Chuck
Administrators
Everything posted by Chuck
  1. No not yet. That is months away I am afraid. I am using MinWax Wipe-On-Poly for the finish. Nothing else. Started on the timber heads today. There are only six. No shortcuts here. Just grab a sharp blade and start shaping. I know some folks use power tools for this but I prefer to go old-school. I just go very very slow. They are 3/32" thick. Chuck
  2. I created the rudder port by flipping the hull upside down. I made a pilot hole and slowly opened it up and shaped it. I made the rudder first which is shown below. This was used to test the size and shape of teh port and when I was satisfied I touched up the red paint around it. Then it was time to add the small top section of the rudder post. I designed the model so it was simulated and put on in two pieces. The laser cut longer piece is shown in the same photo below. I left a longer tail so folks can sand it down to fit their models. The deck level will probably vary model to model and this takes care of the issue. Once filed down to fit, it was glued into position and painted. To pull off the illusion I used yellow glue which sets up slower. By having the rudder made I was able to tape it in position so I could get the correct angle for this tiny piece. This step was crucial. It was tweaked while the rudder was taped on temporarily. The yellow glue gave me a lot of time to move it around so it was positioned correctly and creates the illusion of a one piece stern post. A little sanding on the outboard edge and some filler and it looked really good after painting. I still havent decided if I will paint the inboard portion of the rudder head. I probably will as is stands out too much left bright. And finally....I made some time to paint the windlass. I havent glued it into position yet but here are some overall detailed photos.
  3. Thank You.....I am not sure I understand what photo spars is. Can you clarify? I will certainly help you any way I can. Chuck
  4. Yes indeed...on each end...I have seen some folks use 6 or seven and sometimes more at each end. It just wouldnt be the case. Its usually because they don't taper the planks to curve them. If you use straight planks then you may well be forced to use many more which is why they usually tapered them. I also find that they start the nibbing process too soon. It usually isnt needed till the margin plank turns down the sides of the bulwarks further aft then most start.
  5. Druxey On this particular model they are not curved or tapered. They are straight planks. Go figure!!! Chuck
  6. I agree that both methods were used. until around 1825-30 when most decks were nibbed. Here is an image of a 1770's cutter. It is a contemporary model for sure. The deck is clearly nibbed. Both methods were used and its just a matter of picking which you prefer to model. I prefer the curved planks with hooked and tapered scarfs over the straight and nibbed. Although there was also curved and nibbed deck planking as well. Like everything else....its a matter of personal preference. Chuck
  7. And finally....the deck is planked. This is a big milestone for me because it is the last really big messy job to be done. The remainder of the project will be small fittings and less sanding. There will be less dust and less paint touch up. The planking was pretty straight forward after having lined off the deck. I just following the plan I drew on the false deck. Each plank was tapered to match. The scarphed planks were handles much the same way the drop plank was on the outside of the hull. If I thought it was needed, I made a card stock template. The scarphed planks were cut from wider stock (7/32" or even 1/4" wide planks). Next I will create the rudder port because it will be the last time I can turn the hull upside down without too much trouble. Once that is done I will return outboard and finish off all of the details. The boom crutches, boarding ladders, scuppers and channels etc.
