HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
Seventynet
Everything posted by Seventynet
  1. Hi Paul, I just discovered this interesting build and am pulling up a chair. Beautiful work as always! ian
  2. Mark, I don’t foresee any problems making the carrier out of aluminum, I am just a bit hesitant about drilling the hole through the spindle headstock. It seems like drilling through 4 or 5 inches of aluminum would be quite an adventure and I don’t own a drill press. But it might be easy enough to mill a slot in a 1/2 square piece and epoxy it into the headstock inside corner to hide the wire. I’ll figure it out. Thanks again for the excellent design. Ian
  3. Hi Mark, Thanks for the explanation. The hole in your spindle stock stumped me until I realized that the headstock I have predates yours by a few years when there was no through hole, which as you say is perfect to run the wires up out of the way. That’s too much aluminum for me to tackle so I’ll try to find a different solution. Best, Ian
  4. That is a nice idea, Mark. Since I see you are not CNC did you use a fly cutter to make the hole? I think I will make this too. I notice there are dimmable RBG and possibly white light rings on Amazon that could address brightness levels. How did you run the wires up? It looks like the wire comes out the top of the headstock spacer…? Regards, Ian
  5. I agree with Yves. I used some 40 grit to start, eventually getting it to 220 grit and used fairing strips as I went. Lots of elbow grease. Ian
  6. Your planking job looks first rate. As far as what to finish it with I can’t help you but I do understand your sentiment as I felt the same way when I finished the walnut on my catboat. I often look at it and think I’ll paint a waterline and some colour below it, and maybe I will someday. Anyway your beautiful ship inspires me to get at my kit. Ian
  7. Beautiful job. I especially like the dragon head and tail. Ian
  8. Greg thank you so much for the kind words; although continuing to impress you will be tough indeed. 😀 Ian
  9. Really nice explanation of how you made the windows. I remember that same challenge with my Haying Hoy. Now I am configuring the windows using cnc which should do a good job. The biggest obstacle is figuring out how to get a good enough bitmap and then converting that to vectors. I really like your project. Ian
  10. Thank you billocrates, Mikki, Cisco, and Sfotinos for your overly generous praise. I know that there are lots of mistakes but hopefully not too noticeable. Ian
  11. So a little bit of progress. I’m going pause work until the next chapter has arrived. As you can see I decided to partially plank the port side and fully plank the other side. This is how I did my Hayling Hoy and I really liked the effect. I know I’ve made more work for myself because now I will have to plank the corresponding insides. Lining the hull into 3 sections: Laying the Garboard strake: Lining out the rest of the hull: Half way there: Finished starboard side: From the bow: Port side finished: Treenailed with 25lb monofilament: Notice how translucent Holley is. You can see the frames through the hull. If I turn off the overhead light you can’t see the frames anymore. 5/32 Cap rails installed. Inside faired: Cheers all, Ian
  12. Great work Tom! Your project has given me some ideas for my Gokstadt. Could I ask what you used for the hinges and clasps for your sea chests? The benches are the one thing I never got around to. ian
  13. Such nice clean work Rusty. I am going to slow down so I can benefit from your excellent work. Ian
