GrandpaPhil
Posts posted by GrandpaPhil
  1. The gratings are all made and the deck hatches by the main mast are made.  The galley funnel is partially made.
    I cut slots in the head gratings to pass the gammoning through.
    None of the deck fittings are painted or glued down.  I still need to shape the funnel and make the end look hollow.
    I need to make the pin rails.
    Due to the scale, I am using straight pins for belaying pins again.
    I still need to make the bellhouse, the skylights, the wheel and the binnacle.
    I also need to make the ladders and my remaining guns.
  2. OC,
      I know, I thought about that.  I was planning on cutting slots for the gammoning after the gratings dried, but I forgot.  Thank you for the reminder.
    The Victory is the first ship that I’ve built which has a double gammoning.  This should be interesting (but fun).
  3. Thank you all for the likes and the comments!
    I am currently gathering ideas and looking at other builds to try and prevent the warping and twisting that I have had in the past.
    I think that I am going to fill the gaps in the bulkheads with balsa this time.
    The covering is going to be card, so strength won't be an issue.
    Balsa is light, so weight won't be a significant issue.
  4. I finished the head, except for the boomkins and the netting.
    I’m waiting until I get to the masting and sparring stage before I install the boomkins to prevent accidentally ripping them off.
    I’ll do all netting at the same time because I have to install netting all along the rails.
    I’m currently finishing the sides, then I’ll start at the front and work my way back on the deck fittings.  Maybe, we’ll see.
    Either way, I’m having a lot of fun working on the Victory.  Deciding to scratch build the rest of the model was a good decision.  I’ve been having a lot of fun with it.
    I just finished the hardest part that I had left which means that the rest should go smoothly (aka: I’ve already been down this road).FD51AB56-6B1A-415F-980A-EBF96819FA13.thumb.jpeg.e1b5064a00b8e4586debec253608befb.jpeg180DB415-66DE-40D1-8C39-4E3028D1D2D7.thumb.jpeg.fca429df8732770ae1aa15fa6a2ddd36.jpeg24B52C23-2975-4BD1-BC32-39B54B2106F3.thumb.jpeg.9096c240d7e8c05ebcb86dc52410e800.jpeg
  5. The head gratings are in place.
    They need some trimming and some paint work.
    The knight heads are just dry fitted.
    I extended the beak head and will paint it when I paint the gratings.
    I just need to make two fashion pieces that sit on top of the head rails and two double seats of ease and the head will be complete.
    I’m holding off on making the boomkins until I get further along so I don’t break them.
