Everything posted by Mirabell61
Build log part 41 the shroud wire alignment in relation to the mast belaying Points is pre-checked with ordinary strings after belaying all the running rigging the deck shall look more busy the depth indicator scales are made with my regular Microsoft Excel program on photo print paper portside shrouds and backstays under way, also ratlines in the upper shrouds Build log Part 42 to follow.... Nils
- 222 replies
- gorch fock
- barque
Build log part 40 view on inner port bulwark side with pinrail and shroud- and backstay spanners the yellow boom is just a Yard laying at the wrong place started to rig the bracing ropes the mainmast running bracing ropes are lead over the aft bumpkins starboard foremast backstays Build log part 41 to follow.... Nils
- 222 replies
- gorch fock
- barque
SS Vinal Haven by TBlack - FINISHED
Mirabell61 replied to TBlack's topic in - Build logs for subjects built 1851 - 1900
real nice looking ship Tom, also the two boats look very realistic Nils- 326 replies
- vinal haven
- steam ship
congrats Patrick a proud ship and a proud builder.... well done ! Nils
- 299 replies
- niagara
- model shipways
Michael, I was already expecting that question related to the blocks already since the Pamir`s rigging pics had been posted. I once was on search in the web and at Ebay Shops for this type of equipement and finaly found quite a lot of items that with a Little Tuning only would well suit my Needs, an this all at peanuts priceing.... When sighting the articles available at the Ebay sections for Fashion jewelery equipement I discovered Little metal beads of all sorts in diam. and Color. These I use for solderingthe wire chord Ends to the shroud spanners. Criteria is the Little hole through the bead. The beads are very well solderable (clean Ends and sufficiant flux) For the single sheaved blocks I use metal double-Loop capsule type bead knot covers, which are available in different sizes Colors quantities. As rollers I again use metal-beads that resemble rollers also in sizes to suit the bead covers. Shall enclose a scetch for explaination.... I would though not use These for historic wooden shipmodels, here Chuck has the correct ones in his Sortiment. For the mini shackles I use an article from the beadsshop made of brass, nickel galvanized, shall enclose a link cheers Nils http://www.ebay.de/itm/20-Stk-Verbinder-Kettenglied-9mm-nickelfrei-H77-/120407595118?pt=Schmuckgestaltung&hash=item1c08da186e use bead knot cover "blocks" either for hooks, single sheave blocks or blocks with 2 fastening sides
- 222 replies
- gorch fock
- barque
Nigel, many thanks for sharing that link comprising Jimmy Woods work, you`re right, that is very interesting for me as well, and I`ll take myself more time to study and explore that site more intensively. I love those modelers who build machinery from scratch, modern or historic. I also built a steam river tug with selfmade gas fired Boiler and driven by a self designed and made V-type arrangement 6 cylinder steam engine for RC control. Unfortunately I had a leakage in the Boilers superheater tube coil, and so the model is sitting idle on the shelf for many years already. Nils
- 222 replies
- gorch fock
- barque
Build log part 39 mast top lower top platform here with Counters for upper shroud spanners made several mini shackles for Multi usage Build log part 40 to follow... Nils
- 222 replies
- gorch fock
- barque
Michael, thats a a nice rememberance to your mind. The mainsheet block shall look great when its done Nils
- 2,215 replies
Thanks for your nice comment Nigel, I found out that doing models in finer scale than 1:95, max 1:100 is not so well producable for me, too much fiddeling and fagile parts. A Limit of course is the length of an actual ship...., for example I would love to challenge in doing one of those famous 4-stacker Atlantic liners between 1900 and WW1. I have already a beautiful plan for Cunards quadtriple screw "Lusitania" in scale 1:200, that could be magnified, I fell in love with the lines...., but still its a beast in model-length, let alone in scale 1:100, would Need an extra room for that. Nils
- 222 replies
- gorch fock
- barque
Build log part 38 poopdeck handrail Prior to sanding and varnishing wheel to auxiliary rudderstand decks nearly completed nav sight-bearing devices on pods next to the raft containers handrails complete all around poopdeck mizzen mast top shroud wire chords a few hundred blocks (in total) for all the sail operating running rigging spanners for the upper shrouds of foremast Build log part 39 to follow... Nils
- 222 replies
- gorch fock
- barque
Popeye, the railing assembly is always quite a fiddeling session, and when those thin stanchions are bent too often they simply break off. I consider about 5-10% spare when purchasing... Nils
- 222 replies
- gorch fock
- barque
Michael, in total it must have been appr. 1600 manhours, but not continously building, because the Pamir was pulled up inbetween, whilst the Gorch Fock stood waiting, so that both ships nearly had the same sequence Level and I could do common practice withe the sailmaking, etc... Cheers Nils
- 222 replies
- gorch fock
- barque
Build log part 37 the anchorchain-stoppers choke type, with spindle in combination with electric spills and Spill band-brake device forecastle deck now ready for operation Crew in Trial positions because of the Motor there must be an machine telegraph operator poopdeck railing nearly completed continous Progress.... Build log part 38 to follow.... Nils
- 222 replies
- gorch fock
- barque
ROYAL CAROLINE 1749 by Doris - 1:40 - CARD
Mirabell61 replied to DORIS's topic in - Build logs for subjects built 1501 - 1750
Doris , Thanks so much for those Close up pics of those absolutely fantastic mystic figures, its like in fairyland even with my 66 years Nils- 883 replies
- royal caroline
- ship of the line
congrats Karl, a great tool that Proxon lathe, someday I think I will invest in such myself Nils
- 662 replies
- bonhomme richard
- frigate
Build log part 36 the forecastle stairs will not be permanently fixed until the frontmast rigging in that area is done, due to Access Problems otherwise view without the boats uncomplete forecastle deck, the portside only bears an nostalgic admiralty type anchor shortcut Access to boatstations also directly possible from welldeck portside welldeck Forward view the stairs to poopdeck shall be integrated into the railing Build log part 37 to follow.... Nils
- 222 replies
- gorch fock
- barque
Mauro, Plankings Looks good are you going to fill the plank gaps in some way when the Planks are all laid down ? Nils
- 111 replies
Build log part 35 starting the brass railings with 3 hole stachions and 0,4mm wire from the spool shaping a duct for the potside anchor ...and on towards the boatstations front mast goes through the deck here the two boats are hanging outwards but also can be swung inwards fit in the forcastle stairs (to be soldered with the railing, later on ropedrums attached railing continued around the boatstations and up to the liferaft containments Build log part 36 to follow.... Nils
- 222 replies
- gorch fock
- barque
Build log part 34 Davits fitted on poopdeck walking Planks at boatstation again the wheelstand portside boat rigged all boats on... Build log part 35 to follow.... Nils
- 222 replies
- gorch fock
- barque
Build log part 33 nav. light containments mushroom type vents on the deckhouse top slowly having all deck Fitting-out placed front of poopdeck with main wheelstand two additional raft containers still lots of space on the welldeck the White round item is not the cooking pot, its the mother gyro-compas containment White tipped Ends... Builg log part 34 to follow.... Nils
- 222 replies
- gorch fock
- barque
