GrandpaPhil
Posts posted by GrandpaPhil
The port side is second planked up to the waist.
The next step is to trim all planking.Then gaps need filled, planking needs smoothed out and everything will get sealed prior to painting the final yellow ochre band across the gunports.
The rest of the ship will have the geometric patterns that galleons of that time period were known for.
I’m starting to appreciate how large of a project this model is going to be.
I’ll have to find a place to put it when I’m done with it.
Quick lesson learned: I much prefer vertical planking and then applying the wood grain, it works much better than this has. The only drawback is that one must account for the 1mm difference in thickness on the planking when tracing bulkheads.
I built the crocodile version of this kit a number of years ago. It built up very nicely.
- mtaylor, Old Collingwood, Canute and 2 others
- 5
Thank you very much!
The trick with card is to preshape everything before gluing.
The card will retain its shape.
For round pieces that need rolled or to take a sharp curve, I run it over the edge of my desk to break down the fibers, kind of like using scissors to curl ribbon.
This model is POB. I just traced the parts from the plans, copied them a number of times, to layer them up, and pretty much just treated this like a wood model.
I am using this one to try out new techniques and see if I can finish it.
The hard part for me has always been getting a hull.
But, I have that now, so there should not be any overwhelming difficulties remaining.
- Glen McGuire and Canute
- 2
- Canute, mtaylor, Glen McGuire and 5 others
- 8
Schreiber-Bogen makes a card kit of the Great Eastern in 1/200 scale.
It retails at Fentens Paper Models for about 40 €.
https://www.papermodel.com/272449-great-eastern.html
Card kits can make great sources of plans and are infinitely scalable.
I have bought many of them over the last couple of years for that reason.
- mtaylor, John Fox III, Thukydides and 6 others
- 9
They are definitely something different to make!My wife was very pleased with them!
- mtaylor, Glen McGuire and Canute
- 3
Welcome!
- Deyson Morken, Keith Black and mtaylor
- 3
Model Shipways has plans of the Bluenose I.
Welcome!
Where is the model located?
I ask because there may be someone relatively local to you or a model ship club in your area.
I am not interested in another project myself, but there may be someone in your area that is.
- Baker, mtaylor and Keith Black
- 3
Welcome!
- mtaylor, AJohnson, Keith Black and 1 other
- 4
Looking forward to this build, Chris!
- Canute, mtaylor, Old Collingwood and 6 others
- 9
Purchasing Old Wood Kits
in Wood ship model kits
The best bet is to look in the kit if it is local to make the best determination about the condition of the materials in the kit.
Bounty has a bluff bow (a lot of curvature) so be sure to check on the condition of the planking, unless you are planning on replacing the planking anyway.
Also, check for warping in the sheet wood, although that can be corrected.
