Everything posted by Edwardkenway
No it wasn't heavily manned but as it was sat on the main road across the valley and in the centre any columns attacking down this road would have been enfiladed by the farm garrison and morale weakened before they reached Wellingtons line, also once past the garrison could sally out and attack the rear of the column that was being blasted by the rolling platoon volleys from the British line in front. So he didn't want a thorn like that in his side. In my opinion, if he had left Hougoument and concentrated on his centre and his right flank he probably could of routed the British and her allies before Prussian forces appeared on his right. But that is only my opinion with the benefits of hindsight and a wealth of historical information. Other better informed people may have differ reasons for his distraction with the farm and Hougoument.
Proxxon saw advice
Edwardkenway replied to SweepHall's topic in Modeling tools and Workshop Equipment
I bought one last month to try and save having to pay for pre-milled planks, have had decent success but would recommend also buying the 0.6mm blade as the one supplied makes more sawdust than plank☹ If buying in the UK, CHRONOS are pretty good, not the cheapest but supply ready for UK use, plus standard delivery in the price. Just my two pennies worth. -
@Kevin thankyou for that link, there was alot I didn't know in it eg the Dutch and German troops 👍 @Canute yes, if they are as well painted as the French, they will look superb. The 60th did get a mention in one of the sharpe books, Sharpes Regiment I think it was, but it's a shame they are not as well known as the 95th🤔
Neat and tidy, something I can only aspire to, great woodworking Glenn 👍
- 778 replies
- cheerful
- Syren Ship Model Company
The cannon are looking great Tim, and when you've rigged them they'll be even better. All in all your whole build is super 😃😉
- 435 replies
- vanguard models
- alert
Seems ages since I was here last, but I'm still sorting out the stern frames and window formers. As a break from working on the hull skeleton I had a practice cutting some planks. for a first ever attempt I'm reasonably pleased although I shall be buying the thinner saw blade for my proxxon, as with the throw away planks which I wont be using, I only managed to get 12 planks. The kerf being thicker than the cut plank I assume with 11 sheets you need about 23 from each?? Thanks for looking in and the likes. Cheers Edit:- the Cedar from Chuck is beautiful, and smells good too😁
Most of the light skirmishing troops tended to leave unnecessary equipment with the regimental baggage as it gave them a better freedom of movement. The 95th and 60th Rifles only took their full quota of cartridges (60 per man), a quantity of small soft leather patches for a tighter therefore more accurate shot, horn of fine milled powder and a canteen of "water"!!! I'm not so sure of the French but I would assume they went packless also.
and a slightly late welcome to MSW Your keel in the photo looks like a good start on a viking drakkar, hope to see the full log soon 😃
I would never have thought of doing it that way, I probably would have tried to buy all the figures in one go and had the Admiral questioning my spending 🙄😋 Are you scratch building the farm or getting resin components? The two "Gros Frerès" look amazing OC, I'm already feeling for the KLG infantry.
No, it seems to taper abruptly from the 3rd bulkhead, but when I marked it out for the planks the tic strips also showed tapering from the 3rd bulkhead. The planking worked out but I must do better. I think a little more patience and a sharper pencil for marking as the tic marks are not fine enough and did throw me out by .25 - .5mm. I can use the port side to refine my planking as I would like to be more confident with it before I start Winchelsea!! after a good sanding and one coat of danish oil, ther is a few parts that need attention to remove glue residue and some small gaps that need filling. Thanks for all the comments and likes, it's really appreciated. Cheers till next time 😉👍
