Everything posted by CDW
These photos give a better idea of the gap I'm trying to fix. I glued on some .030" x .060" styrene strip stock, and once it's thoroughly dry, will shape it down to fit as close as possible to hide that ugly gap. Will have to re establish some rivet/fastener detail that will need to be replaced after it's all done.
I don't know yet about the engine cover fit, but in one build review I read, the author only found the fit of the forward gun cover to be a major issue. It is my intention to cut/remove certain panels to allow some of the internal detail to be seen. Most of it gets completely covered up unless the builder desires to customize/make some provision to allow it to be seen. There were only two prototypes of this airplane that were actually built before the war ended. Photos of maintenance panels removed are hard (maybe impossible?) to come by. Of the two prototypes, neither had guns installed, so this part of the kit is speculative and perhaps based upon design drawings.
After the basic airframe, attention gets focused on the fuselage skins. Unfortunately, I quickly began to realize there were fit problems. At first, I wondered if it was something I had done or failed to do in earlier stages of construction, but couldn't find anything. Then I began to look for obvious issues such as flash or other irregularities with the plastic molding and could find none. Last, I started searching for build reviews of the kit online. There is not much out there, but with the few I found, other modelers ran into the same issues I am facing so it is recognized as an engineering failure with the kit. it's likely the prime reason one does not find many finished kits of the model finished on the net. The major fit issue I am seeing at this time is the fit of the upper gun cover to the lower fuselage. Other modelers found the exact same issue. A very small amount of plastic needs to be added to the front gun cover to close the gap between upper and lower parts. It's not a deal breaker as far as building the model is concerned, but it is disappointing considering the cost of the kit. It should have been better engineered. It is often said but bears repeating, if you want the best engineered, best fitting plastic kit, buy Tamiya. Everything else is second place or lower. This model has some nice features, but it is going to be a pin in the rear to get it done right.
Liberty Ship looks great, Jack. Very nice indeed.
- 106 replies
- trumpeter
- john brown
Is this the tank you bought? https://www.scalehobbyist.com/catagories/Military_Vehicles/MGK0000TS36/product.php?gclid=Cj0KCQiAp7DiBRDdARIsABIMfoB7vm7stbu5-KYLSnMHVYcEA3ujAVlu95A4DZokwNpjVVismjWQwVEaAihxEALw_wcB
Indeed, it looks amazing! Very well done Seymore. It's going to be fun watching your next build, whatever it is.
Another memory... It was 1975, the Gator Nationals. Kris Karamesines (The Golden Greek) campaigned a AA Fuel Dragster that was painted in a beautiful black finish and all the parts were typically chromed or polished aluminum were gold plated. The rail got out of sorts from the start and he lost control of the car rolling over several times and parts/pieces flying everywhere. While most of the fans were concerned about Karamesines' well being, he jumped out of the wreckage and ran all over the track picking up gold plated pieces. It was pretty hilarious (and sad at the same time), and he was obviously worried about fans picking up gold plated souvenirs before he could collect them. Probably some fans did pick up gold plated souvenirs.
One other tip about photo etch. If you use CA, and the excess glue becomes smeared on the surrounding plastic or on top of your photo etch, use a Q Tip dampened with CA debonder to remove the excess. Only use enough debonder on the Q Tip to dampen, not saturate it. Too much obviously may cause your part to become unfastened.
- 106 replies
- trumpeter
- john brown
With a siphon feed airbrush, an often overlooked source of flow blockage comes when the tiny vent hole on top of the jar lid is blocked, but my first guess would be your percentage of reducer : paint is too low. In that case, the siphon is not capable of pulling the mixture through the feeder tube. I have never used Life Color paints so I don't know the viscosity you're starting with. Sometimes, even a 50 : 50 mix of paint to reducer is too low and you may have to simply increase the percentage amount of reducer until it will flow through. I am using the same bottle of Gator's Grip glue for almost three years now. Since it's water based, you'll need to keep it at/near room temperature. Over time it will thicken, just add distilled water to reduce it to the viscosity you want.
- 106 replies
- trumpeter
- john brown
Jack I'm late for your build thread, but enjoyed browsing through your progress. Love the subject model, so much solid history behind the Liberty Ships. Regarding your photo etch doors...I recommend trying/using acrylic glue rather than CA. 1. It allows all the time you need to adjust the position of the photo etch part and will provide a superior bond (IMHO) for flat items like doors to plastic. 2. It dries totally clear and will not mar the finish of your plastic or photo etch. 3. It's water soluble so clean up of excess glue is a breeze just using a water dampened q-tip. 4. Because it's water soluble, it's easy to remove a part if you make a mistake...even if it's dry. Gator's Grip acrylic glue works a charm for photo etch. A small bottle of it lasts a very long time, years even. Regarding your air brush issues...is yours a siphon feed or gravity feed air brush?
- 106 replies
- trumpeter
- john brown
Thanks Richmond. I used Mr Color Metal Aluminum on the engine cylinders and crank case, with Vallejo black ink for a wash to bring out the cooling fin details. Tamiya gloss black on the intake manifold and rocker covers. I used Mr. Color Metal Iron to dry brush the black manifold and rocker covers. For most of this model (maybe all?), I will be using Mr Color Acrysion, Mr Color Metal, Tamiya paints and some Vallejo washes. Will use Pledge Floor Care as a generic acrylic gloss clear coat where necessary before washes.
That's great that Testors is making an affordable airbrush most anyone can acquire. Things like this help grow the hobby as similar items that higher priced can discourage people from even giving the hobby a try. I remember well when airbrushes seemed out of reach for me from a financial standpoint. I admired them and those that used them, but just couldn't afford and/or justify the expense to acquire one. Painted everything with a brush and rattle cans for a long time.
