Everything posted by Hubac's Historian
Mark - beautiful progress, as always. I like your approach to constructing the quarters. You are so good at getting the complex geometry right. As you work your way up the quarters, you might find some useful ideas in Siggi’s Tiger build, beginning with post #1003, page 34. Like you, Siggi is brilliant with the smallest details:
Thank you all for your likes and kind comments. As was the case with the chains, I’ve been experimenting and taking my first baby steps with rigging techniques. Specifically, I’ve been learning to strop 2mm single blocks for my main deck haul-out tackles. As I mentioned in an earlier post, I will not use scale rope for these, as the line gauge is fine enough to get away with much cheaper thread, of which I have an abundant supply. Abundance is what I have needed, here, because I have tried a number of different approaches to both minimize any space between the hook and block, while also stropping the block in a neat and tidy fashion. I was really struggling on that front. And, that’s when I decided to consult with two of my favorite plastics builders: Michael D and Daniel Fischer. Both are outstanding at creating very correct looking rig, using ingenious technique in relatively small scales. I need 24 of these single block tackles for the visible guns that will be rigged. I had made 9 that were variously unsatisfactory. Dan’s Victory log is particularly illustrative of small things I could do to achieve better results. Initially, I was using two overhand knots (alternating from one side to the other), with the finest linen thread I posses, in order to strop the hooks. With a spot of CA, and the help of a simple pin jig to hold the block, I’d center the hook on the block and smooth the line into the groove until the CA set. Then, I’d use the same linen thread and an alternating overhand knot technique to seize below the block. A spot of CA seals the seizing and I nip the excess clean. This was my best result using this technique: It’s okay, but I wasn’t really happy with it. From Daniel, I realized I could secure the hook with one overhand knot and then secure at the top of the block, as before. Now, while Dan often employs the alternating knot technique for simple seizings, he often uses fly-tying thread which, I am given to understand, flattens out as you wrap it. Dan’s simple seizings look great, and I think the flattening aspect of this type of line is the key. So with those tips in mind, I tried again. Using a binder clip to keep the strop ends taught, I found that I could do a single overhand knot close to the block, followed by six conventional wraps to get a seizing that looked proportional: Now, I will be buying a set of alligator hands, as Dan Pariser previously suggested. I will also pick up some fly-tying line to experiment with. For the time being, though, this is both manageable and repeatable. Here is a side by side comparison: Now that I have an approach that I like, I dipped all of the previous tackles in acetone, so that I could salvage my blocks and hooks: Any remaining glue residue brushes away with an old tooth brush. Well, it isn’t much, but it is progress of a sort and I feel good about it. Thank you all for looking in!
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Daniel posted this link in his Victory log of the Texel Roads diorama. Many wonderfully detailed photos of ships being worked. What is very evident to me are the design parallels between these early Dutch ships of the 1660’s and their French counterparts, often designed by naval architects with Dutch training backgrounds, like Laurent Hubac: https://www.modellmarine.de/index.php/fotogalerien/178-/1624-die-reede-von-texel-teil-2 The head structure, the pronounced tumblehome, steep sheer, broad sterns - it is all there. The draft and underwater lines would of course be different, in order to navigate the more shallow Dutch coastal waterways.
- 419 replies
- soleil royal
- Heller
Hi Bill - what Shipaholic has shown, here, is essentially what I was talking about, it’s just set-up above the foredeck. I would go with that
What you have done to raise the steve and create the appearance of piercing the fore deck looks more plausible than a butt-ended bowsprit nestled between the fore bitts. The end of a bowsprit, in actual practice for sea-going ships, usually had a square tenon that keys into a heavy balk of timber (itself, secured between the lower legs of the fore bitts), before the foremast. With your present arrangement, I can at least believe something like that is happening below deck.
