Mirabell61
Everything posted by Mirabell61
  1. Many thanks to Pete and Mark, and to all who clicked the "like" Button... today I made the hand-bilge pump, which discharges into the centerboard case, and the upper sill of the centerboard case Nils
  2. thank you very much Johann, I had a look at your "La Creole French Corvette....., fantastic work, amazing shipwright handcraft.. Nils
  3. Thank you Pete, Yes there will be several cuts, also in the cabin area giving view to the whole interior. Thanks again for your link to the screw heads, great idea I think.... Nils bolts holding the gear housing to the machine block, and silicone rubber dampening pads slicing off the round heads with hexogonal sockets exhaust to outside (well above waterline) screws for exhaust tube flange to cylinder
  4. Thank you very much Geert, will start with the removable engine bonnet, that will have some outcuts so the engine remains visible. Have also added silicone shock dampener pads for bolting the engine down, and with reference and thanks to Pete`s suggestion I received the small panel with dummy screw heads, these are also installed already, as well as the prolonged exhaust tube that is now leading to the outside hull planking... Nils
  5. not much progress this tme.. the engine is complete and the sockets for main- and aft mast set in place Nils the mesh fish boxes have been chemicaly blackened the V-belts are from sealings for wrist watch covers added an oil dipstick upper right corner : day fuel tank ca. 20 Liter
  6. looks very promissing Pete, lovely large scale, I`ll be looking in... Nils
  7. Hello Frank, Beautiful work, she`ll be a wonderful ship...., when completed Nils
  8. Thank you Pete, I know sometimes I get lost in details, but if the time for completing is not pressing I can try and realise some of the thoughts I have saved in mind, and its a lot of fun. The tuc- engine is the little heart of the boat. Your name suggestion is not bad, but I intended to call her "Lorbas" as this name was not yet registrated for heritage Zeesboots list, to my knowledge Nils
  9. Very nice drawings Jim... Nils
  10. lovely work Ken, I like your ship, nice clean modeling !! Nils
  11. Many thanks for the link Pete, I found the set A straight away and ordered already... Nils
  12. Wonderful work Danny, I`m totally amazed of the lot of technical parts, their function and how this was designed into the card model, let alone your skilled performance on the assembly, sehr gut gemacht !! Nils
  13. Thanks Slava, yes, I`ve read that somewhere before, think its in combination with RC models on a pond or lake.... Nils
  14. excellent work Gary, the wheelhouse planking has a nice wheathered touch... Nils
  15. Slava, a pitty it does`nt run, I would love the sound, tuck, tuck, tuck...... Nils exhaust tubing, Muffler and tubing through aft bulwark above waterline
  16. Thank you very much Pete, Geert and Eberhard, your answers and input are very much appreciated.... Pete, model locomotives and marine craft in G scale often have details that can be adopted of another.. I went looking for polysterol screw head imitates (your pic...) but could`nt find them in the web net, do you kindly perhaps have a source (link) ? Geert, As I could only model the engine from Photos I found on the web, this was my best effort to produce something alike in scale 1:24, am pleased you like it Eberhard, I remember , when doing the bolts with dome nuts, that connect the blades to the hubs ((KWdG model) I worked a bit like you described in your "pre lathe days". Instead of nails as base material I used quite small hexogon brass bar. Many thanks for your kind input here... Nils
  17. Many thanks Slava, and for looking in, have`nt heard from you quite some time now, nice to know that you`re watching this build..... I`m still working on the engine, installed generator, water cooling pump and tubing and fly-wheel, more to come the next days... Cheers, Nils
  18. thank you very much Peter for your appreciative words, I`m pleased you like the engine... Yesterday I received some brass etched fish for the catch together in scale 1:25, with two fish box kits (sides get folded and soldered together). For the fish there needs to be some uppadding, which will favorably will be done "Fimo clay" that can be baken for curing, before the fishes get painted. I decided also to produce some eels in appropriate scale made completely from Fimo clay. Trust that all together this will enhance the working boat character, when done... Nils
  19. Thank you very much for your nice comment Mark, the small parts of the engine are taking more time than I thought....., I wanted to do the dome nuts for the cylinderhead from small brass hexagonal brass bar but it looks like I lost the remaining bit I still had. In the meantime the housing was painted and I`m working on the cooling tubing with connection to the water pump. Generator and its terminal box are also painted, need to do a bit of wiring, and I`m looking for a suitable mini V-belt or two, perhaps the thin sealing "O-ring" for wrist watch glasses can do for this. I`ll have to see the jewelery shop in town if he has some old ones in his scrap box... Will post some more pics when I have all things together Nils
  20. Hi Peter, thanks for looking in. No, its by far not the completed model, engine, cabin, deck, the whole rigging and sails and may others are still to be done. I gues its about 50 % done to date. The pics are showing the raw motor in build, painting, wiring, tube connections etc. transmission per V-belts and flywheel still to be done..... Also thanks to all that clicked on "Likes" Nils
  21. wonderful rigging of the guns Thomas, you did a good job there ! Nils
