Ian_Grant
Everything posted by Ian_Grant
  1. Bill, she's looking very impressive! Good work, and keep going! 😉
  2. Looking again at your beautiful pics, it occurs to me that the ESC fan could maybe use some duct for outside air on a hot day. Does the funnel actually ventilate the interior cavity? Note, I have zero experience with ESCs' as all my electric boats were made decades ago; simply circulating the interior air may be enough. You could check the ambient air max temp spec for the ESC and decide. Looking forward to video of the maiden voyage! Great work!
  3. Added the upper pivoting oar bar to the starboard oar beam. She can now be seen in all her glory as an 86-oared vessel! Since I'm now using all the oar ports I fished the lamp cord I'm using for the battery connection through the bilges using the holes I had made in the bulkheads. Too late today for a sea trial. In any case I ran into more 9V problems. I had bought a 4-pack of 9V snap connectors with pigtail leads from our local electronic components store. So far I've had occasion to unplug a 9V battery twice; both times the negative terminal on the connector, instead of unplugging from the battery terminal, tore through the connector's flimsy plastic. What a bunch of made-in-China crap! Opening it up I found the connector terminal has almost no flange inside - how do they expect it to pull out of the tight battery terminals? 😠 So once again I'll need to re-solder the jack onto another connector for the purposes of the next trial. What to do next? I can find all kinds of these things, some as cheap as 65 cents (who can source parts, make the product, ship it, and have it sold at retail for 65 cents?). No one with any quality product. 😒 I want to see and handle any replacement candidate before buying but there's nothing else local. I'll even consider getting one of those little boxes that holds six AAA batteries, if I have the space. Hoping to trial her tomorrow, if my son is around to shoot a video.
  4. Yes it was a very entertaining build log, but wait - there's more! Since you seem unsure about blue-footed boobies, here is a short video my wife shot on our Galapagos trip featuring them doing their mating dance. On this walk, we were surrounded by pairs dancing and sitting on eggs, sometimes right on the designated walking trail. The voice you hear is Raul, our Ecuadorean naturalist and park ranger, who accompanied us on the boat the entire trip and led all the walks/snorkels/zodiac rides. By the way, many of the local souvenir places sold tee-shirts with "I Love Boobies" on the chest but I couldn't see myself walking around in one in public. Too many questions...... Looking forward to your longhorn transport ship, Glen!!
  5. I think what it boils down to, reading Anderson, is that 0.5 is a good ratio if the topsails had no reefs; 0.4 is better if the topsails had reefs (and hence the topmast got longer). What with my personal confusion with three Soleil Royales' in different eras I have no idea if this ship kit should have reefs. Perhaps Marc or John know when topsail reefs came to be with respect to the purported date of this "model" ship. I'm taking notes for my eventual build....
  6. This rigging detail in this scale is incredible .... don't know how you do it ....
  7. The book is "The Anatomy of Nelson's Ships" by C. Nepean Longridge. But it sounds like you have it since you mention the mainsheet block bracket ...??
  8. John, your log is fascinating thus far! I love your colour scheme. I see you moved the waterline up to above the bottom edge of the main wale which is what I plan to do. Would they really have had the gammoning going into the water though? I had it in my mind to move the gammoning slots up a bit. Also. I think you have changed the "angle of attack", as it were, of the waterline? I seem to recall that if I kept her slightly stern-deep as does the Heller w/l while raising it to the wale, the decorative bits at the bottom of the 1/4 galleries ended up touching the water which bothered me too. It seems to me that down-by-the-stern is probably accurate, to have some lateral resistance in the u/w hull profile to compensate for the huge windage on the towering stern or she would need constant windward helm. On the other hand the sail plan might be designed to help compensate. I haven't really studied my model too much; it's been just sitting in my stash for a few years. I have two other build to finish first.
  9. Eager to see your finished pics Glen. That water looks fantastic! This build will be hard to top.....
  10. Well I have all 42 upper oars made and varnished, and 21 of them mounted on the port side. It's looking good ..... but .... when I added 1/2" to the upper oar shaft length in order for their blades to lie beyond those of the lower oars, I inadvertently created a problem. The oar ports have to be elongated to allow the shafts to sweep and I mentioned way back there is some play. When I row the oars just on the bench, sometimes a few of the lower blades cross under an adjacent upper shaft at some point in the cycle then there is a clicking noise as they clash and are corrected. The real solution is to redo the loom ends of the upper oars, removing the extra 1/2" so there is some blade overlap which should stop the lower blades from crossing under. Or perhaps it will be ok when they are all in actual water ..... will do the starboard side then have Sea Trial #3. Soon I hope. Here are a couple of pics. I changed the mechanism design to use just three hex metal standoffs to support the pivoting beam for the upper oars, as opposed to the solid wood with drilled holes I had before. The holes were intended to provide access to the mounting screws for the lower oars but it was too difficult to get to the screws in, without dropping a lot of them into the bilge, when adding the oars. As can be seen in the 2nd pic the access now is much better. See the increased size of the blades of the upper oars. They look lighter than the lower blades because they're freshly cut cherry; over time they will darken as the older blades have done.
