gjdale
Everything posted by gjdale
  1. Much the same getting them here Downunda Alan, only more to do with postage costs in our case. But I will tell you this - you will be singing the praises of these machines long after you have forgotten the cost to import them!
  2. Thank you Gary. I’m in awe of your Auto Repair Shop Diorama!
  3. Nice start Tom. Re your query on setting the angle for the Byrnes saw, could you use a sliding bevel for this purpose? I’m thinking draw a line on piece of scrap ply or MDF (or any other wood) using a protractor to get the desired angle, then set the sliding bevel to that line, then place the sliding bevel on the sliding table of the Byrnes saw with the stock edge against the rear fence, and the blade extending out to the angle bar. I’m sure this sounds a lot more complicated than it is in practice, but in my mind it works!
  4. Sounds interesting Tom - I’ll follow along for the ride.
  5. Looks fantastic Chuck. I do have one question regarding the deck planking. I may be completely wrong on this and please tell me if I am. Looking at the planking on either side of the forecastle (ie the outer planking), the inboard one of these planks on either side appears to end in a point. My understanding was that this situation was to be avoided and that therefore the forward end of these planks would be shaped similar to the ones outboard of them (if that makes sense)?
  6. Hmmmm…….can I persuade you to re-think this Kevin? A few hours spent now fixing the problem would be well invested…….. I’d hate to think that not fixing this now might cause the build to hit a wall later on.
  7. If you want to use the draw plate method Floyd, I’d suggest leaving the stock longer while passing through the draw plate and then cutting to length later - that way you can discard any damaged ends from gripping with pliers.
  8. Thank you Chuck - very kind of you to say so. I’m still waiting on a reply from Model Expo - a week after sending my email to them. I have had an email from them every single day telling me all about their sales - just not a word even acknowledging my email to them. I know people here rave about M.E.’s excellent Customer Service, but from where I sit, I ain’t seein’ it. I did get an immediate response (within 24 hours) from Ken Foran (the kit designer), who I copied on my email to M.E., and have since exchanged further correspondence with him - such a gentleman as well as being an awesome modeller. I just wish M.E. would do me the courtesy of at least an acknowledgement - if you can spam we with junk mail on a daily basis, at least acknowledge when I write to you about problems with your quality control. In the meantime, I have received my third party sourced plastic rod so have been able to complete the Boiler Water Level sight gauge. No pics at the moment, but may post an update pic on the weekend as I have some new photographic lights I want to test out.
  9. I’ve always understood that LoS was for use with Copper, not Brass. For Copper I use LoS in a gel form and just put a little in small pallette and add some water next to it. I then use a paint brush dipped in the solution where the water and LoS gel are meeting and rib it onto the part. It works extremely well. For Brass you need one of the Selenium based solutions such as Birchwood Casey Brass Black. The other one that I’ve used successfully with Brass is Jax Pewter Black - gives more of a gun metal finish than black, but very easy to use. Again, I’ve found that rubbing it on with a paint brush works better than dipping the part.
  10. Floyd, Here's a picture from my log showing the shaping of the oar blades. They both taper in thickness as they proceed from inboard to outboard and also have a very slight curve. The tapers/curves are fairly subtle but they make a big difference to the finished look.
  11. Hey Bug! Great to see you back my friend. I look forward to following your next build.
  12. Looking good Floyd. Shaping the oar blades is easier than you might first think. I achieved this with some soft curved sanding blocks but you could do the same thing by just rolling some sandpaper into a sort of tube to provide a curved but not rigid sanding surface.
  13. Thanks Bob and Kurt, I copied Ken Foran on the email I sent to Model Expo yesterday and have had a reply already from him, confirming that some of the early kits did ship with the thicker walls - so I guess that confirms my suspicion (I can’t actually do a check measurement now that everything is built). Wish I’d done some extra research to discover this before I started building - I might have been able to get a replacement for the boiler walls. Thanks also Kurt for you reply to my PM query and your advice, which aligns very much with Wefalck’s observations above.
  14. Thanks Wefalck for that insight. I think it must be the latter (pressure hose) that is meant to be simulated in this kit. If you look at the box art picture in the very first post, it shows the hoses flattened (two per side).
  15. Thanks Mark. I've just finished writing up a document with all of my observations on errors with parts and/or instructions and have forwarded that off to Model Expo. I've asked for a replacement for the hose material, so I'll see what they come back with. And thanks Egilman for the link - some interesting discussion there and some food for thought about alternative material. Will wait and see what Model Expo have to say before deciding on the way forward.
