Posts posted by GeorgeKapas
Unfortunatelly this was the last photo before the "finished" ship or at least the current state of the diorama. I made a simple base with only sea. The rigging is seen almost finished. I used thread and melted spruce as well, especially in the deadeyes, which were also made from scratch. The guns are from my stash.
The lower hull was easy enough, considering it is only a waterline model, and the galley has very little freeboard. It will be recessed into the base, and so only 2-3 milimiters of freeboard for the model. As for the materials, it is made mostly with card and thin plastic strips. I used my usual method for decking, drew planks in the PC, printed them in A4 black and white, and painted them. First with acrylics then with a coat of matte enamel.
Evening! So I decided another small built is in order. I wanted to be thematic to the history of my hometown. The plan was of a diorama of a venetian galley exiting the port of Chania, circa 1640. 1/700 was very small, so I went for around 1/350. I used the plans of "La Dracene 1675" although I mixed and matched other earlier plans I had, after all, the waterline hull at 1/350 left little room for specific details. In any case, the galley was of the heavy 2 masted version or "Capitana" Unfortunately I ommited photographing many steps of the built. Also, although the ship it self is basically finished, I revised my initial plan to have it exiting the port, and quickly built a simpler sea-base. So technically it is not finished yet, as the original plan is still feasible.
- VTHokiEE, GrandpaPhil, mtaylor and 3 others
6
- GrandpaPhil, mcb, mtaylor and 5 others
8
The base is a simple seascape, as the ship will be, once again, anchored. Of course it is not attached to it, and I may change it alltogether later. In any case. The superstructure of the forward barbette and the masts are made of strips of plastic and melted spuce. I may use some ready boats from other 1/700 kits, but I am not sure..
- GrandpaPhil, yvesvidal, wefalck and 4 others
7
- ccoyle, wefalck, GrandpaPhil and 3 others
6
A similar project to the cruiser Averof. Once again, the lack of detailed plans was a problem, which was alleviated by the small scale and the decision to make it waterline. There are almost no models of this class of ships outside the two in the museums here in Greece. I wanted to make one for some time now. Bizzare little battleships, with an unconventional layout which proves a bit of a challenge to recreate. In any case. Here are a few photos of what I am talking about:
- wefalck, mtaylor, GrandpaPhil and 4 others
7
- mtaylor, GrandpaPhil, raysven and 6 others
9
Thank you. The sea is a very thin papier mache with a coat of wood glue. I may need too add a few more coats of wood glue. This method gave a hard time at this scale (1/700)
- lmagna, Old Collingwood and mtaylor
3
17th century Venetian galley by GeorgeKapas - FINISHED - 1/350 - waterline
in - Build logs for subjects built 1501 - 1750
So here is the current (finished?) article!
