AntonyUK
Everything posted by AntonyUK
  1. Hello Shipmates. Started the planking to the sides of the main deck. Completed deck without furniture on. The Stain used to soak the treenails prior to installing them. Thanks for looking in. Regards Antony.
  2. Hi Shipmates. Thank you for the likes and comments. Drilling holes for the rest of the treenails today. Wow that's some 800 per deck The next deck is being milled and sorted into suitable timbers. Apart from the spelling in my last post... The treenails are soaked in Colron wood dye (Jacobean dark oak) Will add photo when I get back on the PC. And the planking spelling should read " stood on edge" Thanks for looking in. Regards Antony.
  3. Hi. Just found this book and Vol 2 and 3 also on sale. The Seventy-Four Gun Ship vol.1 Hull Construction - Boudriot http://www.ebay.co.uk/itm/380856396027?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Seller will ship world wide. Hope this is of some use to someone. I have no links with this seller other than I have purchased books from him. Regards Antony. Edited sale end prices. Vol 1 £79.52 Vol 2 £65.00
  4. Hi Shipmates. A few more photos on my progress up to date. Tree nails are cocktail sticks sacked on dark stain then dryed and a .6 mm hole drilled into the Tulipwood. treenail then glued into place and when dry cut with side cutter and sandpapered. Chalking done with Black card. All the planks steed on edge and card glued to facing edge with PVA glue. Before sanding down and after. Tree nailing done on far side only this side to complete now. This middle Deck is now almost complete and now need to add the furniture. I will add the scuppers holes and the holes for the Gunport lids ropes as I do deck by deck. Thanks for looking in. Regards Antony.
  5. Hi Mark. One word...Excellent. Love this build log. Regards Antony.
  6. Hi Remco. Just letting everyone else say what I am thinking. I will just look and drool over your skills. Regards Antony.
  7. Hello Daryl. Nice progress since I last looked in. Must be putting in a few hours to get this far so quick. Regards Antony.
  8. Hello Michael. Nice start to your build Nice to have your son helping Keep the photos coming as its going to be a nice build. Regards Antony.
  9. Hi. Use annealed copper tube of the correct size. Fill with casting sand(very fine sand). And block the ends. Bend around a bar of the required diameter. Can use heat if required. Bend as many turns as required. Remove the sand. Cut to make rings. Then grind outer part away. Regards Antony. Edit -: Turn it on a lathe.
  10. Hi Bob. Have a read through this article. http://hnsa.org/doc/luce/part4.htm This is page 4. And you can access all the pages. A lot of interesting reading. Regards Antony.
  11. Hi. Another reference from The construction and fitting of the sailing man of war 1650-1850 "The bottom planking, This was generally wrought oak, to a width of between 9in and 12in." Regards Antony.
  12. Hello Shihawk. On the full size ship according to The Anatony of The Ship. Page 50 "Planking was put on in as long lengths as possible-- or rather, obtainable. The Width was usually 12 in. And the thickness of the bottom plank in first -rate ships was 5 or 6 in." I will leave the calculations to u. Regards Antony
  13. Hi Sygreen. Welcom to MSW. Have a read here on starting a build log. http://modelshipworld.com/index.php?/topic/53-before-you-post-your-build-log-please-read-this-starting-and-naming-your-build-log/ That's all the information you need to start your build log. As far as tools .. As others have said.. Keep it basic.. Quality is important. Knife. Razor saw . Mitre block to keep your cuts square. Cutting mat.(Large) Sand paper. Small files. A good light. Tweezers. Best of luck. Regards Antony.
  14. Hello Doris. Like I said in my last post.. Top of the Masterclass. They are better than the ones I turned in a lathe You are so skilled. Is there anything you cannot make... I don't think so Regards Antony.
  15. Hi Remco. Just catching up on your build of the Kingfisher. Stunning workmanship and skill. Regards Antony.
  16. Happy birthday m8 50 today .dont look a day over 25 Regards Antony.
  17. Hello Alexandru. Skilled at wood... Skilled at metal.. And the list grows everytime I read your log. Excellent build with so much detail being as standard Regards Antony.
  18. Hi E&T. Major progress since I last looked in. As always your jointing is perfect and precise. It always amasses me the endless research that you do and attention to the smallest details. Looking forward to the next update already Regards Antony.
  19. Hi Mij. Wow looking real good. The planking really shows off the beautiful shape and contours. Have already put this build on a to do list but I will only work on one ship at a time. Is there any carving to de done on the ship ? Regards Antony.
  20. Hi Doris. Truly excellent work on everything. Nothing is less than 100% You are outstanding in your class of modeling. Is it possible to cast the guns using the cast metal one as a master ? Using blended paper and clay with PVA glue. Have seen this done a long time ago but cannot find where on the net. Regards Antony.
  21. Hi Rusty. Very nice work on the mortar. Looks spot on Not the easy to duplicate something on a lathe.. Start stop,,check,,start stop,, check. Measuring stick to hand. If using same tool you can always stops for each end of cut. Between the headstock and the saddle. Can do a drawing if wanted I have a digital readout on my slides so was not to hard. Carriages look excellent .. I have made my carriages with two types of timber. Regards Antony.
  22. Hi Donanic. That's what I thought but the post below says that Deagostini also do the Pearl. I have orderd the Hatchttepartworks mags.And Yes Chris Watton did the designing. Regards Antony.
  23. Hi Steve. The MDF... What thickness are they using ? I have cleared the space in the spare bedroom and getting everything ready for the start. Did not know DeAGOSTONI did the Pearl. Can't find the link. Any chance of the link please. Many thanks Antony.
  24. Hello Alan. A interesting scratch build. Love your approach to the issues you faced. And the reasoning on selection. I have tried Solidworks and struggled with the concept and learning. Only ever disigned on good old film. Keep up the excellent work. Regards Antony.
