Edwardkenway
Posts posted by Edwardkenway
  1. @SpyGlass Dont care what all you neat workers say - I keep a damp cloth to hand and I can wipe off white glue when I spread it everywhere .
    CA just attachs itself to me and everything else - but never just where I want it !
    I know what you mean😲😤
    @Vane great start !! As soon as I've got enough pennies saved I will get Speedy
  2. Hi, I've cut the top of the stern to shape, and dry fitted it, not completely sure about it!! There be some remodeling yet.
    The internal bulwarks have been faired, lots of dust and very awkward to do, and the first planks have been glued. Once the bulwarks  are planked I will carry on with the deck planking.
    Cheers 👍😀
    Thanks for the likes.
  3. Ok, so this post sees the window openings cut and the sashes made. I don't mind admitting that they have definitely tested me (and my old eyes). Hopefully they'll look better when the details of the stern are done, although I not sure whether I can do detailed  carvings.
    I'm just waiting for the glue to dry, so till next time,
    Cheers 👍😀
  4. Hi, it's been a while since I've been on the Xsection, but had extra couple of hours in the workroom so made up one of the gangways. The brackets are wood and not metal but I don't think it matters to much. I can't fit it til I've rigged the cannon. Still got the other one to make.
    That's next time though.
    Cheers.
    Thanks to all for the likes and looking in 👍😀
  5. Hi, just a small update, stern counter sanded, made a panel for the cabin windows and dry fitted,  I think that the scroll top needs another look at but that will be after I cut the openings for the windows.
    That's it for now.
    Thanks for likes, tips and opinions gratefully received.
    Cheers 😉👍
  6. Hi, a bit more re-modelling with the mahogany I'd put on for the main wale being changed for double plank construction in cedar as per Mark's suggestion as I was struggling to bend the thicker mahogany round the bow.
    At the stern, the counter is planked and I've also started to plank the gundeck and sort out where the hatches and gratings are.
    That's it for now,
    Thanks for likes and comments,
    Cheers
  7. Thankyou Phil it's appreciated.
    Thanks Mark, that is the better way for sure. I've fitted the opposite side that way but in the same wood as the rest of the hull so the wale will be painted black now. I don't know why I didn't get thinner mahogany instead of the 3mm but that's another lesson learned! The mahogany I have surplus now will no doubt be used elsewhere.
    Thanks for that simple solution that I didn't see 😖
    I'll post some progress photos on the next update.
    Thanks for the likes and comments 👍
    Cheers
  8. Hi all,
    Thanks for the kind words LS, I'm not too worried about a bit of deconstruction,  because it's how we learn and also if it's good enough for Dirk it can't be all bad😆.
    But yes I'm glad I caught it before I got to far on with the stern. Hopefully I've finally got the stern sorted now as it has given me quite a bit of trouble on this build.
    To have a bit of a break from that I've put the matt coat on the lower deck planking and fitted the beams for the gundeck , the photos don't really show the camber of the beams but there is one , honest!!!
    The main wale is going to be a slower fit than I expected as I've never attempted to bend wood this thick before,  its 3mm x 9mm mahogany  and if it looks ok it's going to stay natural.
    For the joints on the wale I'm doing the simpler scarf joint .
    Thankyou to everyone for the likes and comments, they are always welcome.😀
    Cheers 👍
  9. Hi, the stern frame that I fitted yesterday has been removed today as it was too high and the counter would not have finished at the level of the main wale,  also the great cabin windows would have been part of the taffrel and the cabin with no windows.
    It's been remodeled and set lower and the planking refitted to the framework.
    The counter will have a second layer of planking to tidy it up.
    The lower deck planking has had a scraping and a light sanding ready for an application of matt coat.
    Thanks for liking in and the likes.👍
    Till next time,
    Cheers 😀
