Tigersteve
Everything posted by Tigersteve
  1. Looks good! Seems like a more relaxing build so far compared to the longboat. Steve
  2. Thanks for all the likes everyone. As most of you, I have ridiculously high standards for my work. That being said I really want to try to figure out a way to sand the inside planks where it's painted red to get a better finish. I'm just not sure if it's worth the effort. Especially when it might not be noticed after all the other inboard details are done. What do you guys think? Steve
  3. Wanted to give a quick update. I've been painting the cap rail and inside Tamiya flat red. The photo shows three coats. It's not as clean as I want yet so there's more sanding and paint ahead. I'm not thrilled with the brushes I am using so I will get some new ones before the next project. It's a tricky area to paint! Steve
  4. Annoying they would burn it right on the transom. I would attempt to make a new one. No extra wood in the kit that thickness? Maybe get some extra basswood from Michael's? Steve
  5. Yes- thank you. Trying to get an idea of what people are using brush-wise. Steve
  6. How's she coming along, Erik? Eagerly awaiting your progress as many others probably are too! Side note- excellent longboat build. I've also used to reference for my longboat build. Steve
  7. Excluding the windlass and a surprise! You have my attention. I hope your materials show up. Steve
  8. It is coming along nicely. I also just found your longboat build. Nicely done! Best of luck with the plank bending for this one. Hoping it goes smoothly for you and is a little easier than the longboat. I am following closely, as this is my next build as well. Steve
  9. The oars are coming along. I think you are right- more fine sanding should do the trick. Glad to see you back at this build. I'm currently doing some tests before I paint the cap rail on mine. Did you do any masking inboard before you painted or freehand? Steve
  10. It's looking good to me. Your planning will pay off I'm sure. In skimming through some of the manuals online for these kits I noticed they all seem very "cookie cutter"- at least from this kit's designer. I hope the plans are clear. I will keep following your build. Steve
  11. Applied the freezes and moulding strip below. I advise that you apply the moulding strips first as it was tricky to keep the freezes pristine. I applied one coat natural stain to the moulding the night before. I left the transom freeze off. I thought the model looked better without. At least I think mine does. Painting the cap rail is next. Steve
  12. Nirvana- I'm enjoying it a lot more now that the planking is done. It's an extremely challenging kit! Gunther- I think it does add character. Originally I selected all similar colored planks but as I started to break the planks when bending, the wood became more varied. I'm still pretty happy with it. It's smoother than it looks. Sanded with 220 then 320 then 400 sandpaper. Thank you both for the kind words. It is much appreciated! Steve
  13. Ok fellow builders- one coat of pre-stain and then one coat of natural stain. Cut out the freezes. What a pain! I will apply these after I apply WOP. I think I will paint the cap rail after the WOP is applied and freezes are on along w the moulding strip that needs to be applied. Special thanks to the stain for highlighting the imperfections! Steve
  14. Thank you, everyone. Yes I did read about the hairspray trick. Did some research though and was also prepared to purchase proper fixative because there's some debate on the long term effects of hairspray. I'm giving Minwax Polycrylic clear satin a try since I have it. Yes- I have many freezes now. Applied two coats. Gives a bit of a sheen but it looks protected. Steve
  15. Looks great, Elijah. Take your time with it like others have said. -Steve
  16. I get it. Thanks for the clarification. There's always your Syren build to go back to. Lol
  17. Mike, very clean work as always. Your longboat build is also one of my go to logs for my longboat build in progress. On another note- I am also waiting on the completion of your Mayflower! It's the cleanest log on that ship I've found. I plan Mayflower as my first ship build. After Chuck's longboat and pinnace. -Steve
