MikeR
Posts posted by MikeR
- gieb8688, GrandpaPhil and KeithAug
- 3
After the bulkheads, bracing and support pieces for the bits were installed I covered the deck area with a thin layer of wood, to make it a lot easier to install the deck planking. Then I added the waterways and planksheers.
The types of wood that I will be using are cherry for the hull planking under the copper plates. Dogwood for the rest of the hull , deck planking, and the masts, from trees that died in my yard from a disease that went through our area years ago. Bloodwood for the structure trim and ebony for the timberheads and railings. For the yards I will be using cocobolo.
Hello all
In the early 2000's, I got the model Flying Fish and last December 13, 2021 I started the build. I enlarged the plans 50% to 1:64 (3/16 scale ) to keep it the same scale as my other models.
I used rubber cement to glue the patterns to 1/4" plywood. I then separated them with a scroll saw and proceeded to cut them out. I tapered the bulkheads and then attached them to the center keel piece.
If you are still looking for a supplier for micro nut, screws, taps, and drills check out Tabco Optical. ( tabcooptical.com )
I purchased 100 M1.4/1.4mm nuts for $5.95 I made eye bolts out of 3/64 rod and used these nuts. I retapped these nuts with a 1.7mm tap for use with 1/16 rod. I enjoy following your build and the purple heart looks great.
- Keith Black, mtaylor, Saburo and 1 other
- 4
Hello Ed
I have been following your builds since the Victory and they are some of the best I have seen on this site. If this question has been answered before I do not remember. What do you use to clean the copper fittings after they have been installed on the ship, before you use liver of sulfur to blacken them?
Mike R
- mtaylor, Tom E, GrantGoodale and 9 others
- 12
- John Allen, Jack12477, mtaylor and 5 others
- 8
Jack, I should of taken some pictures, but once I started making the sail I forgot. I used vellum drafting paper. I tried to find vellum paper that shows the linen weave but I could not find any. I drew out the sail on graft paper, I then folded the vellum in half so the seam will be the mast side. I use a glue stick to glue a .020 brass wire on the seam and also to attach the battens. I also reinforced the corners with piece of clear plastic. I then used a spray paper adhesive to glue the 2 sides together. For the bottom of the sail I folded a strip of paper and glued a .020 wire on it then attached it to the sail. I then laid the mast over and ran the sail up the slot in the mast. Then the same thing for the boom. All I need now is get a few decals for the sail.
- mtaylor, GrandpaPhil, cog and 4 others
- 7
- shipmodel, Canute, GrandpaPhil and 5 others
- 8
Flying Fish by MikeR - 1:64 (3/16" to 1 Foot) - from Model Shipways plans
I have finished installing the bulwarks, bulwark ceilings, and the knightheads. I started to install the hatch and deckhouse coamings.