  8. That is looking very good Alan. Its fantastic to see you back in the workshop. Hope you are doing well. These are difficult pieces to shape and they look like they will work out very nicely. Chuck
  9. The Fleet Book of the Alaska Packers Association, 1893-1945: An Historical Overview and List By Donald H. Dyal North Charleston: CreateSpace, 2014 8-1/2” x 11”, softcover, xvii + 208 pages Photographs, notes, index. $44.99 ISBN: 9781499329209 The last large American fleet of ocean-going sailing ships was that operated by the Alaska Packers Association, seasonally carrying workers from San Francisco Bay to the mouths of Alaskan rivers and creeks to can salmon. This salmon canning business was very lucrative, second only to lumbering on the West Coast in the late nineteenth and early twentieth centuries. The ships that made up this fleet were very miscellaneous. None of them was purpose-built for the Association; all were purchased, usually rather cheaply, after hard service lives of fifteen to twenty-five years in the worldwide oceanic trades. (It is worth remembering that fifteen to twenty-five years was regarded at the time as the usually working life for a merchant vessel.) Remarkably, most went on to provide twenty-five years or more of service with the Association’s fleet, despite the rigors of the Alaska canning trade. Donald H. Dyal set out to research the extant fleet books in the archives and consolidate the information they contained into a single comprehensive fleet listing that would tell the remarkable half-century story of these vessels (and their steam or diesel-powered fellows). The heart of the book comprises thirty-six individual “biographies” of the sailing vessels of the fleet. Each vessel’s origins are presented in tabular form, followed by a short history covering its operations prior to, during, and after service with the Association. Dyal also includes remarks on surviving artifacts from the vessels, two of which (Star of India and Balclutha) are preserved to this day as museum ships. The powered ships are treated much more briefly, as are those vessel chartered by the Association and the Liberty and Victory ships it operated during World War II. One of the most interesting features of this new Fleet Book is the author’s excellent summary of the history of the Alaska Packers Association that opens the work. This presents not only a chronological summary of the Association’s story but also material on the routine of its operations; both important to provide context for a fuller understanding of the industry and the vessels in its service. Overall, The Fleet Book of the Alaska Packers Association is an invaluable reference for both researchers and aficionados of the later days of oceanic sailing ships. It is packed with useful material and, equally importantly, replete with pointers toward sources for those interested in greater detail. Henry Farrar Baltimore, Maryland
  10. Silent Strength: Remembering the Men of Genius and Adventure Lost in the World’s Worst Submarine Disaster By D. Allan Kerr Portsmouth, New Hampshire: Jetty House, 2014 6-1/4” x 9-1/4”, hardcover, xvix + 124 pages Photographs. $29.95 ISBN: 9781937721190 Silent Strength (which takes its name from the motto of USS Thresher) is a compilation of articles by D. Allen Kerr published during 2013 to commemorate to fiftieth anniversary of the boat’s loss as tributes to the men who served aboard the submarine. As such, it does not concentrate heavily on the design or construction aspects, nor on details of Thresher’s loss, but more on its legacy. From an operational perspective, Thresher’s most important legacy (as Kerr notes frequently) was the development and implementation of SUBSAFE: the Navy’s quality assurance program designed to maintain the safety of the nuclear submarine fleet. Thresher also was the lead boat for the fleet’s advanced attack submarines designed to hunt down and overcome the Soviet Union’s expanding nuclear submarine force through speed, silence, deep-diving ability, and the deployment of advanced technologies. Thresher’s human legacy is the lives of the 129 sailors lost in this tragic disaster. The story of many of their lives is the central element of Kerr’s book. Kerr’s skillful writing brings out, over and over again, the accomplishments of seemingly ordinary men, from a whole range of social and educational backgrounds, who came together as a cohesive team to operate this submarine that was on the cutting technological edge of its time, thanks to training, dedication, enthusiasm, selflessness, and commitment. This is a fascinating exploration of the often obscure nature of the submarine service’s social history. Silent Strength’s melding of operational and technical history with evocative retellings of the lives of Thresher’s crew is a wonderful tribute to these men. Michael O’Brien Tampa, Florida
  11. Submarine Torpedo Tactics: An American History By Edward Monroe Jones and Shawn S. Roderick Jefferson, North Carolina: McFarland and Company, 2015 6” x 9”, softcover, viii + 221 pages Photographs, diagrams, notes, bibliography, index. $45.00 ISBN: 9780786496464 During two world wars, the menace of submarine warfare against merchant shipping loomed large in naval strategic and tactical discussions. Germany’s U-boats came extremely close to forcing the Allies to the negotiating table during World War I and were a major threat to Allied success in World War II. How ironic it then is that the single incontestably successful submarine campaign against merchant shipping should have been that of the United States Navy against Imperial Japan in World War II. Submarine Torpedo Tactics lays out, in a wonderfully readable manner, the story of this evolution in the United States Navy from just before World War I to the present (within the limits of information publically accessible). The authors bring together a vast array of material, much of which has been published previously in snippets but never before presented together in such a coherent format. The net result is probably the best explanation yet of how submarine attacks have been and are now conducted. If a reader wants to know why American submarines were so successful in their assault on Japan’s shipping during World War Ii and they proposed to keep Soviet ballistic missile submarines at bay during the Cold War, this is the place