Posts posted by Papa
Turned out that the scale was too small to use the bandage stuff. I just wrapped some thread around the stay and made a reasonable approximation. Good enough for my old eyes anyway.
- thibaultron, mtaylor and Canute
3
Love your cute little helper dog.
- mtaylor, BETAQDAVE, Old Collingwood and 1 other
4
- cog, Canute, nancysqueaks and 2 others
5
I need to make a mouse for my Granado. This looks like a good technique.
- thibaultron and mtaylor
2
On 10/18/2017 at 10:55 AM, Cathead said:
Ragove, that's interesting that you had quality issues, as I didn't. The only part I broke was the very thin port-side door frame which sticks up alone for part of the build, and that was my fault for rough handling. I was able to reattach and brace it with no problems. Otherwise the frames stood up well to sanding and shaping, and the planking material was strong but flexible.
I did hear from Nic at BlueJacket (I hope it's ok to share this) that the kit is due for an upgrade, which would be exciting as it's fundamentally an interesting model and well worth building.
i purchased the kit around 2008, I think it was, when we were visiting Maine and I stopped into their facility in Searsport, ME and got around to building it just a couple years ago. Perhaps the kit had been up-graded since that time. It might even have been a Laughing Whale kit in a Bluekacket box.
I have a Laughing Whale model of Slocum's "Spray" that I had been sort of reluctant to start. I just re-read his "Sailing Alone Around the World" and that has encouraged me to give it a go.
And I should add: Cathead’s model looks fantastic. Could be taken for a real boat with some clever photoshopping
- thibaultron, John Allen, Cathead and 2 others
5
I also built this lobster boat and had similar experiences as cathead: bulkheads not correct and needing shims etc. I also thought the plans were very poor and the instructions often bore little relationship to the plans. The wood was brittle and I was constantly fixing broken parts. Over all I was very disappointed with the kit, as I have been with other the Bluejacket kits I built: ironclads Monitor and Virginia.
- thibaultron, Cathead, Duanelaker and 2 others
5
The detail is amazing. You have a steady hand and a sharp eye. This model just blows me away.
5 hours ago, Dan Vadas said:
If you intend using that cradle, I'd suggest you cut largish 45 degree angles into the uprights - they look like they will restrict your reach somewhat. I can see bruised wrists coming up
Danny
Don't think that is necessary, the cradle is foam-core poster board so not likely to injure me. But, point taken, the edges might get in the way. I will see how it goes as i progress. Not sure what to do for a permanent mount if she ever gets finished.
- Captain Slog, Canute, mtaylor and 1 other
4
Now that I have nearly finished the hull I have learned some valuable lessons.
1. Use white glue VERY sparingly.
2. Keep your workspace spotless so that you don't lay a critical part on some wet paint
3. Thicken the bulkheads or add lots of longitudinal bracing so that all of the hull plates lie smoothly.
4. Trim the seam-hiding strips so that the additional armor plates do not overlap and leave an ugly bump.
5. Write part numbers on the back before cutting out.
I can't wait to see what I learn as I attempt the deck furnishings.
- mtaylor, ccoyle, Old Collingwood and 2 others
5
- cog, Old Collingwood, John Allen and 3 others
6
On 10/4/2017 at 1:32 PM, cog said:
Welcome ship mate! I 'm glad to be of service
Thrilled to meet a new face. You might take a look at RGL's (Greg Lester) mind blowing build logs - I do too but I don't tell anybody
Do you have a build log here at MSW?
Cheers
I did a log on the Chaperon by Model Shipways and I am doing a paper model now--Helgoland
- popeye the sailor, mtaylor, Piet and 3 others
6
Impressive work. I will have to pay attention and perhaps learn something. My plastic models never come out well.
- mtaylor, popeye the sailor, Piet and 3 others
6
I fill the larger cracks with slivers of wood. They blend in very nicely when sanded.
SMS Helgoland by Papa - Modelik - 1:200 - CARD
Posted · Edited by ragove
There are some tiny pieces in this model! I have to cut out and attach 16 of these little buggers around the funnels.
