Posts posted by Dr PR
I have had problems similar to what Chris and others reported - some blotches and the blackening rubs off.
I noticed that the parts blacken almost immediately in Birchwood Casey Brass Black diluted 1:1 with water. I have tried leaving them in the bath for 5, 10 and 15 minutes with about the same results. Then I rinse with water 5-10 times and dry the parts. Maybe I should use a minute or less.
I normally wash the parts in acetone for a minute or two to remove solder flux, then use rubbing alcohol to remove the acetone, and a final wash with water to remove the alcohol or any remaining water soluble materials. After drying I use the blackening solution.
I have also tried etching with mild acetic acid (vinegar) and then rinsing with water. Then the acid/alcohol/water washes. It doesn't seem to make any difference.
- Desertanimal and Canute
2
There are many "sanding sealers" or primers. But shellac is probably the best.
You can get pre-mixed spray on shellac. Zinsser Bulls Eye Shellac is available at hardware stores, A 12 ounce spray can will last a long time. Use the clear shellac for painted surfaces. For "bright" (unpainted) wood use the amber shellac. Each new layer will darken the wood, so continue until you get the wood color you want.
I sometimes spray it on the surface, or just spray it in a small cup and paint it on with a brush. Either method works, but brushing gives you better control of where the shellac goes.
Shellac cleans up with rubbing alcohol. But if you want to dilute it use denatured ethanol (alcohol fuel). It dries quickly.
You can paint over it with just about anything.
First sand the hull smooth, starting with heavier grit and then fine grit. Keep at it until the hull is smooth enough to paint.
Coat the wood with shellac and let it dry an hour or two. Then sand it with fine grit sandpaper. Wipe with a clean cloth to remove sanding grit and dust.
Apply a second coat of shellac to seal after the sanding. Then rub it down with #0000 steel wool to get a nice satin finish.
Wipe the hull to remove steel fibers. Use a strong magnet to pick off any remaining steel wool fragments.
Paint with whatever you want. Use thin coats and apply evenly, stroking from wet paint to dry, and you won't need any further sanding. But if you get runs and need to sand them smooth just apply another coat over the sanded area.
If you use acrylic paints allow each coat to dry for 3-5 days, or longer in high humidity areas.
A lathe us a useful tool to have around, but I don't think it is the best way to make masts. A lot of experienced modelers have said the same thing. The main problem is that it is tricky to set up a lathe to create a tapered (conical) piece, and some lathes do not have all the features to do this. And masts aren't conical - the taper varies to create something like a long truncated ovoid.
I have made masts and spars starting with round dowels and chucking them into an ordinary hand drill (a locking trigger is very useful for this). Then I used files and sandpaper to grind the dowel down to the desired dimensions.
However, I like the simple method of using a small plane and files to taper the mast. Starting with a square dowel you shave off the corners to 8 sides and then again to 16 sided. Then you can round it in a drill or using files and sandpaper. This is a lot easier than it sounds! Here are some examples.
- Snug Harbor Johnny, Canute and mtaylor
3
A fairly simple way to modify the cannons is:
1. Find some round head pins of the appropriate diameter for the cascabel. Fabric stores carry a variety of pin sizes. Clip the pin about 1/16" / 2mm from the head.
2. File off the projections on the rear of the cannon and round off the back end.
3. Drill a hole in the back end where the cascabel should be. The hole/drill bit diameter should be the same or slightly larger than the diameter of the pin. The metal is soft so you can do this with a pin vise or motor tool.
4. Glue the shaft of the pin into the hole in the cannon. Use a glue that will adhere to metals. I would use Duco Cement or a two-part epoxy.
5. Paint with satin black paint.
Note: Don't try to solder the pins into the holes. Some of these fittings are cast from low melting point metals, and the whole cannon will melt into a puddle if you heat it very much.
- thibaultron, Gregory, barkeater and 8 others
11
There are several photo editing programs for Linux. GIMP is the one that comes to mind - I think it has been around for some time, Some of these raster image editors can import and export PDF images.
- GrandpaPhil, Canute and mtaylor
3
Another slight change of plans.
I decided to use 1/16" (1.6 mm) plywood for the sub deck. I think the 1/64 (0.4 mm) plywood would be strong enough, especially with the large number of bulkheads. However, I have a lot of spare 1/16 inch material and I might as well use it. The added stiffness will give more strength to the hull, and that is important in minesweepers!
Several places around here carry 1/16 inch plywood, but 1/64 inch is pretty rare, and relatively expensive. It is really handy for making small bits and pieces and is much stronger than plain wood. So I will save it for those special pieces and use the thicker material. I already know I will be cutting some 1/64 inch thick pieces for trim on the superstructure. I can't find any 1/64 inch thick wood scale lumber of the right dimensions.
There were two common ways to get up the mast without rat line. One was to climb the mast hoops - only works when the gaff sail is raised. The other was a bosun's chair - basically a plank in a harness at the bottom of a halyard run through a block at the mast top (or just tie a line around a sailor and haul him up with the halyard).
Capelle's books show smaller vessels (less than 40 tons) without ratlines. Larger vessels (40-90 tons) may or may not have them - usually masts with square sails had ratlines, fore-and-aft sail mast did not. The largest vessels (100+ tons) usually had rat lines.
The advantage of the fore-and-aft gaff sails is that all the lines can be worked from the deck, and they can be reefed from the deck. Ratlines not needed. But square sails almost always required sailors to go aloft, especially to reef or furl the sails. Ratlines allowed many men to go aloft in a short time.
