Everything posted by bruce d
Many thanks Lester, may take you up on that 😊. Just a bit of advice: to keep the scalliwags out of your life I suggest you edit out your email address, there is a really good PM function on MSW.
- 128 replies
- model shipways
- new bedford whaleboat
Me neither, but ... I seldom hear of duck hunting without thinking of a Dornier Libelle, the ultimate 'duck blind'. This 1920's aircraft actually included in it's sales blurb that the well-heeled owner could land it on his favorite lake, taxi to a shore and fold the wings: then, using the wings as shelter take up position on the sponsons and wait for the ducks to arrive. http://www.histaviation.com/Dornier_Do_Libelle.html I always imagine rich German arms dealers having a boozy lunch from a wicker hamper with their shotguns while sitting either side of the cockpit. BTW, I am enjoying your canoe build 😁
Welcome to MSW.
They are absurdly cheap on fleabay from China. I got one (didn't need it but had to look) and there is absolutely nothing wrong with what arrived in the post. This image is used by several sellers on the site: It is iron so store it somewhere dry. I have several ways to index/divide in my shop and have to admit this is as good as some much more expensive methods. Cost about £4 = $US 5.
- 123 replies
- Model Shipways
- Pinnace
Hello Chris, Nice job, you really captured the look of a Bermuda boat. Also, a reminder that there is no need to rush! Bruce
- 144 replies
- corsair
- bermuda boat
Joinery
bruce d replied to Maury S's topic in Building, Framing, Planking and plating a ships hull and deck
Wow. -
Just looked back at what I wrote. Seemed a bit harsh, sorry about that. I haven't really found anything that says what happens to the ballast on commercial ships except (I think) a couple of times in the contracts. IIRC, one of the contracts just said the slate ballast 'to be set fair on fir and stayed' which I took to mean placed on battens and wedged into place. Whether the slate was shaped or not wasn't mentioned. I didn't take notes so I can't call it up again but I am pretty sure it was a Colonial (Virginia?) craft mid 18th c.
The elephant in the room: this ship made it back to port because the copper sheathing held. Who knows how many other other ships that had been lost without trace had the same problem but a different outcome? The episode provided first hand evidence of what happened when ballast was treated in a sloppy manner and probably saved several other ships from the same fate. By the way Druxey, perhaps you can correct me but I do not believe the gazzilions of transports pressed or hired into naval service had automatic dockyard upgrades to install ceiling planks. So yeah, the purpose built warships followed the same general rules but the privateers and commercial craft were built to whatever contract the owner stipulated.
I have not found the answer but here is an example of why it is a good question: "Danger of Shingle Ballast. The following is to be added to the many instances of injury arising from the use of shingle ballast: - The Mysore, an Indian Ship of large dimensions and uncommon strength, lately, on her passage from Bengal to Bombay, sprung so serious a leak, that unremitting exertions at the pumps were for several weeks necessary to keep her afloat. On arriving at Bombay she was docked, when water was observed running through a part of the copper which covered the bottom sheathing abreast of the chess-tree, and the nails of the copper partly drawn. On removing some of the sheets, a hole was visible in the sheathing plank, which being taken off, the plank of the garboard streak on each side the keel was found to be quite cut through, and an aperture in them sufficiently large to admit a man's arm from the outside. On the timbers being cleared inside, this was discovered to have been occasioned by some round stones, nearly the size of a twelve-pound shot, having fallen betwixt the floor-timbers in this place, and by the constant motion of the Ship, perhaps from the time she was launched, had grooved their way through the garboard planks and sheathing, over the keel, which was likewise indented upwards of three inches, and through the two next bottom planks. As the stones were found in the timbers, and exactly fit the groove, and as several of the other floor-timbers had stones betwixt them, which had occasioned a similar effect, although not in an equal degree, no doubt can remain of their being the cause of the circumstance which had so nearly proved fatal to the Mysore; for, had the sheets of copper, of which the nails were partly drawn, fallen off, no exertion of the Officers and Crew could have saved the Ship. Naval Chronicle, Vol. iV (1801), p 270. "
Hello Jay and welcome to MSW from the UK. There is always room for another Cutty Sark, it is a good looking ship and a part of history. Glad to have you aboard, will we see a build log? Regards, Bruce
Hello Robin, welome to MSW from the UK.
Advice needed. How much rope do I need?
bruce d replied to bruce d's topic in Masting, rigging and sails
Grudgingly, I agree. But if there is a quality product available, I will at least try it. -
In view of the news from Syren, I realised that I have put off too long one an important question: I don't know how much rope I will need for the two scratch builds on the bench. As I expect there will be some changes in the supply chain I would like to get it right first time when ordering because there is no guarantee the same supplier will be able to send more if I need it. The first to get to the rigging stage will be Mediator, a 1/48th single masted merchant vessel. Since I have never rigged a model before it would be very easy for me to think I can get it right by measuring up the ropework I can see in the drawings. Maybe, but I suspect there has to be a better way. The second model, which will always be behind Mediator in progress, is a 1/40th scale Pickle. There is no build log yet and I will not start her rigging until Mediator is done and in a display case. Also, there are three small CAFModels that require some rigging. The plan was to order a bunch from Chuck in a month when I have done my sums but I have missed the boat. Now So here goes: is asking 'Your model looks a bit like mine will, how much rope did you use?' good enough? If not, what is the best way to estimate correctly the amount to order? Many thanks, Bruce
Hello Park Seungha and welcome to MSW. Your model looks very good, and the paint has very nice crisp lines. Please show us more. Regards, Bruce
Welcome aboard, hope to see what you choose to build.
Hello histprof1066 Welcome to MSW from the UK. That is a nice looking model.
Mustafa used them in this build: ... and most of the pictures of his process are on the first page. You will see he is after a particular look and uses tung oil for the finish. I found his treenails worth looking at because they are nice and crisp and then have a different appearance after his surface finish is applied. HTH Bruce
Hello desalgu and a warm welcome to MSW from the UK. Very nice looking model, look forward tro the build log.
Very nice work, it's got that 'working boat' feel all over it. Good job on the lettering, can I ask how you did it?
Artesenia Latina Virginia American Schooner
bruce d replied to Dougal Mack's topic in Wood ship model kits
Hello Dougal, I got a few hits by seraching 'Artesenia Latina Virginia', maybe you were using a different search key? Looks like you chose a good subject. Bruce -
Jose, welcome to MSW, glad to have you aboard. You are cleared for take off.
