Posts posted by aydingocer
Build day 35: 4hrs / Total 73 hours
Today I spent about 4 hours on
- masking and aligning the rails,
- varnishing the hull,
- painting,
- gluing the rails.
Photo 298: Sliced approx. 2mm wide strips from my masking tape for covering the areas where the rails will sit, to prevent from varnish. -
While they are drying, I prepare the other ones (that need no prior bending). I used my Dspiae sanding stick to remove laser char as good as I can, focusing mainly on more visible areas. I also use clamps to help strengthen against sanding stick strokes.
Photo 294: Parts carefully removed from the wooden sheet.
Photo 295: Here is a comparison, chars removed vs not removed.
Photos 296-297: Use of clamps and sanding stick.
Build day 34: 2hrs / Total 69 hours
Today I spent roughly 2 hours on preparing rail patterns. These are among the most delicate and fragile parts.
Photos 292-293: Sheer and Waist Rail patterns, removed, soaked (for 20 mins) and pegged on location, waiting to dry for at least 24 hours. As instructed, I used scrap planking strips to apply even pressure and prevent from being damaged.
Photo 291: A waterline can be painted in any color, as long as it is black 😆.
Well, I thought over this a lot and finally chose black instead of white. As I wrote earlier I like slightly visible planking patterns rather than a completely smooth surface, as it gives a more hand made like look. In my opinion black would suit better than white in this case. I am happy with the result.
- Vladimir_Wairoa, mtaylor and ccoyle
- 3
Several photos showing the progress of Quarter Gallery windows installation. Here there is quite a bit of rasping and bevelling of the parts. It mostly went smoothly but at some parts I used wood filler to achieve smooth transition. At this stage sanding is not complete yet. Most of this section will remain under paint and decoration.
Photo 283: Bevelling of the roof part.
Photos 284-285: Windows on both sides.
Photo 286: Lower finishing patterns, made up of three parts, dry fitted. This will substantial amount of rasping and sanding to get to shape.
Photo 287: Looks about like this after shaping
Photos 288-290: Wood fillers to cover impurities. I will sand them more later.
- hollowneck, Vladimir_Wairoa, BobG and 2 others
- 5
Photo 281: Paint dried, masking tapes removed. Looking good enough.
- CiscoH, BobG, Vladimir_Wairoa and 2 others
- 5
Build Day 31: 1hr / Total 62 hours
After sanding, one layer of wood filling looks good enough to me. I prefer the wood plank patterns exposing a little under the paint than having a perfectly smooth painted hull. To me it gives a more handmade look than ready made hull. It is a question of taste.
Photos 267-269: Main whale patterns soaked in hot water for 30mins and pinned temporarily in place to dry and get the shape. These are thicker than the parts we did the same procedure earlier (1mm vs 0.8mm) therefore 30 mins is the minimum you should keep them in water. It was enough to soak only the front section where it will bend. Now it will rest at least 24 hours.- DonSangria, BobG, chris watton and 2 others
- 5
- CaptnBirdseye, CiscoH, mtaylor and 2 others
- 5
- Knocklouder, BobG and mtaylor
- 3
BUILD DAYS 27-30: 14hrs / Total 60 hours
Photo 260: 2nd planking is finished. Now the hull is ready for preparing to remove the jigs and its parts before sanding.I used UHU Hart glue and spots of super glue for securing quickly at the ends.
- DonSangria, BobG and mtaylor
- 3
BUILD DAY 26: 1 hour / Total 46 hours
Photo 259: Continued planking with two rows of pre-cut pear planks and one row of pear strips.
- BobG, DonSangria, James H and 3 others
- 6
BUILD DAY 25: 1 hour / Total 45 hours
-----Photo 255-258:
Aft Outer Planking Patterns (271, 273),
Front lower Outer Planking Patterns (305, 307),
Rear lower Outer Planking Patterns (306, 308)
are also now glued in place, after soaking and bending where necessary.- JeffT, ct mike, DonSangria and 2 others
- 5
Photo 251: Fore outer planking patterns. Soaked in hot water and clamped in position, waiting to dry... this time completely, I promise 🤣!
- hollowneck, CiscoH and mtaylor
- 3
- hollowneck and mtaylor
- 2
6 minutes ago, James H said:
Ah, and if that piece is still damp, it won't have shrunken back to its proper size. Pear swells a LOT, so you need to make sure it's bone dry.
That's most probably the case. It is the first time I am working with pear and I have to admit it was not perfectly dry. I have left my workshop room for the day now and I'll see tomorrow how much it shrank. Luckily after all it will stay under the upper counter so I am hoping there is room for correction.
- mtaylor and hollowneck
- 2
HMS Sphinx 1775 by aydingocer - Vanguard Models - 1:64 - Revision #2
Photos 299-300: Rail patterns masked, ready for varnish. I applied acrylic matte white Admiraly varnish from Caldercraft using brush.
