Edwardkenway
Posts posted by Edwardkenway
  1. Hi all, had 2 or 3 hours on my cross section mainly cutting frames and assembling them. I've only got four more to make, but as my decking timber has not arrive yet I'm not going to rush them.
    This is because I've found that when rushing thing go wrong, and that's  why my last two frames were cut out twice with one of them going in the scrap box.
    Well till next time,
    Cheers
  2. @vaddoc I have come to the conclusion that if I'm going to buy anything it will  be a scroll saw. As to all the other toys my other half would raise more than her eyebrows. But till my budget is healthy enough to get said scroll saw I will persevere with my coping saw and for smaller more delicate work a jewellers saw.
    Thanks for your input it is greatly appreciated.
    Also thanks to everyone who has contributed to this discussion.
    Cheers
  3. Hi all,
    Could not find the time to get any more frames made up, so decided to have a crack at the gun carriage axles and wheels.
    I racked my brain thinking what to use for the wheels but then I looked at the pencil I'd been chewing, it would be perfect as it was 5mm diameter and the lead ran exactly through the centre. So I drilled the lead out and then sliced the pencil into as many rounds as it would make as I was bound to break some.20190911_222648.thumb.jpg.f1f9df0e25b598dbd38741a2cf951d2a.jpgI could not cut them to thin as they just broke apart so there was a lot of sanding to make them look passable.  All in all I had an enjoyable couple of hours doing this.
    Oh well back to the frames next time, although there's no rush as I'm waiting for the wood for the deck structure to arrive.
    Cheers
  4. Hi all
    Rain today so not at work so I have done a bit on my build. Tack glued another frame template ready to cut out and made the gun carriage sides. These are made from some scrap 2mm walnut ply.  These 4 are the best of my efforts. I'm not quite ready to tackle the wheels yet so I'll leave them till later when I'm a bit more confident.
    Cheers
  5. Hi LS
    The rigging is less complicated than it looks. The one thing I would have done differently is the running rigging that the plans show belayed on the windlass, if I were doing it again I would belay them on the mast bits.
    You  have made yourself a lovely little ship and she will compliment Ballahoo perfectly.
    Cheers
  6. This is going to be a long, slow and enjoyable experience as I'm learning new skills and seeing something I've made come slowly together.
    I checked that my drawings were the same and yes all frame drawing are  identical, apart from position number/letter.
    Bought some  new and finer blades for my coping saw.
    Well I cut my 2nd frame and it's better than the 1st, at this rate my last one should be perfect!! It's now glued and clamped and while waiting for the glue to dry I attempted to cut the rabbet into  the keel, the one you see in the photo is my 3rd try, I think I may go with that one.
    Cheers
  7. @Bob Blarney I have just bought some more extra fine coping saw blades bladesand am going to try them tomorrow as I need to cut some more frames . I've got some f clamps I use for work and some scrap board  so I'll see how it goes. Thanks
    @Bob Cleek. Having read all the advice given in this thread I understand that if I bought  a scroll saw  first it would help cutting frames for POF  projects  but with a different blade it could also be used for POB projects where it would be used to cut out the bulkheads, therefore I will save up for a decent parallel action saw. Until then I shall persevere with my trusty coping saw.
    Much obliged  to everyone for all advice , opinions and reccomendations .
  8. 15 minutes ago, Gaetan Bordeleau said:
    A good strategy would have been to wait and save.
    The road you took in a hurry will be more expensive:
    not only you bought a jigsaw, but you will probably buy a scroll saw in a near future.
    My strategy  was to sound out the jigsaw here before spending  my money.
    I have not bought the jigsaw and after @Bob Cleek input I will save up for a decent scroll saw.
    The photo I posted is a stock photo.
    But I thank you for your input
    Cheers
