FlyingFish
Posts posted by FlyingFish
    After cutting out on the scroll saw, each futtock is sanded down to within 0.5mm of the line – this should be enough for the bevel. The ends were squared on the disc sander. The tweezers are for retrieving futtocks that go down the pipe into the shop vac and end in the pre-Cambrian layers of dust.
    Frame pairs 15- 25 ready for assembly. Only another 28 pairs to go. It’s been a productive day. And England won the first test match against India.
  2. Framing
    The weather has warmed a little, so on with the work. The frame templates have been drawn and printed. It has taken many days of happy work and sticky fingers.
    There is a set for aft, centre and fore to enable the double frame to be assembled.
    I learnt how to set up the CAD to print more efficiently and produced a second set without needing to paste into an A1 sheet. Then the job of cutting these into floors and futtocks to lay out onto the stock timber was straight forward.
    A corner of the shop has been turned into a frame assembly factory. There are ten frame pairs in this shot:
    Trying to make the best use of the grain and material:
    Once happy with the layout, its ‘Pritstick’ time! Next job after this is to stock up on scroll saw blades.
  3. I have used this company for wires for fly tying - the coloured copper wires have kept good for years, and they also do tarnish restitant wire, including silver plated, and cotton covered annealed copper which may have a use too. Sizes go down to rediculously small.  I'm sure a similar supplier can be found in the US, and elsewhere, but it does show what a variety of materials is available.
  4. Thanks Gary, yes they certainly do. I visited yesterday to survey the geometry of the counter timbers which they are currently installing. I'll post some pictures of this when I get to it. Meanwhile I am beginning the framing, but limited due to the temperature of the shop which is a bit 'nippy' at the moment.
  5. It looks very nice Hakan!
    Regards planking, I've not found much in researching Vigilance, which predates your boat but has much the same design. As working boats, cost was important - can't see them cutting an oak plank down without good reason, and the longer the stronger, being single planked. I think they would run 20 - 25 feet if they could, and probably had a pretty loose formula on butt shift.
    I agree with Eberhard - especially if it coincides with a missing frame.
    Hope the temperature rises for you soon!
  6. Centreline Layout
    Finally get to start building.
    Scantlings 1:1
    1:32
    Keel (oak) 12.75” by 8”  in 2 No. pieces  Joined by 4’6” stopped scarf
    F. Maple 9.7 mm by 6.35 mm
    Keelson 10” by 10”
    F Maple 7.9mm by 7.9mm
    Stem 19” by 8” tapering to 12” by 8”
    15.1mm to 9.525mm by 6.35mm
    Stern post (Oak) 8” sided, 15” moulded at heel, 10” at head
    Holly 6.4mm sided, 12mm at heel, 8mm at head.
    Horn Timbers 6” sided by 6”, trapezoid section below to follow planking. 16’ long.
    Holly 4.7mm sided. Swelling at knuckle and shaped to match planking. 152mm long.
    Deadwoods (elm) 8” sided. Stemson knee 6” sided.
    Holly 6.4mm and 4.7mm sided.
    Parts ‘exploded’ in CAD.
    Keel, and keelson in maple, and the rest in holly.
    It doesn’t come out well in a photograph, but this shows how the holly (wider piece) with the grey fungal stain can imitate oak better than the maple, which will take more staining work:
    The stern deadwoods were original, and I had a rare opportunity to copy them accurately:
    image.png.3ecf3523838a6897b98f2e4464ac167a.pngimage.png.adabbf9cd69fc6550ac2cb665080488b.png
    The knee upon which the mizzen mast-step resides may need a shallower angle, hence the optional piece.
    Thanks to Ed T for the inspiration to build a proper jig. The stem support jig is an example of over-engineering due to being shop-happy after so many awful wet days here. After some fresh air I made a forked stick for the stern.
    No excuse to put off framing now!
  7. On 12/26/2023 at 8:37 PM, Keith Black said:
    Sometimes the result is more suggestion than 100% accuracy
    Tremendous work Keith - I agree wholeheartedly with this, although it does look very 'on scale' and I particularly like the lack of 'fuzz' on the ropework - a sign of attention to detail. Really enjoying seeing it come together.
  8. Your third image give a real sense of the size of this model - I'm excited!
    1 hour ago, KeithAug said:
    I didn't find any of the usual solvents worked particularly well on pritt stick
    I don't think they are solvent based... I've found a washing-up sponge (scotchbright side) damped with soapy warm water works as well as anything.
  9. Thanks Keith, Keith and Wefalk, and for the likes. I'll put the lamp base on hold for now, Keith 😅
    Centrelineline (dis)Assembly
    As a break from lofting frames in CAD, there’s no reason to delay laying down the centreline. If, like me, you have ever struggled to assemble a centerline accurately and dead straight, then cast your eyes over this!
    Stirling’s Yard replaced the centreline of Vigilance as the first step to rebuilding her, whilst keeping the rest of the boat intact.
    The next few photos (credit to the ‘Friends of Vigilance’ facebook site) are from their pictorial record of works.
