Roger Pellett
Everything posted by Roger Pellett
  1. It certainly worked for this guy. The alloy that he used is readily available from gunsmith supply houses such as Brownell’s and I believe that the material is reusable.
  2. Amazing project!! If my mental metric conversion math is correct, the real thing would have had a bore of 32in. That’s twice the bore of the main armament of an Iowa Class Battleship. Am I correct? Was this actually built and used? Railroad guns are fascinating. The museum at the Washington Navy Yard used to have one of the ones built for service in France during World War I. It was built around a Battleship gun- 16 or 14in. If a kit for one of the WW I guns was available I would be tempted. Roger
  3. At least 10 years ago there was an article in the Nautical Research Journal about the construction of a model of the gunboat USS Bennington. I believe that there was a connection to the San Diego Maritime Museum. The author formed cowl ventilators by electroplating a metal plug that he had cast. The plug was cast from a metal used by gunsmiths to cast impressions of gun cylinders. This metal (maybe called Cerro?) has a melting point close to the boiling point of water. After electroplating, the plug was immersed in boiling water leaving only the electroplated shell. Roger
  4. I agree, John. That’s a lot of money for metal, especially as I believe that this is a relatively new kit. A better choice for the gun barrels today would be cast resin. BTW, if you PM me your deadeye bill of material I might be able to help you out. Roger
  5. I hesitate to give advice to an accomplished modeler, but here’s my setup for painting figures. The Duco cement is the old model airplane cement, Maybe Ambroid in the UK? It easily separates with a single edged razor blade, although my figures are metal. The little hand vice is handy for positioning the figure for hard to get to areas. Your guy looks great. Nice work. Roger
  6. Very nice, OC. The two models, both nicely done really compliment each other. The figures and equipment are lifelike. Roger
  7. I’d save the $50, approx towards eventual purchase of a Byrnes saw. Roger
  8. The best reference that I know of is an NRJ article by Eric Ronnberg about historic paint colors. An edited version is included in the NRG published Shop Notes (I think Volume II) and was at one time included on the NRG website. You can also occasionally find references in old specifications. For example, an 18th Century longboat specification required the interior to be painted “drab.” Looking up drab color on the Internet I found it to be a mixture of burnt umber and white lead that I mixed from acrylic artists colors. Roger
  9. At one time, Bluejacket, I think, produced a true plank on frame kit for the Schooner Yacht America, and one of the 1850 era US Revenue Cutters. I don’t know if either of these are still available. Roger
  10. Rather than using wall paint, custom colors can be mixed from tubes of acrylic artist’s colors. I have had good luck mixing these pigments with artist’s matt medium. For use in my airbrush they are thinned with water. I do not pretend to understand the intricacies of using a color wheel. Instead, I mix them by eye. For old colors like “drab” and “straw” formulae can be found on the Internet. Roger
  11. Brass tubing is the modelmakers friend. Short pieces can be used to line drilled holes to produce a clean sharp edge where required. It can also be used to make a miniature hole saw for cutting sharp edged holes in wood. Roger
  12. I’m not familiar with the vessel, but if it is one of the World War II era tugs it would have had a steel plated hull. If that’s the case, I would fill in the areas between the bulkheads with wood blocks- basswood or pine and then shape the hull. I would then plate it like the real thing. Roger
  13. A trick that can work rather well is to paint raised stripes like cross belts first and to then paint the uniform base coat up to it. This would work especially well in your case as these details appear to be molded in heavy relief. Roger
  14. Wonderful work, OC!! Can this somehow be combined with your Mosquito. Roger
  15. Over here “across the pond” Mystic Seaport Museum hosted a large exhibition of Turner’s work in it’s new art gallery. It was the only American institution selected for this exhibition. My wife and I stopped to see it on our way to the NRG Conference. Temerarie not included but lots of other works demonstrating Turner’s amazing abilities. Roger
  16. By the time that your grand daughter is a young adult and able to fully appreciate this beautiful model, who knows what technology will be available to let her see below decks. A very inexpensive endoscope? Roger
  17. Jerry, Here is a picture of some Civil War era US Navy figures that I painted. Material is lead alloy. Size is 52mm, a standard military miniature modeling scale, which would be close to your 1:36. I believe that they were sculpted and cast by a company named Kramer Miniatures. Although these date from the 1980’s, some recently show up on EBay. I recently bought one with the all blue uniform. The second picture is a plan set for the 12 pounder light boat howitzer that was used in launches of Sloops of War. I bought mine from Dixie Gun Works but suppliers of Civil War reinactment gear also sell them. At one time they published a plan set for the 12 pounder heavy boat howitzer but it seems to be out of print and I have not found a used copy. BTW, what is the overall length of Constellation’s launch? I have been trying to read it from the National Archive drawing but can’t make it out. Roger
  18. Why not a new category for ship model restorations?
  19. Toni, In Volume 44, page 220 of the Nautical Research Journal published in 1999 you will find an article by N. Roger Cole, Clinker Planking over a Fully Framed Hull. In it he describes clinker planking a model of a cutter similar to the one that you are building. About the same time he also published another article about copper sheathing a clinker hull Roger
  20. Whether the scenario you show with the enlisted mechanic on the step ladder and the guy with the “hat” on the wing actually would have happened, the scene looks lifelike and realistic as far as I am concerned. NICE WORK! Roger
  21. In normal times, I like to browse in hardware stores and often end up buying stuff that strikes me as being useful to my model building activities. Sometimes it can be used to advantage for purposes known only to me. There is a Menards big box store near out local Target Store. I can often spend an enjoyable hour at Menards while my wife is at the Target analyizing the toilet paper selection. Unfortunately, Ace Hardware’s business strategy seems to be “extreme helpfulness.” They pounce on you as soon as you enter to select the product that in their opinion works best for the problem that you are trying to solve. This hovering prevents browsing. For this reason I seldom go there. With the virus, am following my Doctor’s advice to wear a mask, and spend as little time as possible in the confined public space of a store. This makes the local Ace Hardware store more attractive. I tell them what I want and they go get it. Roger