  11. Bill, in your second photo above it looks like the t'gallant mast maybe could be struck, or nearly so, if the topmast had normal trestle trees instead of that "cone" shape going all the way around the mast. The cross trees themselves look too far apart to me. Normally the middle one would be pressed against the front of the topmast and the aft one would be pressed against the back of the topmast (as Anderson says too, pg50) which would place them at little more than half the distance apart. And I agree they are too long. You can't do anything about the first issue, but I would cut them shorter as Marc has already discussed. Looking forward to working on my SR ......not really 🫤 But I'm taking notes for the future.........🤙
  12. Regarding the cross trees, when I first looked through my SR instructions I wondered if it was yet another "Hellerism". The reason they were constructed as shown by Anderson was so the t'gallant mast could be "struck" ie lowered vertically through the square hole between the first and second crosstrees, just as topmasts are dropped through the lower mast tops. Heller's construction leaves no such cavity.
  13. ...... which is itself derived from the ship's beam (Anderson, Chapter 1 part III, pg 15). Sorry to "quote" you, Marc. 😉
  14. Hi Bill; in short, yes. Anderson has some ratios for English and foreign ships at the start of Chapter III. Bear in mind that when he says a topmast is x/y as long as its lower mast, he means the entire lower mast to the step in the keel. It would be interesting to compare his values to the stock Heller parts. At any rate, he says fore and main t'gallant masts varied from 0.4 of the topmast, to 0.5, then back to 0.4 from 1620 to 1670 or so; any value in that range should be satisfactory.
  15. Begging your pardon of course, but my thought would be to buy a wheel ... 😉
  16. It may be best to not try to hinge the rudder - instead, have the rudder shaft pass through a brass tube epoxied into the hull and have a way to support the bottom of the rudder: eg a small plate attached to the keel, extending back under the rudder with a hole for the bottom end of the rudder shaft; or make it with a pin which extends up into a hollow rudder shaft. Just two ideas to inspire thought.......
  17. Looks good. My only comment is that the rudder linkage is much farther out from the centre of the servo arm than from the rudder shaft. The servo will hardly have to move to give rudder hard over, which means it would be very "twitchy" when moving the "stick" on the transmitter. Moving the link towards the servo shaft would give a better feel on the "stick", and give more torque from the servo though more is probably not needed. Also not sure why the rudder horn holes are oval....🤔 Finally, you would get a smoother action if you employ "quick links" rather than bending the wire. https://www.greathobbies.com/productinfo/?prod_id=DUB109
  18. Good luck; I'm interested to see how this works...............
  19. John, I am really enjoying your historical analysis and will follow to the end, of course. I hope to start my SR in about two years from now, God willing, and am very interested in where you go from here. Thanks for posting!!
  20. Just yesterday in another log someone replied to the same question. His solution is to pass a styrene rod (like Evergreen) through the tube, form the bend during which the styrene prevents kinking, then heat the tube with a propane torch to melt the styrene out. Apparently he does this fairly often. I would do the heating outside in the fresh air though.
  21. Started production on 42 upper tier oars plus spares. I decided I wanted the blades 1/8" wider and 1/8" longer for good measure. Thinking about modifying the existing oars, I decided it would be easiest to trim their edges back to flat then add u-shaped additional wood, rather than messing around with the glued shaft/blade joints or scarfing new ends on. Further it would add some pizzazz to make the additional wood a contrast to the cherry ie use maple. Given all this I decided to make the upper oars with the wood contrast too, only in reverse to add yet more pizzazz. The shafts are 1/2" longer to decrease overlap between the blades from the two tiers. Here we have the notched shafts and the formed blades. Making oars - deja vu all over again....
  22. Steven, you work so quickly, puts my scratch effort to shame. And your true-to-the-ship framing is wonderful! There are soldering irons which allow you to set the tip temperature, but they're more expensive.