The exception with square sails is that smaller sails (topsails and topgallants on schooners, royals and skysails on large square riggers) could be rigged to the spars on deck and the rigged spar and sail lofted into place quickly. This still might require a man aloft to secure things. But these spars/sails could also be lowered to the deck quickly. So a lot of men aloft weren't needed, nor were ratlines high aloft.
- Gregory, Rik Thistle and mtaylor
3
I have some progress to report. When I find time I have been adding the bolt ropes to the sails. Here is a photo of the sail loft with work underway on the fore course and a finished fore staysail.
It is monotonous work. The rope tends to wander off from where I want it so I can glue only fairly short lengths to the sail edge at one time. I use a tool to hold down the loose end and "paint" diluted (1:1 with water) white glue along the sail edge, While the glue is still damp I use the brush to push the rope into place along the sail edge. The glue doesn't stick to the parchment paper on the work surface.
Here are the completed triangular sails laid out on the sail loft (kitchen) floor.
Now I am working on the larger sails (course, topsail, fore sail and main sail). They should be finished in a week or two. Then I have to put on all the reef points.
So far I have found no reference that says what diameter/circumference line was used for reef points. One source does say they were flat braided straps that came to a point. Well, I am not going to try to do anything like that. I think I will just use the smallest thread I have.
While adding the bolt rope I had a sudden "oh, no!" moment. The triangular sails used a lot of the 0.008" tan rope, and I realized that when I did the calculations to determine how much of each rope size I need I didn't include the bolt ropes! I went back to my spreadsheet and added up the lengths of bolt rope. Fortunately, I have a lot of extra rope on hand. I should have about nine feet (3 meters) of the 0.008" left after the model is finished.
- SiriusVoyager, Gregory, John Ruy and 1 other
4
There is a discussion of carriage gun rigging here:
https://modelshipworld.com/topic/21776-carriage-gun-rigging/?do=findComment&comment=652700
- mtaylor and Knocklouder
2
Gregory,
I saw George Wales' drawing of the Rattlesnake in "American Sailing Ships" about 55 years ago and thought it was a beautiful ship (I really like vessels with tumblehome). I started redrawing Chapelle's plans by hand, scaling them to 1:48, with the intention of making a scratch build model. However the little fuss in Vietnam brought that effort to a halt.
About 25 years ago I saw the Mamoli kit in a local hobby shop and bought it on the spot. However my job, marriage and a couple of houses to keep up put the kit on the shelf, where it has been ever since. But someday I intend to bring it out and start building it.
Hence my interest in your project. I will be following it closely, taking notes for when I start work on the Rattlesnake.
I have decided to make a small change of plans. I originally intended to lay the decking directly on the bulkheads, and the tops of the bulkheads were dimensioned for this. The decking is 1/16 x 1/16 inch (1.6 x 1.6 mm) basswood sticks. These will not be very strong and might break easily.
Looking at other builds I see that a subdeck of thin plywood is common, with the deck planking laid on this. I decided to use some of the extra 1/64 inch (0.4 mm) plywood for the base deck material and plank on top of this. I reduced the height of the bulkheads by 1/64 inch to allow for the thickness of the plywood.
I plan to try the technique mentioned in recent posts of using Titebond Original glue and heating it to fasten the planks in place. First the subdeck will be coated with a thin layer of the glue. Each plank will also have one side coated with glue. After the glue dries the planks will be put in place and then I will use my spiffy new small quilting iron/plank bending tool to heat the planks, melting the glue.
- KeithAug, FlyingFish, Ras Ambrioso and 4 others
7
Here are a few thoughts.
1. The fairleads in this position were common, so they were used for something.
2. The open top fairleads/chocks are used when you need to lead a line temporarily and be able to move it quickly.
3. They are above the well deck, so they were probably associated with something there.
4. There are life boats on the well deck of the Cecilie.
5. The deck plan drawing marks "boat skids" port and starboard. Perhaps these were portable skids to allow the boats to be moved. We had essentially the same thing on the cruiser I was on.
6. The boats are positioned under the shrouds. It would be necessary to haul them aft before lifting them over the sides.
7. The lines to move the boats could be lead through the fairleads and back to a capstan.
- mtaylor and Keith Black
2
The model is looking good!
- robert952 and Paul Le Wol
2
Jim,
Good to hear from another CLG sailor - if you will excuse me calling a Marine a "sailor."
This thread isn't very active. The CAD model is finished, mostly. I guess I should put a Kaman SH-2B Seasprite on the fantail (the Admiral's helo) but I haven't found any good plans to work from.
Mark,
The sheave could be used for the flag halyard. In some cases the halyard ran though a small "jewel" block hanging from the end of the gaff. Either way would work.
I have seen examples where the ends of the flag halyard was belayed to a cleat on the boom. This way the lines moved with the boom and gaff. You really can't tie them off to anything else (like the bulwarks).
On schooners that flew gaff topsails the topsail sheet sometimes ran through a sheave at the end of the gaff. Maybe the model plans just copied the gaff drawing from a schooner. On square riggers it was not common to have a gaff topsail above the spanker/driver. However, I have seen at least one instance where a gaff topsail was used on the mizzen above the spanker. Sometimes such additional sails were rigged in light winds but not normally flown.
Rob,
Very nice work!
For me making a bunch of tiny complicated parts like this is like banging my head against the wall - because it is so nice when it stops.
Albatros by Dr PR - FINISHED - Mantua - Scale 1:48 - Revenue Cutter kitbash about 1815
The bolt ropes are done. Taxes aren't!
