Papa
Posts posted by Papa
  1. I’ve been working on this off and on for a while and finally decided to post some progress photos. It’s an older kit and has a lot of flash.  I had a great deal of difficulty getting the bombs to stay on the rack and finally gave up and used the closed bomb bay doors option. I also decided not to obsess over the seams. I am just trying to keep this an enjoyable break from ships.
  2. After drilling holes for the shrouds in the first channel I decided it would be better to wait until I was rigging to ensure the holes end up in the correct locations.  All the davits and such will go in much later in the build or I will surely break them off.  Starboard is in good shape, and the channels are installed on the port side also. I think I’ll go back to finishing the deck furnishings next.
  3. “the lower end of the stays and coil them up for rigging later.  Just be sure to accurately place the eyelets and leave more than enough rigging. Here is what I did on the anchor deck. “
    I thought about doing that but in then end figured this would work best. Being a worrier I’d have left about a yard of extra line to get in the way.
    i started the steps to the anchor deck.  And once again realized that I should have waited to install the  windlass until after the bow work was completed. 😬
  4. On 4/25/2020 at 8:36 AM, vossy said:
    Hi Ron,
    how about getting some ultra thin strips and planking over it? You can get strips so thin they are almost like paper. If it was me, I would be trying to keep it unpainted. Strips will cost next to nothing, and if you muck it up, then paint it. If you do have to paint it however, I would go for a brownish base and try to weather it a bit. Be more realistic I reckon.
    Cheers
    Chris
    After much thought I decided to follow your advice. I ordered some .6 mm walnut strip wood from Model Expo and will replank the lower part of the hull.  There is a thick wale that separates the bad part and will make a natural stopping point.
  5. After at least 5 attempts I finally got the cheek timbers and bolster in place and looking like the photo of the Morgan in the instruction booklet. I the process I installed and then had to rip out and destroy the hawse castings. Now I am waiting for replacements from Model Expo.  Love their parts replacement policy!
  6. 18 hours ago, Jaager said:
    A shallow search indicates that Spain did not mine asphalt for another 200 years, so the pitch was probably "Pine" tar.  Dark, but not 000,000,000 black.   The proportions of dark brown and tallow are maybe lost forever or in the Spanish archives,  but see what 50:50  dark brown to tan nets you.
    thanks for that information.  I'm not ready to paint it yet. I am working on the parts that made me give up years ago.  The SM has timbers on the sides of the hull.  The plans called for making them out of square strip wood, 5/32" maybe (not near the plans now). No matter what i did i could not get those pieces to conform to the hull.  Recently i decided that i would make them by laminating thin layers.  I think this is going to work.
  7. I have decided to finish my Santa Maria kit that I put aside more than 20 years ago out of frustration. My biggest issue now is that the wood on the lower part of the hull is very blotchy. I made several messes with the planking and did a poor job staining which I then tried to correct by bleaching and sanding it out.  My question is: would it be appropriate to paint the lower hull an off-white.  The Mini Mamoli kit of the Santa Maria shows the lower hull painted white. All the other models I’ve view are natural wood, but that  just isn’t going to work.
    I purchased the kit at the 500 anniversary of Columbus’s voyage in 1992!
    Ron Gove
  8. A word of advice, learned the hard way😬.  Drill out and install the hawse pipes and mooring ports BEFORE installing the windlass assembly.  They are very much in the way.
    Second lesson: Remember all those laser cut parts you looked at when starting the kit.  I forgot the knees for the windlass were already made for me!  I scratch built them.  Good experience i guess  Perhaps I should have made notes on the plans and instructions about all those parts.
