Tigersteve
Posts posted by Tigersteve
  1. Behold the stern completed. When creating the windows, I did not cut the 1/16” framing tape down to 1/32”. At the time I did not think it would make much of a difference, but at this scale it does! After the windows were mounted on the ship I added 1/32” x 1/16” wood strips on the top and bottom to create a thinner reveal of the white tape around the windows. This helped.
    The knees were created in cherry as shown in the photo. As with many parts of the project, I figured the stern would be easy. I was proved wrong, as I had to make many adjustments to accomplish acceptable results.
    I am learning not to linger too long on a particular part of the project, only redoing things that look out of place or inconsistent with the rest of the ship.
    Steve
  2. I redid the metal rings around the gratings because they were loose and drilled the mast holes. Finally, the bulkhead template install is in progress. It’s not as easy as I thought. It took a couple of glue sessions to secure the first template. I’m making some supports so I can clamp down the next template properly.
    Steve
  3. A small update, but one worth posting for me. Back on track with the Mayflower build. It is full speed ahead as I work on the interior planking of the bulkhead templates and redo the metal work for the door handles. The first planks on the templates are basswood, as they will not be seen on the model. The remaining planks will be cherry.
    I had a small surgery in the last few months, but mainly I have been procrastinating on this metalwork. It’s good to be back. I ordered a cheap optivisor and some thin CA glue. Hopefully it will be easier to work with than the medium CA that I have.
    Steve
  4. You could easily charge at least $850 for this. I’m not sure what the wood cost is, but I’m sure it’s extensive. Shipping alone will be expensive. Those two chapters really give builders a solid foundation for a great model. People are paying for the quality of your design and kit. (Maybe Mike has a better opinion since he’s built many of your newer kits.)
    Steve