to find the answers. Of necessity, the requirements of their thesis obliged the authors also to explain the development of submarine design in the United States. Their success is such that Submarine Torpedo Tactics may well be the best short outline of this process yet in print. It is concise, it highlights the major milestones, and it presents sufficient technical detail to make its case without overwhelming the non-specialist reader with esoteric terminology or concepts. Submarine Torpedo Tactics also includes a major bonus in the form of stories illustrating the lives of the operators, ranging from the antics surrounding theft of a totem pole by crewmen from the missile boat Growler through the installation (and use) of a Steinway grand piano aboard the attack submarine Sturgeon to vivid descriptions of underwater gyrations by American and Soviet submarines during the Cold War. Though short (in light of the magnitude of its topic), Submarine Torpedo Tactics displays excellence on so many levels. anyone—academic, lay researcher, or simply interested reader—can only learn from this most enjoyable and informative study. Steven Fitzgerald Wilmington, Delaware
  12. Sveti Pavao Shipwreck: A 16th Century Venetian Merchantman from Mljet, Croatia By Carlo Beltrame, Sauro Gelichi and Igor Miholjek Oxford: Oxbow Books, 2014 8-1/4” x 11-3/4”, softcover, vii + 180 pages Photographs, diagrams, maps, appendix, notes, bibliography, index. $70.00 ISBN: 9781782977063 Distributed in the United States by Casemate Academic, Havertown, Pennsylvania Many people forget (or never knew) that much of the eastern coastline of the Adriatic Sea was territory of the Republic of Venice until well into the eighteenth century. As a result, the waters off the coast of Croatia and, to a somewhat lesser extent, Montenegro and Albania are likely to be the final resting places of many Venetian ships, wrecked while trading within the Adriatic or voyaging from elsewhere in the Mediterranean. During the past twenty years, in particular, archaeologists have been searching these waters in the expectation of locating wrecks of Venetian ships. This book about the Sveti Pavao shipwreck is a preliminary report on six years of work on the site by members of a joint Croatian-Italian project that has been excavating and conserving objects from what is almost certainly a sixteenth-century Venetian merchant vessel, one of a number of such craft located in the same general area over the past thirty years. The wreck is quite deep (about 40 meters (130 feet) below the surface) and also quite concentrated. Because the team had very limited funding, it took a somewhat innovative approach to recording the site by making extensive use of photogrammetry. This both substantially cut the amount of time divers had to spend on the bottom recording data, since they could use photographs rather than manual measurements, and also opened up interesting possibilities for interpretation, because the imagery could be manipulated both to uncover information that might have been missed during a visual scan and to generate three-dimensional representations of the wreck and site. This particular preliminary report concentrates primarily on objects that have been recovered and undergone initial conservation. There is much cargo—mainly high-end luxurious metallic and ceramic vessels—coinage, and animal remains that may represent livestock transported as cargo or for consumption by crew and passengers. There is also an impressive array of mid-sixteenth–century ordnance, most of which are breech-loaders. It is interesting to note that the barrels of the breech-loaders are bronze, while the breech chambers are iron; an interesting detail for researchers. The remains of the hull are very limited. Nevertheless, photogrammetry and subsequent three-dimensional modeling proved very useful in interpreting the remains for archaeologists and, especially, for public display (since the team had decided to leave the hull elements in situ rather than raise them for conservation and display). This preliminary report provides a fascinating insight into elements of sixteenth-century Venetian trade and the ships that conducted it. We can only look forward to more information as research funding permits. . David Djanogli Chippenham, Wiltshire
  13. I just wanted to let all of you folks know that as the conference approaches we have quite a few folks who will be attending. We may in fact have close to 175 attendees before it all begins. But as an aside I wanted to mention to those who have never attended one of these and havent signed up for this one, they can still make a day out of it and come visit. We have two very large rooms at the hotel. One room we call the vendor/model room is open to all. You dont have to be signed up to drop by and talk ship modelling with your fellow hobbyists. You can visit the many vendor tables and have a look at dozens of models on display. All brought in for display by those attending. The other large room is where we have our talks and table top demos. You must be signed up and pay for those. But if you are looking for something fun to do. Come out and spend the day at Mystic Seaport or the aquarium. We are right across the street from the aquarium. Then pop your head in to meet and talk to all of the ship modelers attending. Browse the vendor tables and say hello!!! I am sure you will see how much fun it is and maybe decide to sign up next year and attend!!!! You may even see how joining the NRG is going to be fun and meet a whole bunch of new friends.!!! The 2015 Conference will be in Mystic, Ct. on Thursday October 22 thru Saturday October 24. I would love to see you guys and will be at the Syren vendor table with my wife Patti and son Roman. Here is a list of the other vendors who will be at the show. Crown Timberyard - Milling services and wood for Ship Models Bluejacket -Ship model kits and supplies Byrnes Model Machines - Ship Model Power Tools Seawatch Books - Nautical history and Ship model books Seafever Books - Out of print Nautical history and Ship model books Ages of Sail - Ship model kits and supplies
  14. Nice progress!!! You are getting a lot done. It looks just great.
  15. Looks very good Dave. But you will know when its completely faired when all of the laser char is removed from the bulkhead edges. Just a little more to go...
