Everything posted by michael mott
John, Pete, thanks for following along and all who have visited and liked what I am doing. In order to be able to set in the Lexan after every thing is varnished I needed to be able to fix the cleats with the bars afterwards, fortunately I had some very small brass flat head wood screws, I purchased them from Lee Valley page 203 they are #0 x 1/4 Step 1 was to make a small self centering awl for transferring the hole position to the cleat. I used a bit of 3/16 steel hex stock I had on the rack. after they were marked I used the same awl to make the indent larger for the #60 drill the next pic shows all the tools for setting the holes. I did have to countersink the frames so that the screws had enough purchase on the cleats I did this with #33 drill just twirled it between my fingers. seems to hold well enough. one down three more to go
- 2,207 replies
Druxey, Bob, Ian, Steve, thanks for your positive comments, and all who pressed the like button. I finished rough sanding the four lights and am starting to work on the cleats with the bars that protects the Lexan. after cutting the cleats they were drilled with an .046 drill to accept some 3/64th brass rod 3/8 scale size. the cleats were then given an initial shaping, by stacking them on foundation with 2 sided tape to sand them after assembling the first one the bars looked a bit small so I up sized them to 1/2 inch (1/16) but did not want to re-drill the holes. after cutting the copper tube to length I inserted some 1/32 brass rod in each end and gave the tube a gentle squeeze with some round nosed pliers to hold the rods in place. I am thinking that the copper looks better anyway. Michael
- 2,207 replies
An obvious concern for your safety Ed shown by the above posts. We all get more or less comfortable with the methods we choose to work with. My own thoughts when seeing your set up was one of less concern about the exposed blade than a snag caused by a slip of the clamps. I only use spring clamps where any slippage is not critical. my preference is always a screw type clamp when clamping to a substrate for milling or sawing with the mill with lateral movements. when cutting vertically with drill or mill a back stop to prevent rotation is either clamped with screw clamps or wood screws. Then a spring clamp for me would be OK. Regards Michael
- 3,612 replies
- young america
- clipper
Cutty Sark by NenadM
michael mott replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
Nenad that looks like a great challenge, perhaps you can do something along the lines of what Dan did on the funnel like this Michael- 4,152 replies
- cutty sark
- tehnodidakta
Looks great! now you're not going to chop half of it away are you? Michael
- 1,083 replies
Ah! Nenad you have discovered why I work in 1:8 and not 1:92... it is much easier. Michael- 4,152 replies
- cutty sark
- tehnodidakta
Andrew I beg to differ on this point. some of us drool at pictures like that Nice work on the kit model by the way. And yes I to am looking forward to your getting into the scratch building of one of these beauties, I think you should build it to 1:8 scale that way it would be 28 1/2 inches long which would be stunning. I would also think that 1:12 would be nice too at 19 inches. Michael
Looking forward to seeing the planking... perhaps a couple of pics before you complete the planking.... just sayin' since you are clipping along at such speed. Michael
- 258 replies
- buzzards bay
- herreshoff
Thank you all for the positive feedback. Here is a Step by Step of the preparation of the light frame for the skylight. The way of working at the computer desk is different that in the workshop in that I am only able to use small hand tools at the desk. With a little preparation a high level of accuracy can be accomplished with simple tools. To be fair I started with a few strips that were prepared in the shop on the table saw. the first task was to cut the profile to length, using the square vice that I use a great deal for both machine work and hand work. the design of the vice is almost the same as this one with the exception that mine has a dovetail slide and I made it myself as an apprentice 52 years ago. Next the lengths are squared up using the shooting board hooked onto the edge of the desk with a sanding stick instead of a block plane. The sanding stick has the sandpaper set in such a way that the sandpaper cannot wear away the shooting board by removing a strip from the bottom like this. I have a number of these sticks made from scraps of dimension lumber such as 2x4 the section varies depending on what I have available but I like to keep enough material so that is stays flat and square on the board. a little candle wax keeps them well lubricated on the bottom. I also generally use both sides each a different grit. I mark the ends for quick reference. To cut the 45 degree corners on the top and bottom rails I just clamped a steel 45 degree square to the shooting board. The way I use the board is to shift the work out a little so that I can see how much will be sanded off like this you can see there is a gap close to the stop. After sliding the stick back and forth a few strokes the stick ceases to cut like this Rinse and repeat as much as needed to remove the require amount, this works much faster that one would first think, I use this method far more that a powered sanding disk. The next task is to cut away the areas on the vertical sides this is done by transferring the angle to them from the top and bottom rails then cutting away the waste with the jewelers saw. The cut pieces were then cleaned up with the square file that has 2 edges polished smooth as safe edges this is one of my favourite files. then they are ready to be glued up. Michael
- 2,207 replies
Ergonomically it makes sense the way it is from a balance point of view, one step higher and then it would be easier to lose your balance swinging over the rail. because you would be too high. Nice profile Chuck. Michael
- 1,048 replies
- cheerful
- Syren Ship Model Company
Thanks for all the positive comments and likes it is very encouraging, and appreciated. The recent file organization has been completed and during the process I was able to fix a few photo issues in some of the early posts, a couple of links have gone AWOL (the nature of the net it seems). This evening I continued the work on the skylight. The frame material has been roughed out for all four lights. these are the 3rd and 4th sets This is the second frame glued up. and some in situ shots. Once all the frames are assembled I will make a few more hinges the same way as the ones for the cabin doors, I will also add the wooden bars with the horizontal metal bars to protect the glass (lexan). Michael
- 2,207 replies
Clever solution (pun intended) for the badges Nils. Michael
- 2,625 replies
- kaiser wilhelm der grosse
- passenger steamer
Siggi, outstanding work on those chairs. I did not expect you to really go that far, but am glad that you did. The final results speak volumes of you dedication to a wonderful overall model, and your skills. Michael
Thanks for the information regarding the tape Ed that is good to know. Michael
- 3,612 replies
- young america
- clipper
Nicely done Dan. great tip for twisting the wire in the knife collet. Michael
- 108 replies
- andrea doria
- ocean liner
Ed seeing the blue masking tape at first was a surprise, but then realized the relief from the anxiety of dropping a part makes the work more relaxed. Did you have to wash the surface afterwards to remove any residue that always seems to accompany the use of masking tape or is the blue tape special in this regard? A second question, do you use this method often because it was the first time I recall seeing you use it? I have been quietly following along and am always impressed by how clean everything always looks, and your commitment to being as accurate in your interpretation even when a large amount of the work gets mostly hidden. Michael
- 3,612 replies
- young america
- clipper
Thanks for all the positive feedback. After gluing the case together the ends of the channels needed a little more work in the way of small extensions so that the water doesn't just trickle down the side and ends. This was accomplished by taking a small strip of mahogany, and milling a groove the same as the channels then shaping the outside curve to create a cup like extrusion. This end was then rounded with files and sandpaper Oh and i had some help these were then cut off with a jewelers saw and glued to the appropriate locations. The side channels were a little more tricky to cut, and had first to be sanded to the same angle. I did this by placing the cup shaped piece on the side of the case and finishing the end with the sanding block. Cutting these off was done slowly with the jewelers saw with my finger underneath the end to act as a support, As the blade neared the bottom of the curve I used a micro back and forth motion until the cut parted off the pieces. these were then glued to the sides After all the extensions were glued and set they were cleaned up with some 400 grit sandpaper. The top bar was then shaped with a block plane and files and connected to the case with a couple of brass woodscrews from below. Next the hinged lights need to be made and fitted. Michael
- 2,207 replies
