Jim Rogers
Everything posted by Jim Rogers
  1. Have to agree with Lou. Paint it flat black. Now would also be a good time to invest in an air brush and learn how to use it.
  2. I was a Torpedo Technician. I tested and maintained Lightweight Surface Torpedoes for 25 years active duty. Then I got hired on at Keyport, WA (Torpedo Town USA) and over the years got promoted to GS13 in charge of all the Torpedo facilities around the world.
  3. Thanks Eugene. I really appreciate the way your company responds to all inquiries. Other companies should take note on how to provide real customer service.
  4. Mix some of the Cedar sawdust with white glue and use that as filler. It will be sandable and same exact color. The other thing to remember is that parts on boats shift at sea so small gaps would be expected.
  5. I went online and had on of the vinyl label guys make one for me. Just chose the smallest font they had.
  6. $399.95 I’ll keep my number 11.
  7. I have found that anything you plan on painting metallic should be primed or painted white first.
  8. I’d Be runnin’ some line through them now. It will be a PITA later. She is looking good.
  9. It was advertised in a MicroMark email. I believe it is out of the start up phase if a company has it up for sale.
  10. Has anyone used one of these?
  11. These small boat kits are top of the line nice. I have built three of them.
  12. I usually seize the .008 to the top heart then run it through the bottom heart at least 4 times. I then take a toothpick and a small dab of CA to hold in place. Once it is set I seize the bitter end to the line running between the hearts.
  13. Sent it through the planer, polished it, mounted on blackened Maple, made acrylic case, added water action. Done
  14. Lessons learned: 1. Don’t need the pre made groove. That is why God made a router. 2. When I poured the resin I brought right to the top of the wood. When I removed the clamps the resin had dropped about 1/8 inch. It has seeped under the wood. Next time I will mix a small batch and seal by painting it on between the bottom and the wood, and then pour the next day.
  15. Next I laid it all out, checked clamping plan, and coated layout board with sheathing tape. The resin was mixed with Black Diamond Blue Cobalt powder and then poured. The sheet of wood in the middle is where the keel will rest. It is also wrapped with sheathing tape.
  16. It took awhile for the sails to arrive from Russia and they were about 1/2 too long. Not being a seamstress and not going to tear apart the boat an re build I just rolled up the bottom. As I was sitting there looking at the model Imdecided it needed a base so I decided to experiment with a River Run Resin Base. First I purchased a live edge piece of Quilted Maple and cut it in half.
  17. The translation leaves some to be desired. Truth be told I wrote technical documentation for Lightweight Torpedoes for the Navy and bad documentation drives me nuts. BUT the saving grace is the written word is accompanied by a good pictorial. Read, look at pictures, re-read. I found it strange that there were no fighting tops, just crosstrees so I added them.
