking has or will be fiberglassed I would think about a layer of fiberglass on the inside of the hull between frames 10 and 12. If the interior of the hull has already been covered with epoxy or resin the joints of frames 10 & 12 might already be strengthened with the application of resin or epoxy making the joints stronger than they appear. And even the addition of fiberglass might be overkill. Either way take the frame down as low as you need.
Pin Vice Help Needed
kurtvd19 replied to Ed Gibbons's topic in Modeling tools and Workshop Equipment
Ed: Not discounting the Starrett idea, but the kit tool is not a bad tool. Match the proper holder to the drill bit and it should tighten down just fine. I got that tool when I built and reviewed the Yankee Hero kit when it came out. I still use it. I think I had commented on the quality of it when I reviewed the kit. Most "everything included" kits have junk tools. Bluejacket is a quality company - they don't provide junk. If it doesn't tighten at all call Bluejacket - you might have a defective tool. -
NRG Capstan Project
kurtvd19 replied to tlevine's topic in - Build logs for subjects built 1751 - 1800
Absolutely. -
The model exhibit at the Science & Industry Museum was completely reworked just about 2 years ago. Models cleaned and repaired, some new and models put into dioramas. Big improvement. Kurt
Oxy/Butane Micro Torch Kit
kurtvd19 replied to Boccherini's topic in Modeling tools and Workshop Equipment
The cylinders shown are small but one doesn't need a gas leak of any size. My little torch is set up on much larger tanks. Tanks should always be turned off when finished. -
Go with the tried and true Smith Little Torch. Quality w/o questions of reliability. -
I was going to mention the lab in Madison but Alan's from Canada so there is probably some requirement for being a US citizen. I spent some time at the lab before I retired and it is impressive. I witnessed a test of a 4 x 4 or 6 x 6 wood piece about 10 ft long to see how much weight/force it could withstand. They do this so the charts in building code and architectural books can be developed so the minimum sizes of wood components can be determined. We were behind plexiglas several inches thick and when the post failed it was very impressive - loud and toothpicks everywhere! Something they had there that is a relevant topic for this forum was a replica of the hull of the USS Constitution. It was about 6 ft long and about 4 ft high and had appropriately sized frames and planks assembled with treenails. It was made by the shipwrights in Boston before the 1996 refit so various electronic means of testing for structural integrity could be tested while in the water to determine what planks or frames might have to be replaced. This is commonly done with metal ships and they did it to see if a similar process would work with wood. The same woods as on the 1:1 ship were used.
Model shop bandsaw choice?
kurtvd19 replied to tooter's topic in Modeling tools and Workshop Equipment
Tooter: Do a search here for 9 inch band saws and/or band saws and you will find this is a much discussed subject with recommendations. -
Steamboats and other rivercraft - general discussion
kurtvd19 replied to Cathead's topic in Nautical/Naval History
Randy: Have you tried to find anything at the Mercantile Library at the Univ of MO - St. Louis? They have many records that might help. If you are ever nearby this is a great place to visit. I was given a tour behind the scenes just before they opened the new state off art building - very impressive. At the time they had the absolute state of art fire protection especially for their rare documents. But the library was originally started by the merchants of St Louis for business records so many shiping related records were saved for posterity. https://www.umsl.edu/mercantile/- 281 replies
- Steamboats
- riverboats
(and 3 more)
Were you disappointed with the poor quality of the cast parts or are they what you expected?
I second the idea of using a Dumas type motor but with a 2:1 drive - not direct to the shaft. A tug needs more low end power than RPMs and 2:1 with a Dumas type motor works great fro a tug such as you show. CAUTION - Do not under any circumstances use a Dumas geared drive for this - pure garbage and the noise is very loud - a belt drive is great.
Use Brass wire. It can be annealed to bend the chain plates and other parts. It comes in many sizes and can be found in hobby shops, craft stores and on-line. It is easily soldered.
This has been discussed numerous times. Please do a search of topics and read the prior posts - your question has been answered many times. If you need further information about a glue ask the question in the that topic and you will get the needed information.
NRG VIRTUAL WORKSHOP - INVITATION
kurtvd19 replied to kurtvd19's topic in NAUTICAL RESEARCH GUILD - News & Information
Yes it will be. I already have the post it note with "START THE RECORDING" ready to stick in the middle of my screen so I can't miss it.