The pictures Ian posted appear to be of a second steel-hull replica. Various aspects of this design appear to be simplified. The wooden replica, I believe, is more authentically constructed from the original plans. I am having trouble finding good pics of this replica’s fore deck, but maybe you can find some answers here:
Touch-ups on this figure still need to happen, but she’s securely pinned and cemented in-place. Given that this figure represents The Americas, I thought her garb should be gold accented greens and earth tones. She’s wearing a palm frond skirt and crown. Weirdly, while the brown enamel wash that I use is still perfectly fine, the grey wash pigment seems to have cured in the jar, despite there being a generous amount of solvent present. I mixed this for a long time, and it looked good after wiping off the excess. However, long after it had dried, the surface film appears to be reactive with my finger oils, creating an ugly, dirty/crusty appearance. Fortunately, this wiped off pretty easily with a Q-tip. After touchups of the white, I’ll have to experiment with the Tamiya grey and solvent that I have in my stash. And with the arm in-place: On the whole, I’m very happy with how this all turned out. I consider this surgery a success! Thank you all for looking-in.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Gentlemen, thank you all for the likes and the kind comments. Kevin, I will say that all of the yellow ocher applied to this model really improved my steadiness because I thinned the paint enough to ensure no brush strokes, so everything had to be gone over 4-5 times for color saturation. After a while, you get really good at it. Per your request: Dan, if only I could make money on my talents. I am far too slow to make that a reality, though. I will be picking up a set of the alligator hands, though. They seem indispensable for the hobby.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Thank you, Bill. It is all just time spent. There is almost always some glue squeeze out. I always carefully scrape it away. Recently, in fact, a little CA crept under my masking tape and spoiled a bit of my ventre-de-biche color along the lower two decks of artillery. This really sucks when this area becomes blemished because it is very difficult to match the color and tone of the repair to the surrounding area. It came out okay. As for wavy lines - I have a steady hand. However, there have been countless rounds of re-touching, as my eye picks out various things that could be improved upon. All of it is just time. I have found that I literally get out of it what I put into it, effort-wise. I appreciate the thought, though.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
After quite a loooong time, I have finally completed the channel and backstay deadeye chains. I still have a little black touch-up to do, but most of that is looking pretty ship-shape. I’m quite relieved to be past that. My sweet spot on this build has been modifying and manipulating the posture of the large figure carvings. I wanted to get back to doing a little of the work that excites me, and the figures of The Americas and Africa are the final pieces of the ornamental program that I have yet to complete. I have no choice, but to carve Africa from scratch, as Berain’s drawn figure is in such a radically different posture than the kit’s pose. I’ve roughed-out a blank in cherry, which is quite hard, but will hold fine detail in a small scale. Depending upon the quality of the finished carving, and whether or not I find it necessary to graft the plastic head onto the wooden body, I may simply apply Danish Oil to the carving as a call-out to the modification work that was done to the model. On the port side, though, for quite a while I’ve been mulling over the potential for adapting The Americas figure. After all, the kit sculpture is far superior to whatever I could muster from scratch. The main problem is that the stock figure is far too tall to fit within my reduced stern height. As a refresher: at the start of the project, I cut the top sheer-step away (1/4”), but replaced it by half with a low, long sheer cap-railing (1/8” +), and I lowered the side lantern boxes (1/4”), so that their tops were flush with the sheer-railing. This nets out to about 3/8” overall height reduction of the stern. That was how I could ensure that the field backdrop for the tafferal carving of Apollo more closely mirrored that of the Berain drawing. This was my main priority. The consequence of that choice, if I wanted to recycle the figure carvings, was that I would have to modify them in a way that brought them closer to scale. When I made the quarter gallery drawing, I drew Africa without regard for the position of the quarter pieces (the bust carvings that support the side lantern boxes). As for those busts, I merely reduced their length from the bottom. I should, perhaps, have decapitated them to shorten their necks, but I hadn’t thought far enough ahead to see how the figure carvings would relate to them. Here is the fit before modification. She’s practically making out with the quarter piece: My plan was to make a series of narrow-kerf cuts across the outside leg, the lower torso, upper torso and neck. The neck cut followed the re-assembly after the first three cuts because I needed something more substantial to hold onto, while making the neck cut. This worked far better than expected. You can see what amounts to an overall reduction in height of 3/16”. This may not seem like much, but it makes all the difference. Post-cut fit: Although her crown comes up and slightly obscures the face of the quarter bust, at least her face is now below that of the bust. I didn’t like how the inboard foot is just dangling in the air. A quick check of Berain indicates that the in-board foot should be swept out-board so that the pierced lattice of the archway is visible. Considering how much time and effort went into making those archways, I would very much prefer that the lattice work remain visible. With that in mind, I decided to section off the inboard leg, through the groin. By positioning the leg the way I want it, I can get a sense of the angles at play, and the void that needs to be filled. With 1/16” styrene fillers glued to each mating surface, I could then begin the process of fettling