Posts posted by DocBlake
Thanks for the link, Zoltan. Some awesome stuff at that website.
- Canute, Nirvana, zoly99sask and 1 other
4
Model Expo has a 1/24 smooth bore cannon kit, 18th century, that looks to be a 9 pounder. I don't need the kit, just the barrels (2). Who can I contact to see if they would be willing to sell me just 2 barrels? Would work great on my Triton section.
- zoly99sask and Canute
2
I decided to add the scarf joint that appears on the keel plan for the full Triton build. Was that scarf held together by bolts or treenails? In his Cheerful build, Chuck has a vertical scarf in the keel held together with treenails. I've already decided the futtocks will be bolted together with dark treenails representing the bolts.
- coxswain, David Lester, Canute and 5 others
8
- Pete38, GuntherMT, David Lester and 9 others
12
I'd replace the metal with pear, red heart or bloodwood.
- mtaylor, Canute and thibaultron
3
I needed deadeyes in an odd size because of the scale of the ship. I also wanted them black. 6mm would be 9" in scale diameter. That would work. Mike Shanks, using his CNC, cut a bunch of them out of swiss pear that are 6.5mm in diameter. The only problem is that there was no way to cut the grooves along the circumference. I did that by hand, and sanded the deadeyes smooth. Then I dyed them black. The photo shows the raw deadeyes and the finished product. they still need to be coated with tung oil. The second photo shows the remade deadeyes compared to the stock ones supplied with the kit. They are a bit bigger. Perfect!
- GuntherMT, Larry Cowden, KenW and 5 others
8
Good to know. I'm working on a 1/24 scale Triton cross section that needs 2 nine pounders. I'm not sure that I want to turn them!
- mtaylor, thibaultron and Canute
3
What size cannon does this represent. Looking at the size compared to the bulwarks, I'd guess a 9 pounder?
- Canute, thibaultron and mtaylor
3
Thanks Don and Clare! Mike is experimenting with his laser and CNC router. Our plan is to build a 1/24 scale "Hannah" with CNC cut frame parts. Interesting stuff!
- Landlubber Mike, catopower, mrshanks and 1 other
4
After a lot of thought I decided to include quarter badge windows. This is a small, simple ship so I opted out of all the elaborate carving and went with a simple 4 pane light that Mike Shanks cut out for me in boxwood. I took a cue from Dr. Clayton Feldman in his "Lexington" build and added a curved rain diverter and sill, both of which stand proud of the window. Simple molding strips form the sides of the framing. All these parts are of ebony.
- David Lester, mtaylor, rafine and 6 others
9
Great method...great results! Keep it up, Elijah.
- Elijah, EJ_L, zoly99sask and 1 other
4
Rattlesnake by David Lester - FINISHED - Mamoli - Scale 1:64
The paint looks good, David. I can't paint worth a damn...it's why I generally build with natural wood only!
