Everything posted by Mirabell61
HMS VICTORY 1759 by isalbert
Mirabell61 replied to isalbert's topic in - Build logs for subjects built 1751 - 1800
Beautiful precise work Isalbert, you must have many years of experience in historic shipbuilding, building the mast parts says it all...... I joined in after the great crash, when when MSW V2 was already under way , so unfortunately I did see your early build sequences, trust I`ve missed something.. BTW may I ask, where is your Location ? Nils -
Hi Piet, thanks for your word,..... I just had a look at your current Project "Surabaya", a very fine looking model, and all in own design, hat off, its going to be a beautiful representant for the VOC fleet. I also liked your introduction thereto.... Nils
Piet, Congratulations on completion ....... of this lovely submarine model. It has been a great pleasure in following the appr. 2 years of build sequences, learning submarine-details that seldom pop to the surface, also your fine pics and the explaining remarks. In all a lovely model, thanks so much for sharing this build with the gang Nils
Thank you Martin, at the time I stood before this point, there was unfortunately no advise available, but I knew Peter`s mind went pregnant with the thought....., and you`re right, luckily now its solved I`m sure that one is saved in your mind, If you have doubts, you can make yourself a Little mock up mast and Yard dummy with sling and trusses, so first : you did it and second : it stays in mind for your "Fly" build sooner or later anyhow (do`nt take it seriously, smile....) Nils
Thank you very much Bob, I gladly would like to return the appreciation when sighting your outstanding "Essex" rigging Job, especialy when there are tricky details, and to see......Aaah, thats how he did it / solved the point... Cheers Nils
Amazingly detailed kit Bob, following the assembly of those wooden joinings, the quality of the wood and your very talented skill makes this model a speciality with a wonderful exotic touch Well done ! Nils
- 196 replies
- higaki kaisen
- woody joe
Harriet McGregor by Boccherini
Mirabell61 replied to Boccherini's topic in - Build logs for subjects built 1851 - 1900
thanks Grant, very neat coppering work, good Job ! Nils -
HMS Alert 1777 by Jaekon Lee - 1/64
Mirabell61 replied to Jaekon Lee's topic in - Build logs for subjects built 1751 - 1800
Wunderbar Lee, you certainly have the feeling for what makes ones heartbeat increase....... Lovely ! Nils -
Hello Peter, very kind of you for using that opportunity in Venice and following up to the yard arrangement when bracing........., Thank you very much ! This is how I did it.... As unfortunately neigther Lees`s nor Lennarth`s highlight this point in their books, I did it by the truss-tackles, (loosening the weather side and tightening the leeward Truss until the yard gently touches the most fore leeward shroud), The pics will show.... At The leeward side the yard comes to fit about in the vertical level where the catharpin sits, just under the futtock shrouds, this is sort of a waist in the shrouds and allows maximum bracing on leeward side In the vertical hight the yard is securely positioned by sling and jeers. I trust it looks quite realistic I know in the meantime that also on some british ships the first one or two shrouds on each side had an integrated additional tackle to loosten these perticular 2 first shrouds, so they do`nt foul with the yard. In the german version of Wolfram zu Mondfelds publication (in case you have.... this is also shown on page 301 ). It was too late for me to adopt that at time of building... Mostly the modelers do`nt brace the yards, so this point dos`nt raise questions for the unbraced.... Nils here the weather side truss allows the yard to move a Forward distance at appr. a masts diam. (corresponds exactly with what you noticed in the museum) Here the yard touching the first shroud, but not fouling it, in hight of the catharpin under running # 3 on the scetch drawing (Mondfeld) it shows the first two shrouds ready for to fit an additional tackle, so the deadeye lacings at the channel need`nt be loosend as well
Go ahead with "Symphony" Patrick, beautiful name for this new mini project of yours, the boats lines promisses a symphony of hull shape...... Nils
Beautiful work on the hull Grant, This is going to be a very fine ship. What did you use as plates for the coppering ? perhaps copper tape ? Well done ! Nils -
Hi Mick, very nice start and Progress on Cheerful and pinnace..... Planking on pinnace Looks great Nils
- 25 replies
A delight to see this Lee, Nils -
Many thanks Yancovitch, for dropping in to my log and your kind appreciation, you`re always wellcome.... Nils
beautifuly built Patrick, the sail reinfoircements look good, (quite difficult Task in that scale) Nils
Bob, your rigging Looks very good, neat, accurate, taught lines, and realistic run of lines, shall love to see more when your logistics are replenished.... Nils
- 1,477 replies
- essex
- model shipways
Mark. I thank you very much for your nice appreciative comment and you`re always wellcome to drop in for catching up..... Nils
Thank you very much Jbwok, I`l be looking at your progress with HMS Warrior with interest and wish you ongoing good success with it Nils
Lovely Ed, real lovely work, I would spend quite some time only for looking at a fantastic model like this in a Museum if there were........ Nils
- 3,618 replies
- young america
- clipper
