Everything posted by bruce d
Mantua "blue painted" photo-etched brass
bruce d replied to Alexisgm97's topic in Metal Work, Soldering and Metal Fittings
Please let us know how it works out for you. -
B.E., I did a double-take when I saw those weights. You are fearless. Looking good ✔️
- 185 replies
- queen anne barge
- Syren Ship Model Company
Hello Graham and a warm welcome to MSW. It looks like there may have been a hiccup with your picture, nothing is visible. What is the kit? Since you got it 'some years ago' it is possible it has been updated so if you have the manufacturers model number from the box that might help also. Regards, Bruce
Nice job on the reversing gear. It all looks like a working piece of machinery. 👍
- 26 replies
- Model Shipways
- Picket Boat
Hello Gus, As Ron said they are legal. Also, they have good customer service. The owner is an enthusiast. HTH Bruce
Hello Alexis, The blue on the brass is left over from the etching process. It was called 'resist' and was the barrier between the etchant and the area of brass that was not to be etched. You may be able to remove it without sandpaper but it is not possible to be certain without knowing exactly which product they used. The blue film was able to 'resist' the powerful etchants so of course it does not just peel off. There are 'etch resist strippers' available for people who make their own printed circuit boards but there is no guarantee that these modern products will work on this old blue product. Very few of the old products are still used because they used aggressive, nasty chemicals so modern resist uses different strippers. Try cellulose thinners if you can, also the type of solvent used by plumbers to bond PVC tubing. If this doesn't work, I am afraid it is time to start sanding. Good luck! HTH Bruce -
Hello Tom, In case it affects your decision, she was sheathed with wood in the first part of her career when known as Bethia. She was then sold and renamed Bounty and refitted to prepare her for the breadfruit mission. She went straight to the refit after purchase. So, Bounty was coppered but during her time as Bethia she was not. HTH Bruce
My understanding is that the Carron company presented demonstrations of their new product and sought feedback. It had good selling points, such as lower crew requirement and faster rate of fire, and I recall nothing (it has been a while since I read up on it) concerning problems caused by recoil. Before long, Captains wanted this weapon on their vessels. Izzy, can you share the documentation that specifically relates to the Carron policy?
🎼 Always look on the bright side of life 🎼
Hi Mike, I got a 'log-in-required' message when I tried it.
- 238 replies
- sloop
- providence
Regarding the earlier point about hiding the identity of fireships, I believe one of Cochrane's legitimate complaints about the leadership on the night of the attack on Basque Roads was that the fireships were too far from the target. They were recognised by the French in time to react. See Clive in post#2. Clearly the element of surprise is lost if the fireship stands out either by appearance or actions.
Bomb ketches and gunboats used in Barbary Wars?
bruce d replied to Smile-n-Nod's topic in Nautical/Naval History
Bit late but ... https://collections.rmg.co.uk/collections/objects/85102.html This type of gunboat was still in use a few years later in the Barbary wars. Sorry, no book 🙁 -
Deck planking methods
bruce d replied to allanyed's topic in Building, Framing, Planking and plating a ships hull and deck
👍 Oh boy Allan, your timing is amazing. Thank you. I have nearly completed thawing out my 'on-hold-for-the -winter' build and planking is on my mind. I will judge whether my deck is a success or not by the 'invisibility factor' of where hatches, capstans etc. meet the planking. The goal is to avoid hatches and fixtures appearing to sit on top of the deck or look like they are sitting in a cavity cut out of the planks. Also, a symmetrical run of the planks. In other words, the same issues your post raises. I have a plan but am fully prepared to use the eraser so will be watching this thread. Couldn't find an emoji of someone rubbing their hands in anticipation, so thanks again. Bruce -
What were your first tools as a child?
bruce d replied to FlyingFish's topic in Modeling tools and Workshop Equipment
Left middle finger, age nine. Lesson not learned, did it again and again. Still do it. -
Hi all. Last week we cut down a healthy sycamore tree. I have set aside some good straight lengths (enough for six lifetimes) of varying diameters and the rest is seasoning for firewood. What is the best way to season the pieces I am keeping for modelmaking? Storage facilities are limited: I could put a couple of small lengths in the garage but the only place I have for the rest is under shelter outside. So, leave it as cut? Remove the bark? Or what? I have found contradictory instructions online and think the MSW collective experience will produce the best answer. Thanks in advance, Bruce
I suck ripping planks with my Byrnes saw
bruce d replied to bigcreekdad's topic in Modeling tools and Workshop Equipment
It would help a lot to know exactly how you are doing the cutting. What is the set up on the table, whether you are using the fence alone, have you checked the fence is square etc. It's a Byrnes. 👍 The answer is somewhere in the details ... -
Hello Ron, The Hyuda spec includes a variable speed 200w motor. This sounds like a good thing but what it doesn't mention is the drive system. Proxxon ads always boast of their toothed drive and the Hyuda doesn't mention any thing about this part of the saw. It might be a good idea to find out what drive the Hyuda offers, especially since it has a variable speed function. The only grumble I ever heard directly from a Proxxon FET owner was that it didn't have enough power. When I saw what he was trying to do I understood the problem. The FET is not a miniature sawmill for oak and ebony, so don't overload it. I may get another FET one day strictly to get the tilting blade feature which the Byrnes does not have. HTH Bruce