  16. A number of small tasks remain to bring the model to completion. Finishing Touches…..almost First up was the installation of the brake pedal and spring mechanism. The spring joins the brake pedal to the seat. The other end of the brake pedal slips over the crossover bar that passes through the bottom of the water box. Once this is in place, the End Caps are added to either side of the crossover bar. Then the forward Hose Brackets are added, with the lower ends (complete with faux bolts) attached to the forward end of the water box and aligned with its front edge. The next task is to prepare the Head Lamp and Hand Lamp Lenses. These are provided as laser cut clear plastic pieces – four large round ones for the Head Lamp and one smaller round one and two rectangular ones for each of the two Hand Lamps. These all need to be shaped by adding a bevel to the outer edge of all the round lenses and shaping the rectangular lenses to match the contour of the sides of the Hand Lamps. My weapon of choice for this task was a series of sanding sticks. I recently discovered this product from Ultimate Modelling Products called “Thinny Sticks” and they are really good. The have a hard centre core with a softer foam on either side and then the sanding grit on top of that. They also have a shape that provides for a wider end for general work and a thinner end for smaller spaces. I find the shape to particularly good ergonomically too. Each stick has the same grit on both sides and the centre core is colour coded so it’s pretty hard to get mixed up as to which grit you are using. Having used them throughout this build, I can highly recommend them. The grits below are 240 / 400 / 800/ 1200 and then the larger one is a double-sided buffing stick, again colour coded for 3,000 and 12,000. The buffing sticks also come in the same size as the Thinny Sticks. Working through these grits on both the Britannia Metal and the clear plastic, I was able to achieve a mirror finish. Here are the round lenses showing on the right after initial shaping with 240 grit and on the left after final buffing. I didn’t feel the need to go as far as polishing compound. The camera doesn’t do the final product justice! And here are the rectangular lenses Two untouched lenses on the left, a shaped lens and then a finished lens on the right. The Head Lamp lenses were then inserted into the Head Lamp (I used aircraft canopy glue for this to avoid fogging caused by CA), and the Head Lamp epoxied in place on top of the Large Expansion Tank. The Large Expansion Tank was then epoxied in place on its supporting bracket. (The whip holder and whip were also added around this time). And here are the Hand Lamps temporarily installed. They won’t be fixed in place until the model is finally completed. The Spark Arrestor was then added to the Smoke Stack Section and the Smoke Stack Top added to that. The Boiler Top was then added to the Boiler Cap Ring: And the Smoke Stack assembly placed atop that: An almost final task was to add the tires. These are provided as laser cut gasket strips. After cutting the free from the carrier sheet, they only need a light swipe with a 240 grit Thinny Stick to remove the remains of the connecting nubs and then gluing in place around the rims of each wheel. The wheels were removed one at a time for this and the task proved much easier than I first imagined it would be. Once the wheels were replaced, the hub caps were added. At this point, I discovered yet another disappointing quality control issue with the provided kit material – the Fire Hoses. These are supposed to be provided in the form of tubular shoelaces. The idea is that the end of the shoelace is opened up to insert the Hose Nozzles before shaping the hoses and attaching them to the model. A neat idea, except that the kit provided shoelaces are not tubular – they are flat, with nothing to open up for the nozzles. This is another of those extremely frustrating and totally unnecessary errors on the part of Model Expo. I now can’t finish the model until I source some sort of suitable replacement, either from Model Expo or elsewhere. I’m also still waiting on the delivery of the part I need to complete the Boiler Water Level Gauge – held up in the postal system at the moment. Other than these two items, the model is complete. I can do nothing now except wait for replacement parts to finish this off. In the meantime, here are some overview pics. I’ll save the final “glam” shots until the model is finally complete. I'll be back when I have some more finishing touches.....
  17. Wefalck, If you follow this link, http://www.scalemotorcars.com/forum/horse-drawn-vehicles/57939-article-1-12-scale-1869-allerton-steam-pumper.html it will take you to Ken’s build of the prototype in brass. Within that log are many pictures of the original, which is in a museum very near to Ken’s home. Towards the end of that log, he shows a test build of the production parts that were cast from his original. In reviewing that log, I saw at the end that a couple of people had found some of the same issues I have had with the kit. Prime among them was forming the boiler walls. Apparently the design was changed and the wall thickness halved - I think I must have an early production kit though with the thicker walls (I did buy this kit as soon as it was released back in 2014).
  18. Apparently not Wefalck. As I mentioned in an earlier post, I believe that the kit designer (Ken Foran) was very faithful to the original, to which he had access.
  19. Another successful day at the “Fire Station” today, with no major issues encountered - for a change! 😊 First up today was to add the Steam Regulator. There was some fettling to do to fit this as the shaft that goes to the Boiler is deliberately left long and needs to be filed back to make a snug fit against the Boiler wall. The Adjustment Arm (on the right in the picture below) is attached to the Adjustment Arm Link (which was installed way back when the Flywheel assembly was added to the Main Frame) with a 00-90 Bolt and Nut. Some dexterity challenges again, but no major drama. Now we start to fill in all those holes in the Boiler Wall, starting with the Rear Boiler Wall. First up, the Boiler Grab Bar: Next is the engraved Boiler Shield and the Brackets for the upper end of the Hose Nozzles. The Nozzles are now fitted. And that completes the Rear Boiler Wall. Now we continue with the Frame Parts, starting with the Water Return Pipes. There is one of these on each side. They are indexed into the lower hole in the side of the manifold, while the other end is simply glued to the face of the Boiler wall. Now the Flywheel Arm and Links are added. Again, there are two of these, and each is comprised of two parts that index together before being glued using the locating pins – one end to the Flywheel shaft, the other to the upper hole in the side of the manifold. I departed a little from the sequence in the instruction manual, only because I thought that access might be easier for some of the parts. So next up, I fitted the Pressure Release Valve – it goes very close to the Steam Regulator. Then it was the Rear Hose Brackets and the Hand Lamp Holders: A series of four Valves are now added, taking care to align the angle of the drain spouts (pointing down and to the left). And then the Boiler Pressure Gauge is added: The Steam Whistle is next: And then the Frame to Boiler Braces. It’s a little hard to see in this photo but the Brace is the diagonal Red bar going from top right of the picture where it attaches to the Frame, to the bottom left where it attaches to the Boiler wall. We now move our attention forward and install the Small Expansion Tank: And then we add the Large Expansion Tank Support and the Seat. These are a little tricky as the Support is indexed into a hole in the Seat and the Seat Legs index into holes in the front of the Water Box. Because these parts will carry the weight of the Large Expansion Tank, they are glued with 5-min epoxy. And finally, here is an overall shot of where we are at as of close of play today. Still a way to go yet, but we are closing in on the finish line.
