Everything posted by michael mott
Another clever solution to one of those tricky parts that are difficult to do in miniature. Well done sir the results speak for themselves. Michael
Hi Patrick, it is tough keeping up with the speed at which you build these tiny mega yachts. I'm wondering if this one would look even more stunning if the hull was painted with a lower sheen, The only reason I say that is because we can scale down the model but we often do not scale down the high gloss at the same time. I know we cannot scale nature but we can scale our perception of it. Super model as always. Michael
Another miniature masterpiece Javier. What I love about this tiny ships that you build is the integrity of the work, all the framing and detail in areas that will never be seen and that the model has a story that most will never know. I do so enjoy watching these jewels come to life. Michael
Hi Vaddoc just a bit of catching up, you are making great progress. I was just thinking about your comments on the shrouds and the sorting out of the ends I spent some time with this exact issue as well and i found that I got great results by beginning with some shrink tubing like this Regards Michael
Mike , your planking looks superb! Very clean. Michael
- 607 replies
- winchelsea
- Syren Ship Model Company
Good evening Ed Just finished reviewing the last few bits of work. Thank you for an amazing journey, I have not only learned a great deal about the YA but also about your approach to solving some of the challenges that this model presented. Congratulations on the completion of a Masterpiece of Model Shipbuilding ! Michael
- 3,618 replies
- young america
- clipper
Looking at the photographs of the excavation site, it never ceases to amaze me how much silt is transported by the River and in such a short period of time. Michael
- 599 replies
- sidewheeler
- arabia
(and 4 more)
Hello Keith, the hull decking looks superb. Your Granddaughter looks peaceful and resting well after her journey out to join us all. Michael
Hello everyone, Yes I am still in model engineering mode, I have also had a very busy non modeling summer. The model is like all of the work I do, well it seems that a good deal of it, is make things for replenishing the scrap box. I have been working on the frames cylinders and valves which included making a few tools along the way to achieve what I wanted. Afew pictures to show that I was not just sitting around drinking Pina Coladas😀 A rebuild of the boiler Silver soldering the fire tubes to the smokebox plate and the firebox plate Mr Brown checking the progress on the frames The hornblocks for the wheel bearings The wheel bearings as per the originals are split so as to facilitate removal because the wheel will be fixed to the steel axles. the brass ones are just temporary keepers. Beginning work on the cylinders these eventually graced the scrap box A new set of cylinders was begun from some blanks of 2 inch diameter bronze faced to thickness then rough shaped on the bandsaw. The assemblies of the cylinders with the first set of front cylinder covers, more fodder for the box. Making steel hex 1x72 machine screws Fitting the cylinder guide bars, it was at this point that I decided to remake the front cylinder covers to better reflect the actual cylinders. the next set follows. Now a new cutter was needed to make curved recesses After shaping the teeth and hardening the cutter then touching up the cutting edges a test to see how it worked Next the new covers were addressed with the new cutter after a lot of fettling with some rat tail files and slips of emery stuck to thin strips of brass I am happy with the result The top of the cylinders will get a joining plate that will include the inlet and exhaust pipes the valve chamber is common to both cylinders, the motion for the valves is Allen straight valve gear. that is in the future. I will get back to the Bristol Cutter when my fingers get tired of metal I promise. Michael
Hi everyone I am still in railway mode..... it will pass eventually and I will be back at the boats. working on a new live steam boiler at the moment. Shaping the base of the steam dome with some 220 stuck to the same diameter copper tube 2.875" diameter next picture shows the smokebox and boiler in line the flanged front tube plate will act as a register for the smokebox. here is a line drawing of the boiler And the running gear This is the locomotive Michael
Sweet Keith!! very nice work on the removal from the build board and a lovely looking hull now that all the extra wood is gone. nice scroll work too. Michael
Mark, What an exquisite model! It is a pity that I live so far away, I would certainly enjoy seeing the model up close. Michael
I have been absent from the forum for a little while because I have been caught up with summer model railway stuff. I have to squeeze past the boat models as i go back and forth to the bench. The garden railway needed some maintenance and well you all know where that leads. I have also needed to spend time in the house with Judy so took up a kitchen table work spot to work on a couple of sculpy figures for the 1/8th scale Montague's Carriage . Carriage and railway. Which led to trying the live steam loco for the first time, it ran very fast and so i needed to build an inertial wagon to give it something to work against which led to a load of work. This was the final version of the gear train. and then it needed to be tested. It worked very well and so then needed to be dressed up a bit. Here is a Mars on a test run So even though I have not been active here I have been busy with model work all the same. Michael