    My efforts to will follow in the next post and should be a great deal easier!
    Boat propped and held in position – this photo gives an impression of her size.
    Looking aft; keelson and knees removed; floor bolts being removed.
    337541664_745718740594805_4160089894474485851_n_1280.thumb.jpg.0781cb85b286ebcde121f64cad413f9b.jpg
    Garboard and next two planks removed. Keel removed in sections, and hull supported on chocks.
    338707039_212711928109432_5835937135093581086_n_1280.thumb.jpg.c255a287b96d488825803dd4d4292701.jpg
    Stem and deadwoods taken out in one piece.
    411483089_884482990345898_2850442512449405717_n_1280.jpg.5389b39818233b1f4eea3d55b123dbc2.jpg
    Stern deadwoods removed.
    New keel prepared
    ¾” rebates for heel of floors
    338674106_768481744794544_1645297694529329834_n_1280.thumb.jpg.4af8147183544af91871ad6f3d8cf936.jpg
    Stopped scarf joint:
    338695907_216716624374132_7006009626668511782_n_1280.thumb.jpg.9f91aff37db46671a5ac91790feeb707.jpg
    New half keel slid at the stem:
    Second keel length slid in from stern.
    Stem deadwood timbers, with stopped scart to keelson.
    360102229_3522009378056472_3477285283496488194_n_1280.thumb.jpg.3812f8e7c30a8999fa97015cd0413006.jpg
    Cutting the rabbet in the stem. Note step in aft face to help lock into deadwoods.
    361923835_3522009441389799_4326742644797966472_n_1280.thumb.jpg.9a8ce5dde39476877b77e5f793a45c33.jpg
    First half of keel in place; note the reduction in keel depth from the original. Scarf at 18th frame.
    338708083_1269785370412939_6866254322895819802_n_1280.jpg.168728b88a2a3325b62e18ef087ace3b.jpg
    Second section joined; scarf joint complete.
    Feeding the heavy stem deadwoods into place:
    362293867_3522009291389814_7211307161600044777_n_1280.thumb.jpg.241fe4c008247a04082e552af101b0a0.jpg
    Lifting the stem post into position Note reduction in width of the stemson.
    Stern deadwood knee attachment – mizzen mast step position shown:
    362202209_3522009401389803_4810966031548113129_n_1280.thumb.jpg.6421c7cd1a3c680447abf07609f3e746.jpg
    Stern post in place:
    Job’s a good ‘un…
    I am grateful to the 'Friends of Vigilance CIO' for permission to visit the slip, and the kind assistance of Stirlings Yard staff. There are many more pictures of the process on their facebook site here.
  10. Well its seems along time since I last posted - very busy time around Christmas, visiting relatives, and then our two children flew in to stay over. We also had an unexpected guest, a Mr Covid who tried to take the limelight, but we saw him off eventually.
    Hopefully getting back into the swing now, so here's a short update, and I wish all of you a very peaceful, happy and creative New Year!
    Timber.
    I am using timber from trees we planted in the early ‘80’s thinned and felled to make room for a new driveway to our property. This is mostly field maple, acer campestris which is super hard and stable; and a faster growing poplar (aspen) where the grain is not so important.
    Also some boughs of Holly, Ilex aquifolium; which was seasoned outside for about four years and then inside for 12 months. During seasoning it takes on a (fungal?) stain which is grey/blue, but in fact this is what I want when looking for a base colour that can be dyed to look like weathered oak, using Jacobean & Tudor oak stains and oil paint tints. For some of the parts will also be stained to match mahogany and pitch pine. I have some tulip and idigbo which may find their way into the boat.
    Selecting seasoned timber for the project – checking moisture levels and evidence of any live insect activity. The curved sections will be for frames.
    Stock is roughly dimensioned on a 45-year-old band saw, then hand planed and finally sanded to size with my d.i.y. belt sander thicknesser. I keep meaning to build a smarter version, but it’s consistently accurate to a tenth of a millimetre, can plane parallel or to a set taper, so I don’t bother.
    Planking will be 1.9 mm (75 thou) thick by about 4mm (160 thou) wide at this scale.
    image.png.39c4c59fb1ee1590b79ca6ea89ab9e50.pngimage.png.5b98b9122bcc61ace251441bc37b57d1.png
    For the stock sizes I make a spacer-blocks for the ‘thicknesser’ which holds the throat at the right size for each stock dimension and ensures consistency.
    The maple and holly are quite tough on the hand plane blade, and I sharpen regularly to a very fine edge.
    I don’t have table saws, thicknessers or suchlike, so progress is slow, but I don’t mind that.
    Field maple, poplar and holly in 5” (3.9mm) 6” 4.75mm) and  8” (6.35mm)
    Finished dimensioned stock for framing; this is 5 year seasoned holly showing the grey staining. It should weather up to represent oak well.
    I also have a piece of the original timber from Vigilance which I was kindly permitted to take from the skip at the Yard. It is the very base of a frame that has sat next to ballast and bilge water for a century, so it’s not very pretty but I intend to return a section into the boat somewhere if I can salvage a piece.
