AntonyUK
Everything posted by AntonyUK
  1. Hi Alexandru. As always you are producing totally Exelent work. and you cabin flooring is quite standing and so precise.. I can only look on and enjoy the build with eyes wide open. So much to enjoy.. Regards Antony.
  2. Hi. Just catching up on your build. A truly Exelent build. And the attention to detail is outstanding. Regards Antony.
  3. Hi. I have a question or a few questions... What type of construction are you going to use. IE bulkhead. Solid. Frammed. .? And what timber are you planning to use in your build. And do you have a forklift truck for moving LOL. Sorry for all the question But I also am into building model's at a scale that lots of detail can be added. Regards Antony.
  4. Hi E&T. Very impressive work going on here. The amount of detail is in equal to the amount of resurch you put in.. In other words OUTSTANDING ... Every little bit you do simply amasses me. Nice one. Regards Antony.
  5. Hi Shipmates. Thanks for the comments and the likes. Decided to try something new.. Cutting the outer planks some 48 each side of the hull. Started by glueing the black card onto the face of the Cherry timber. Timber now cut with the card already glued onto one edge ready to plank. A close up of the result. Found some moulding in my local dolls house. Quality is very good. made up the decoration to match the mouldings. Just adding a few bits to the quarter deck. Made up most of the furniture for the quarterdeck. Going to start planking the outer /lower hull this week. Thanks for looking in. Regards Antony.
  6. Hi and welcome to MSW. Would be nice if you told us a few more details on what you have to start with and the required finish. Or photos. Mask areas off that you don't want to paint. You can use a liquid masking solution. ( just peels of when finished ) If the gold areas are already fixed into place then hand paint them with a dark gold. Then drybrush them with the gold. Regards Antony
  7. Hi. This is one very smartly built model with lots of unique bits built into the design. This model is on my list to do for the future. Very Very nice Regards Antony.
  8. Hi Maris. What a fantastic build. Your designing of model ships is excellent and show your personal skills well. Makes me want to purchase the kit and make one for myself The detail you are putting into this will make a show piece model. Regards Antony.
  9. Hello Udo. This is one amazing build and you explanations are the making of a tutorial on how to make a fully framed a model ship. You're got another follower and will look for updates. Regards Antony.
  10. Hi Toni. That's one Excellent build you got going there. Your workmanship is outstanding. Regards Antony.
  11. Hi. This will be a interesting build. Are you completely drawing this from scaleing the model up or do you have a basic drawing to work from ? A big undertaking on the drafting side. Looking forward to your blueprints. Regards Antony.
  12. Hi Marsalv. You have made a excellent start on the Pandora. Using TurboCad has done wonders for the designing of your ship. Your bulkheads are looking spot on stacked like that. . I will be pulling up my chair and iPad and following you along with this build. All the best. Regards Antony.
  13. Hi Rich. Just read your build log start to present ... Most impressed with your build and style. She is going to be a large ship when finished It's nice to have builders out there and are willing to help with excellent advice and support. Will follow to compleasion of build. Regards Antony.
  14. Hello Ship mates. Thanks for your very nice remarks And also for the likes. A small update on the Quarter deck. The Deck planked and ready to tree nail. Another view from the side. The copper wire is only for testing the jig for the bending. Will use brass for this. Started on the deck furniture and will post a update when completed. Thanks for looking in Regards Antony.
  15. Hi Mark. Welcome to MSW. I use water(cold) to wet the plank and then I use a large wattage soldering iron with my home made bit on the end approx 25mm dia. Just wet the planks and run the iron over one side and when warm bend the plank into shape. You will notice the planks trying to curl up. Bend the planks just a little bit more then needed. And let them dry Never had any issues with plank bending using this method. Regards Antony.
  16. Hi Miroslac. Another interesting build of a Junk. Looks like you have a nice dog Mine likes to chew wood so it's a bit of an issue. All the best. Regards Antony.
  17. Hi. Found this EBook while resurching my next project and it makes very interesting reading. http://www.gutenberg.org/files/17563/17563-h/17563-h.htm This is is free to read and distribute. No copyright. Regards Antony.
  18. Hi Richard. When pushing through make sure the push stick in between the blade and the fence. Pushing from the none fence side will cause the timber to jam on the blade. The fence will hold the timber true but as the cut is coming to the end the push will close the Kerf. Can do a drawing better to explame what I am talking about. Regards Antony.
  19. Hello Shipmates. Another update.. on the victory. Quarter Deck is now planked and all tree nails and gun port hardware added. View of side ..No sanding here until all planks are in place and tree nailed. Quarter deck Timbers made up and ready to install. Not all the timbers are glued together yet as will do this on assembly. Getting to the part where adding the outer planking after this deck is planked and furniture is added. Then trimming the two end faces. All the gun woodwork parts are made and I have decided to remake the barrels. That's about it for now.. Regards Antony.
  20. Hi John. Nice build. I also love the Xebec and the lines she has. Looking forward to a few more pictures and will follow your progress MIJ has done a scratch build on this boat and it's worth a look at his build log. Using the same plans. Regards Antony.
  21. Hello Karl. First class masterpiece . Your workmenship has NO bonderys or limit's . Most impressed and jaw dropping stuff.. Regards Antony.
  22. Hi Morne. WOW that is gona be one big model ship. I an building a 1/36 cross section of the Victory and that's big. But yours will be enormous in size. One nice thing on building at a large scale is its easy to put in fine details that would have got missed due to being sooooo small. you will need lots of timber for your build. Any idea of the type of timber you will use ?. Got my chair booked.. Glasses on and ready for your build. BTW Adobe Illustrator is a brill tool for scanned images and enlarging the scale. Regards Antony
  23. Hi Tom. Yet another build Will be looking in to watch your progress and follow the growth of the model fron keel to deck and beyond. Best wishes Antony.
  24. Hi Mark. A very nice build with some excellent details. ... No lots of excellent details. Regards Antony.
  25. Hi Don. I assume that the paint is enamel type.. I was always told that when finished with the pot give it a good shaking (with the lid ON) The thinners produces a vapor that stops it from forming a skin and drying out. If you notice one that's thickening up just add 1 drop of thinners (the recommended type of course) Some of my old paints are some 15+ years old. Regards Antony.
