yamsterman
Posts posted by yamsterman
- hexnut, JpR62, paulsutcliffe and 11 others
14
- paulsutcliffe, JOUFF, mtaylor and 4 others
7
Hi alde
Thanks for dropping by
Its nice to make some headway.....dont seem to get much time these days.
The little brass plane is a small thumb plane or more correctly a luthiers plane.
I will upload some more photos.
I think the brand name is e.s.e
Its only 1 1/4 inchs long by 1/2 inch wide.
Cant remember where i got it from.....definitely pre internet days.
Cheers...mick
- hexnut, GrandpaPhil, alde and 18 others
21
ha ha
the master returns!!!!!
i hope theres a seat left at the front.........ready for another masterpiece to emerge
cheers ....mick
- albert, mtaylor and billocrates
3
hi al
with regards to treenails....where possible i will always use my trusty proxxon 50/e.....however sometimes you just have to do it by hand with a pin vice when the drill just physically wont get into a space.
as to depth, usually a couple of mm is all thats needed......model makers treenails are purely representational so no need for any strength,especially with modern wood glues.
yep its ebony!......and boy is it a pain to work with!
but i love the end result.
the wales on washington are 1/8 inch thick if i remember rightly and those were made from a three pieces of ebony. the middle section has a very slight curvature to it but the bow section had to be heat bent to shape in two dimensions ie a bent and twisted.....the rear section has more twist than bend.
so long as you can find a piece with nice straight grain it does bend quite readily under heat.
i take a lot of my inspiration from european modelmaking school eg bernard frolich to name but one....i like the contrast between pear holly box and ebony.
i may have to go down the route of staining pear though as ebony is becoming extremely expensive.
hope this helps al......shall be dropping in to your build from time to time to see how your getting on.
cheers....mick
hi carl
my metal working is positively ginormous compared to your origami in 1/350 .
dont know how you see the parts never mind bend and shape them.....even with magnification the air in my vicinity would be extremely blue and littered with tiny bits of brass shrapnel!!!!!
nice to see you building though!
cheers....mick
hi all
some more progress to report.
iron work for the breeching ropes done and fitted...quarter deck finished but not yet fixed permanently
ive made a rough start on the capping rails....more work to do on those yet
still lots to do .....all the fiddly stuff now!!
ive put a few deck fittings in place but nothings fixed as yet
cheers for now ....mick
- davec, albert, Seventynet and 15 others
18
hi al
i always use the same wood for treenailing as the planks are made from........much more subtle than using a contrasting timber.
the wale strakes i tried something different by way of an experiment....the treenails were made from copper and then blackened with liver of sulphur.
the result was quite pleasing the teenails almost disappearing ,but just visible at the right angle.
cheers....mick
hi all
quarter deck has now been finished.....more or less.....it wont be installed until all the ring bolts are made and attached.
rear windows are in but not yet glazed.
now to spend some time clogging my files with copper....time for the iron work to be made!
photos as per usual
cheers for now....mick
- oneslim, Tigersteve, davec and 15 others
18
hi all
time for an update. inboard has now been planked and treenailed......cleats have been made and fitted....took three attempts to get those little b*******s looking right.
deck fittings have been placed purely for the photos.
work has started on the quarter deck
next up will be the iron work....eyebolts,gunport hinges etc etc. stocked up recently on copper tube and sheet ready for the marathon blacksmith session to come
still plenty of work to to but were getting closer to the finish line!!!!
photos inc as per usual
cheers for now......mick
- Magellan1520, Canute, cog and 10 others
13
WASHINGTON GALLEY by yamsterman - 1/48 scale - POF
Hi carl
Violin planes,good ones anyway,are pricey.....ibex is a good brand
Steer clear of some of the far eastern stuff...some are good but most are dodgy.
Well spotted its not brass but copper...easier to work and easier to blacken eith liver of sulpher.
I shall make the anchors from copper as well
Still bending impossibly small bits of brass?
Cheers for now....mick
