Everything posted by RGL
Ok, the whole mast tapers for the cheeks, with the green bit being full circumference. I did it on the lathe. I filed the sides above the green for the cheeks so they are fairly flush. The woulding was filed into the cheeks and used ratan for the hoops. The metal bands were just cut to appear as if they go under.
The "leather" liner is copper tape painter brown and the netting is commercial from Cornwall. I was going to try and hand sew it but it would have looked like crap at this scale. I did about 3 versions to get it right whilst I was watching the 5th test.
- 319 replies
Bowspit cap, and horses and netting. As I said to slog I attached the blocks first to the cap. I've been dreading this part for years, but it came off quite easily really, only a days work in it for the netting.
- 319 replies
Last post of the year I promise! Bit of serendipity today as I actually read the plans and looked at the replica and the Topgallant shrouds have no ratlines! I'm finished with them! Shrouds and backstays in place. Lots of work on the bowsprit before I can add the last stay. next year it is.
- 319 replies
Probably a bit too tight as it does kink a bit. The first shroud needs to be served all the way down to the deadeye to stop wear on the sail. I didn't fix my tops until I'd finished the shrouds as it let my fat fingers in to seize them. That being said, I never did get the deadeyes aligned properly but "meh"! At 1/64 some things just won't matter as there whole rigging thing makes it look so busy. Janos Caroline is just so perfect and neat it makes mine look like the cat did it. I've almost finished to top gallants so only a few ratlines to go.
- 517 replies
- Endeavour
- Artesania Latina
Looking good mate, I also love your tool box, I reckon you spent hours on that. Let the pain begin for shrouds and ratlines!
- 517 replies
- Endeavour
- Artesania Latina
There is a sense of achievement finally fitting the topgallants. The topgallant futtock shrouds and thimbles were attached first which gets really fiddly seizing them properly to the Topmast shrouds. Strangely, the masts ended up aligned! 12 shrouds and 4 backstays to go. Finally given the Endeavour's strong ties to Australia, a boxing day BBQ is always on the cards, so the BBQ photo. Hope you all had a happy Christmas.
- 319 replies
Something completely different! I like it!
- 113 replies
- bohuslän
- nordic class boats
Topmast blocks added. The jeer blocks slung under the shrouds required me to make eyelets and sling them. It looks really busy (it is) and because of the close ups looks somewhat out of scale, but by the time the topgallant shrouds are added and eventually the yards, the tension of the blocks should look correct.
- 319 replies
The topmast blocks. Does not seem much of an update, but it's taken a week of hard slog (sorry Capt'n) between work commitments to get these done. I've placed them on a blown up image of the AOTS Endeavour topmast to show placement. As you can see each block has a served rope, so I've shown my little serving machine. Very expensive. Really quick too, I can get about a foot of rope done in in 5 minutes. The Jeer blocks will need to go under the shrouds then strapped above the ropes on the mast, thus the open eyelet. My next block of days off (no pun intended) I can fit them to the masts.
- 319 replies
Thankyou, I'm afraid it's not that good, I can see every sin. Our cat chewed one of the bumpkins fraying one of the stays for it so I now live in fear.
- 319 replies
Mizzen topmast stays. This was the most difficult as the thimble that goes on the end of the stay had to be put on whilst it was rigged. fat fingers and backstays do not mix. Now to have some fun and rig the blocks under and over the shrouds.
- 319 replies
- 319 replies
