Posts posted by Papa
- russ, Tigersteve, coxswain and 6 others
- 9
- popeye the sailor, coxswain, russ and 4 others
- 7
I have attached most of the decorative railings. Everything fit perfectly together. The skylight is done and attached. I assembled the skylight fully before attaching to the deck to ensure that it was square. I am working on the Texas (which I placed on the skylight for the photo). I decided to assemble it before adding the 1/32" sq. battens. The battens are a bit more tricky to add this way but I was concerned that they would interfere with bending the fore and aft sections. Although the sections are pre-bent using a supplied jig, there is a lot of fiddling to get the curve right when everything goes together. Since the battens are laid over the grooves that need to expand as the sections are bent, i thought it best to do them last.. I may actually get this model finished in less than 1 year! I appreciate all the "likes" and comments.
Ron
- popeye the sailor, Cathead, russ and 5 others
- 8
- russ, popeye the sailor, Tigersteve and 4 others
- 7
Thanks Blighty. It has been a fun build. A great vacation from rigged ships.
- Cathead, Blighty and popeye the sailor
- 3
That must have made for some messy stern wheels! I guess I need to get some model chickens for back there!
So it is literally a chicken coop? Wouldn't that need some ventilation. I thought it might be for a "seat of ease".
- russ, Blighty, popeye the sailor and 5 others
- 8
Well, Thanks. I hope I can keep up with frequent postings.
- hexnut, coxswain, Tigersteve and 6 others
- 9
- tasmanian, GuntherMT, Tigersteve and 10 others
- 13
MikeB4,
Of these 4, I have only built the Latham. Planking was not too difficult since there are no real sharp bends and the planking directions were very clear on how to taper the planks (My memory is not great and perhaps I followed the directions in "Planking the Built-up Ship Model" by Jim Roberts). I think the Mayflower would be the most difficult because of the extreme curves at the bow. I gave up on my Santa Maria model since i messed up the bow planking so badly, and it has a similar hull to the Mayflower. The Whale Boat might be the easiest simply because it is smaller, on a larger scale and less to plank over all. Anyway, that's my 2 cents.
Ron
Leesburg, VA
Thanks Kurt. You are correct about the rain, unless they added scuppers. Anyway, flush is much easier.
Ron
- mtaylor, popeye the sailor and Canute
- 3
I have a question from anyone who has built the Chaperon. It is not clear to me if the cap rails that are bent around the edge of the boiler deck are to be installed flush with the deck or centered on the edge of the deck. Any advice will be much appreciated.
Ron
- popeye the sailor and Canute
- 2
- jbelwood, mtaylor, Ryland Craze and 8 others
- 11
Rob,
You say a fair time ago, if any company warranted a part with a time limit I would say the part would be replaced in that time frame. How long is a fair amount of time. Not to cause a hullabaloo but you may not be fair to Model Expo in requesting a new hull that is not defective but hacked by a previous modeler.
It is not a perfect solution but you may be able to use a filler, wood putty, and reshape the hull. and a repaint may not be perfect but this was an older freebie.
My thoughts, no disrespect intended.
John
I totally hacked up the dory towed by the Benjamin Latham. ME sent me all the parts for a new dory and it had been more than 5 years since I purchased the kit. I think they really want you to finish their kits because then you are likely to buy another one.
Ron Gove
- EJ_L, mtaylor, John Allen and 1 other
- 4
Tut tut ....brain fart..that's a new one on me in what way dose this function work I mean it sounds qwite sereus contion poor old you is it painful have had it checkt out. Whatever its qwite a croud turn of frase a bit nicer could be mind blank or well some thing nicer robin
don't you thinke
OxfordDictionaries.com: Brain Fart: A temporary mental lapse or failure to reason correctly.
I didn't know how else to explain my stupidity on this issue.
Chaperon by Papa - FINISHED - Model Shipways - Ron Gove
in - Kit build logs for subjects built from 1851 - 1900
Pilot house wheel under construction using tooth picks and styrene. Not prefect put it is mostly hidden anyway.
