Posts posted by CPDDET
Very nice build! And welcome to our little corner of the world.
Between your past experience and the help available here, I doubt you'll have any problems with your next project.
Dave
- Keith Black, Ryland Craze, Dave_E and 1 other
- 4
Next on my list was to make and install the brass inserts and the chafing plate for the boom jaws on the main and foremast. While I have decided to cut the mast short and skip the rigging (in order to save costs on the size of a display case) I did leave the masts long enough to mount the booms.
After some careful measurements I cut a piece of .005 aluminum sheet to the proper size (.45 inches high and .87 inches wide). While not photographed, this width left the proper gap on the aft side of the mast.
I picked up the aluminum sheets from UMM when I visited the model expo at the Dupage County Fairgrounds. In an attempt to make the aluminum look a bit more like galvanized metal, I scuffed it up with some 400 grit paper and sprayed it with Easy Off Oven Cleaner. Not quite the look I wanted but not too bad either. I toyed with the idea of using a rivet wheel to simulate the nails that would hold the chafing plate to the mast, but at this scale I decided against it.
For the brass band inserts I used an automotive feeler gauge to measure the gap. Then cut a .032 wide strip from a .005 brass shim stock I had on hand. This, and the aluminum, cut very easily with a utility knife.
I used fast epoxy to attach the plate and band inserts.
Now it’s on to building the gooseneck for the foremast, which looks a bit challenging.
- Prowler901, GrandpaPhil, bhermann and 1 other
- 4
Welcome! You'll find lots of help here if you ask for it.
Looking forward to your build log.
Dave
- mtaylor, Dave_E and Keith Black
- 3
Welcome, you're at the right place for a positive learning experience.
Dave
- VitusBering, Dave_E, Keith Black and 1 other
- 4
Welcome! Looking forward to seeing your work.
- mtaylor, Keith Black and Dave_E
- 3
Nice workmanship there! Welcome to the forum.
Dave
- thibaultron, Keith Black, Dave_E and 1 other
- 4
Welcome!
- Keith Black and mtaylor
- 2
Welcome! Anytime is a good time to resume work on a model. You may find putting aside a project for a short or extended time is more common than you think. I sometimes go for weeks without getting anything done in the shipyard. I find forcing myself to work on my model usually ends up in inferior workman ship. Better for me to wait until I'm really ready and looking forward to the task.
- mtaylor, Keith Black and Ryland Craze
- 3
Welcome Chuck! Trust me, no matter what level anyone here is at we are all learning from each other.
Doing is learning.
- mtaylor, Dave_E, Ryland Craze and 2 others
- 5
Well, it’s been quite some time since my last update, but I’m fully recovered from surgery now, Christmas décor is up, lawn is put away for the winter and snow blower is ready to go.
As mentioned in my previous post, I've decided not to do the entire masts so I can save some money on the display case. The main and foremast will be cut short allowing me to purchase a much shorter case for the model. I’m really limited for display space.
I now have a good start of both the main mast and foremast.
Poplar isn’t the best wood to work with as it fuzzes up a lot like basswood. But at this stage of my experience I wanted to use what I have on hand. I will be moving on to better woods on future models.
I started with a ½ inch poplar dowel rod for each, about 5 inches long.
I turned these on the lathe.
I used a shaping tool to get the slight taper on the lower band which will sit on the desk.
Then used a cut off tool to make the grove in the upper band
Then mounted the piece in the mill to form the tendon which will fit into the block below deck that was installed when building the hull.
Here is the main mast (on the left) and the foremast (on the right)
For the supports blocks I cut a piece of cherry into a 2 mm X 2 mm square and then used a scraper to make the shape I wanted. The cherry is much easier to work with and will add some detail highlights to the model. My bluenose is quite a mixture of woods, shiny brass and blackened brass, but I've already succumbed to the fact that this build is more of a learning process than anything else. My next build will be more uniform.
Cutting the length of cherry into individual pieces was accomplished by using an X-ACTO blade to mark the cut and then using my jewelers saw to complete the cut. After trying a razor saw and an X-ACTO saw blade, I found the jewelers saw made the cleanest cut.
Using Titebond Quick and Thick, I glued the support blocks (corbels?) into place on both the main mast and foremast.
Still have to do the metal bands as well as the “galvanized metal” on the main mast. But first will finish both masts with amber shellac first.
Moving along…….
Welcome, and best of luck!
- Keith Black, jcooke26 and mtaylor
- 3
Welcome aboard! Some fine work there on your model.
- 3
White glue, yellow glue, epoxy, CA
They all have their place when used in the correct application. But never Gorilla Glue.
At least for me.
- Chuck Seiler, mtaylor and Keith Black
- 3
Welcome! You will find all the help you will ever need here.
Starting with the Model Shipways series is a great way to go, I wish I had done it.
You may also want to consider the half hull model offered by the Nautical Resaerch Guild to get a good grasp of hull planking.
- Keith Black, mtaylor, USCGDave and 3 others
- 6
To paint or not to paint. That is the question, at least for me. I struggle with deciding which way to go. I love the look of wood but paint is needed if one wants realism.
But it is my model and i should follow the path that leads to a finished product I enjoy viewing. So I imagine my next model will be wood. Using different species to add depth and interest.
5 hours ago, allanyed said:
Welcome to MSW!!!
Not sure what series Dave is referencing, but there is one that others have tried and have great things to say. https://modelexpo-online.com/Model-Shipways-Shipwright-3-Kit-Combo-Series_p_5465.html Hopefully you can find these from some other supplier that is not so far away from you.
This is exactly what I was referring to. If I had to start over I would have done the half hull kit and then the next three before taking on a large project.
- 3
You might want to start with something basic, like the half hull model sold through the Nautical Research Guild. This kit will teach you proper hull planking techniques.
There is also a series of 3 models. This series starts basic and builds into more challenging work as you proceed.
Dave
- Keith Black, Dave_E, mtaylor and 1 other
- 4
Beautiful detail work there!
- KeithAug, mtaylor, Knocklouder and 2 others
- 5
Thanks, Todd. Just trying to get re-started.
Life gets in the way sometimes.
Carry on, Tim. The planking gets easier, the more you do.
Dave
Bluenose by Fubarelf - Model Shipways - Scale 1:64
Looks great!