  16. Looking great Dave..... You might also want to consider hard maple. If you can mill it on your own it is readily available and very reasonably priced. It will be much easier to obtain a better finish that closely matched the boxwood using it. Even at Lowes or Home Depot.
  17. Thanks John The beauty of lining off the deck is that it allows you to create a great plan of attack. If you connect all of your tick marks you will have a really good idea of how it will look. If it needs adjustment then just sand it off and start over. You can do all of this before you lay one deck plank. Imagine if you just wing it and have half the deck planked...you are sunk. Lining off the hull first helps you avoid this. I will do this at the stern next and then start cutting wood. Now if you were just going with straight planks nibbed into the waterway, would you need to line off the deck like this? Maybe not. But I think it is worth the extra work. And keep in mind you want have to cut into your waterway and risk a cutting error with a bad joint while nibbing. That takes a huge amount of time and careful chisel work. So its pretty much a wash as far as the amount of time and effort goes. The contemorary model of a cutter shown below also has tapered and scarfed deck planks vs. nibbing. You can see the tapering very clearly here. Chuck
  18. Deck planking has started. Just a quick note about the two styles of deck planking. There were the times when deck planking was straight and nibbed into the waterway. Most are familiar with this style. I in fact drafted the plans for Cheerful this way. However, I believe that the earlier style was still in practice at this time and probably both were used. More like a transition period. In my opinion up to possibly 1820 or even later. This second style would be where tapered and hooked scarf joints were used. No nibbing into the waterway. I have decided to use the second style as the first is so common. You see it all the time. I find this more pleasing to look at as the planks are curved. Straight planks are to harsh in contrast with the curves all over the rest of the model. Folks can choose which method they prefer. I did use the scarfed method on the Confederacy but I simplified it with straight planks. In reality the planks would have tapered and curved a bit at the bow and stern. Like this below. Also note the curvature of the planking on this contemporary model. After gluing the six deck structures in position, I drew reference lines for where the deck beams would be located. This will become important later. Then I planked down the center with one strake (3/16" wide). I followed that with 2 on either side of that one. These were straight-non-tapered planks. Then I started lining off the deck much like I did for the hull planking. Although in hindsight, I should have probably tapered these 5 center planks as well. See the contemporary model image above. But they are already done, so I am moving on.... First I measured with a tick strip in 3/16" increments at the deck's widest point. The beam reference line on the forward side of the main hatch. This showed that I still have ten deck planks to put on each side. I used blue tape in thin strips to separate the deck into two belts both port and starboard. The inner belt on each side has 6 planks....the outer has four. I manipulated the tape until it curved nicely from bow to stern. Remember these are not straight deck planks. The curve is not very drastic. But it has to be taped out so you can visually check the symmetry port and starboard. Once I was happy with it, I traced the inside edge of the tape to define each belt. I removed one strip of tape in the photos below. Note the curve of the blue tape still on deck. Then, just like I did for the hull. I used my planking fan and tick strips to divide the deck up at each reference line for a deck beam. This will show me how much taper I will need in each deck plank. Its just a matter of measuring the total distance at each deck beam and transferring it to a tick strip. Then you take that tick strip to your planking fan and divide that space into six equal parts. Then you come back and transfer those ticks to your deck beam reference line. All of the planks in this inner belt will be cut flat on the ends with no scarf joints yet. I find that on most contemporary models there are only a few scarf joints.... as opposed to modern models where the builder uses way to many. I have always seen just two or three and on the rarest of occasions four hooked scarf joints against the waterway. Most people start way too early and end up with too many of them and it looks very busy. This is also true of just plain nibbing into the waterway. In addition, by curving and tapering the planks it actually reduces the need for that many of them. Thats it for now as I continue to use tick strips to define the width of the planks at each deck beam location. Then I will start cutting more wood.
