Everything posted by cog
Should anyone ... especially in a gale ... but those ladders are not so much different than the ratlines on a 74, I wouldn't fancy climbing those either, and to be honest, the forard mast will be a single "pipe" (the only way I have seen it depicted in photographs, so no tripod) ... and to help you up for maintenance, OC, with a ladder, which I for one certainly wouldn't climb!
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
Aye, so much better ... Eureka ... that happens once every while ... You have made some great progress blinging things up. When you look at it, the barrels are not really a challenge, neither a vast improvement, but the additional, undelivered pieces, e.g. the hatches at the back of the turrets, you use, to finish it,make it complete ... the cherry on the pie. Marvelous
- 405 replies
- tamiya
- king george v
on the tripod ... those are ladders, from a "spare" PE set of Musashi, if I'm not mistaken ... a lot more where that came from
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
Where ... nope, those are pipes mate, those funnel gards are worse ... a lot if you do not hav a steady hand
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
Now it really is a production line cigar tube ... You picked up spraying rather well OC .. a sterady hand, I like the result ... a lot
- 229 replies
- trafalger class
- airfix
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
Summertime ... and the livin' is easy ... Fish are jumpin' ... now I expect a whole lot more mr butts!!
Jack, I do not know the size of your grommets, but could you use a small drill like this to flare them:
You have come a long way from that crashed starting point, Michael. I wonder ... would she look even better than before the crash ... (shouldn't surprise me if she does)
- 749 replies
- albertic
- ocean liner
bluetack, two small dots on the bottom with some thin wooden sticks in it
- 229 replies
- trafalger class
- airfix
Quite an improvement OC. Hope your rattlecan turns up soon
- 229 replies
- trafalger class
- airfix
I think his house will fall apart when you yell "P EEEEE" Mine starts to look a lot like that ...
- 405 replies
- tamiya
- king george v
Nothing before OC !?!?!?!?!?!?!?!?!? oh dear ... deprivation ...
- 1,090 replies
- showcase models
- vendetta
Pat, he gets HSI, and ESI At least you got value for money, Greg, kept you busy for quite a while ... See you got rid of that humongous signature too, I hated the thing, every build meant I had to update. I know what I build, it shows (or not, depending on the quality, so very little shows)
- 405 replies
- tamiya
- king george v
Thanks for sharing, which will mean likewise for NZ and Canada still had the RN Ensign
- 1,090 replies
- showcase models
- vendetta
Jack, you see, the sqealer is picking again
- 1,090 replies
- showcase models
- vendetta
There must be a lot of unsolved crimes downunder ... I suddenly realised you ripped off the ensign, RGL, and you replaced it with a British version, I went back to verify, why if Vendetta is a RAN vessel ...
- 1,090 replies
- showcase models
- vendetta
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