the joint, until I get that foot to rest where I want it to. The resulting re-join is highly imperfect seeming, but all of that extra plastic will be carved away and detail added back to provide the visual continuity that is so lacking, at the moment. After fairing: Now, I can fair her seating position along her under-carriage. There are only three tenuous connection points: the outboard ankle, her seat, and the inboard shoulder with the quarter piece. I decided to add a few steel pins - one to the ankle and one to her seat. I also want to pin through the inboard shoulder, into the quarter piece. The pin locations drilled: The one for her seat was really tedious to drill because the quarter piece and lantern box prevented me from using a pin vise. I had to trap the top of the micro bit with the fore-fingernail of my off-hand, apply pressure, and turn the bit with my other thumb and fore-finger. This was a real test of patience, and I managed to not break away the archway. For the shoulder pin, I’m using .035 styrene rod: You can see how I had to flatten the fore face of the shoulder and bicep, so that the figure would nestle-into the quarter piece. And, so, the un-modified figure before (I have an extra): And After: This figure now is in proportion with Europe and Asia, above, and matches the height of my Africa figure (not pictured). I will paint the figure and glue her ankle, seat, and shoulder. The shoulder pin has to be inserted after the figure is in-place, which is why I chose styrene for that pin; I can easily trim it, fair it, fill with putty and re-paint after installation. Thankfully, I realized that the angle of the arm needs to be modified a little, in order to wrap around the quarter piece. I will position the arm after the carving is secured, to ensure exact placement. You can’t, after all, maneuver the two steel pins into place, with the arm on because you need a little wiggle room to get around and up against the quarter piece. The figure will be grey-washed white like Europe and Asia, and I will probably do Citadel green wash for her skirt, with highlights of bright gold. I will soon get back to the rigging of the main deck guns. Thank you all for your likes, comments and continued interest. Best regards, Marc
- 2,699 replies
- heller
- soleil royal
(and 9 more)
I will take a look around and see what I can find. I’m not optimistic about what you are describing, in particular. Most of what I remember was strictly ornamental: figurehead, fleur-de-lis, the big stern carving, the main lantern, and some other stuff that I don’t remember. Castings/pressings of what I have may be better than whatever iteration of the kit you have now. I’ll look and keep you posted. In any case - if I can find it - you are welcome to it.
What castings are you in need of? A modeling friend, along the way, had acquired a set of castings for what I believe is the Corel kit. I know it is definitely La Couronne. He passed them to me, as he knows I love the French ships. I’m pretty sure I still have them somewhere. They were fairly substantial bronze castings. They’re yours for the asking, if I can find them.
Aaah, coaching - extremely rewarding, but time-consuming! I can relate to the fact that it is definitely very difficult to find energy and time when the season is on. Dolphins look truly awesome - nicely done! As for there being more connection to the dolphin belly, they were drawn to suggest open space, but for practical strength purposes, it does not seem unreasonable that there might have been complete connection, with the inner scroll carved as a raised relief.
- 419 replies
- soleil royal
- Heller
Aaaah, Kevin - you are here, at last! I've been patiently waiting. I understand your methodical approach, and I don't expect you to make any quick in-roads on this one, but I am guaranteed of one thing: whatever you end up doing, it will be interesting and innovative. One thought springs to mind, and that relates to your comment about tumblehome of the upper bulwarks. The kit's aft bulwarks end up relatively vertical, and more slab-sided, as determined by the stock stern-plate. I found, however, that because I made the lower hull wider, I could pitch the aft bulwarks at a much more pleasing angle/degree of tumblehome. If you are already considering the possibility of printing a new stern plate to incorporate the stern round-up, then you have the opportunity to incorporate a more pleasing slope of tumblehome. There would also be the opportunity to re-scale to a six-window stern, as opposed to the stock 5-window stern, vis-a-vis the Tanneron model. What surprised me, by the time I reached the upper tier of stern lights, was that the width of my stern at the very top, was almost exactly that of the stock stern plate +/- 1/16". I mention the possibility of six windows because the two lower tiers of lights are more vertically in-line, and lay waste to additional space below. Really take a hard look at the stock stern plate, and you'll see what I mean. Heller simply followed Tanner, on this detail, but there is room to re-scale - even without widening the lower hull. Anyway, I will be watching with tremendous fascination at what I know will be excellent. Bon Voyage!
Excellent process and results. I agree to err on the side of smaller.
- 419 replies
- soleil royal
- Heller
Excellent problem-solving and technique, John. The chains look excellent. At this scale, one has to do their best to find something that works for them. Now, I could very well be mis-remembering this, but I believe all of those extra rings, interspersed between the chains and along the length of the ship, are there to assist the carpenters as they scale the sides of the ship plugging battle damage. As always, John, it is a pleasure to catch-up on your log. You always seem to have an innovative approach to vexing problems.
- 106 replies
- Soleil Royal
- Ship-of-the-line
Your dolphins are definitely trending in the right direction, Eric. That last one is really very good. While I had some carving skills going into my project, I had no small-scale carving experience. Whatever your medium, it just takes a little while to figure out what you are doing. These, I think, are simply the growing pains of this sort of project. Your efforts are quickly bearing fruit!
- 419 replies
- soleil royal
- Heller
