Posts posted by baskerbosse
Looks interesting.
By the look of the first parts anyway, looks like better accuracy than Corel.
The bow section is looking promising.
/Peter -
Looking great!
Amazing as usual. -Just make sure you don't leave rigging the deadeyes until too late.
Can be quite tricky to run the lanyards for the mizzen deadeyes in my experience..
Keep on with the great work!Cheers!
Peter
- NenadM, Omega1234, CaptainSteve and 3 others
6
Epoxy and microballoons is an excellent filler and should not shrink much.
It's also lightweight.
Hobby shops that sell RC planes might have microballoons.Back in the 80s when I used to build windsufingboards, you used to be able to by them in the surf shop in larger amounts, as well as epoxy resin.
Probably not likely these days, I don't know.
If you use microballoons, wear a mask. They are actually made of glass, and can fly around like dust. You do not want to breathe glass balloons../Peter
Hi Nenad,
Probably best to be careful with the glue type.
Is a large percentage of the filling glue? How much does it shrink when it dries?
As Patrick said above, perhaps resin would be better.It doesn't shrink much and does not need evaporation to harden.
If the hull is to a large percentage filled with water based glue (the rest being wood, leaving no air), it will dry very slowly, and shrink as it does.If air cannot come in to replace the lost volume, the hull might come under strong (imploding) stress!
Might deform the planking inwards, perhaps not straight away, but if the glue takes a very long time to dry, perhaps in a year or more.Please be careful.
/Peter
- GLakie, Omega1234, CaptainSteve and 2 others
5
Ornamentation looks really good!
I see you made a new figurehead.That was the main part I was unhappy with when I first opened the box.
It's so bad that they didn't even use it on the model in their catalogue! :-)/Peter
Peter Jenssen Jeg skulle vel ikke kunne skrive til Dig på dansk ?
Absolut! :-)
Jag är Svensk med Norska förfäder, men förstår dansk! ;-D
/Peter
That looks excellent!
/Peter
Thanks!
Now for the tacks;Drilled a hole at the end of the block to attach a rope.
Ready to install, approximately where Campbell's plans have them.
Looking at pictures of the real ship, the tacks, sheets, clewlines and reef tackles are all rigged up together.
Most models omit the reef tackles, Billing's rigging plan does not have tack lines either.
(I may leave out the reef tackles as well, not sure yet)Cheers!
/Peter
Thanks,
In the early 80's, the parts were just printed on different sheets of wood and you had to cut them out yourself (I was using my dad's bandsaw which made my mum a bit nervous).
The deck was on one sheet of wood (1.5mm veneer I think), and if I remember correctly; the deck houses were marked, and the masts as well as the deck plank pattern was also printed, -but no markings for the fife rails..
Anyway, once I had cut out the deck and drilled the mast holes, I scribed the planking with a knife and sanded off the printing.
The deck was then finished with a coat of varnish, a dark wash followed by a second coat of varnish. Not very realistic, but looks nice enough..The main reason the holes were still not drilled for the fife rails is probably the same as for the rest of the missing rigging around the fore mast.
I had just quick-rigged the foremast (not finishing it) and left the model at my parents house when I was going off to university. It then remained there until about ten years ago when the whole rigging was taken down for ease of transport.
- juleslucas, ScottRC, GrandpaPhil and 3 others
6
I think when it comes to the gammoning, usually they are indeed rope, however, I believe Campbell has this one right and for the Cutty Sark, the gammoning is actually chain.
Thanks,
Peter
Looks great!
You mentioned you are adjusting deck camber when installing them, -just don't forget the roof camber! :-)Are you doing both deck houses at the same time?
(Looking at mine, it's pretty obvious that they were made at different times as the work finish and the colour hues don't quite match! :-( )/Peter
Thanks Nenad,
There are several simplifications though.
I have skipped a couple of brace pendant blocks, omitted the upper topsail sheets and most of the running rigging to do with sails.I may install reef tackles for the lower yards, but have not decided yet.
Cheers!
/Peter
Vasa by puckotred - DeAgostini - Scale 1:65
Posted · Edited by Peter Jenssen
This looks like rather impressive gun casting. (My Corel kit came with some generic guns, not anything like the actual Vasa guns)
I don't think it would be a 1 pounder or 3 pounder though.
They would be a lot more slender.
Looks like a 'Stormstycke' that goes on the forecastle.
Also, red for the Vasa carriages is probably not historically correct.
The accounts book states black paint purchased specifically for the gun carriages.
Seems to be a great kit so far.
/Peter
