Posts posted by DocBlake
Great job on the boat, Jon!
Historically, the futtocks would have been bolted together to produce the frames. What would the correct diameter of the bolts be? May best estimate from research I've done is somewhere between 1" and 1-1/2". Any thoughts? Also, would it make sense to mark the locations of the deck clamps and gunport sills etc. on the frames prior to glueup?
- Canute, zoly99sask, Nirvana and 1 other
4
Thanks David and Scott! More to come. Next up are swiss pear deadeyes dyed black to simulate ebony. The channels will be boxwood with a molded edge. I'm also planning to add quarter badge windows of boxwood to contrast with the pear planking. Mike Shanks is instrumental in all of this. Stay tuned!
- mrshanks, mtaylor and Landlubber Mike
3
I've been busy. We are replacing our cedar deck and we spent a week in California (the Bay area) since my last post. I haven't been doing a lot of modeling at all. I did want to rename this schooner "Clio" after the Muse of History in Greek mythology. My friend Mike Shanks was able to laser etch some ebony I had on hand. I then painted the etched name using white acrylic paint. Sanding the face with a 220 grit sanding block took care of any excess paint on the name plate. I then glued the name to the transom.
- Tigersteve, Landlubber Mike, KenW and 3 others
6
Great job! I have the LSS Halifax, and I hope I can do it half the justice you have. Chuck's rope is great, isn't it?!
Nice job, David. Don't sell yourself short. You have all the skills necessary to keep the model natural and not paint . All you need is an assortment of woods. I have used yellowheart in the past for the ochre effect, but it's falling out of my favor. I plan to use boxwood for the outer bulwarks of my 1/24 Triton cross section - to substitute what would have been painted ochre. Bob Hunt's practicum for "Rattlesnake uses boxwood also. Crown timber can supply in in the dimensions you would need.
Very impressive work on the ship's boats.
Outstanding. Bob! The holly below the wales will look awesome. I did that with my "Independence " build, but the contrast on your model will be really dramatic, given the hull's cherry frames. Good choice! Do you plan on limiting the holly to just one strake, or maybe several on one side of the hull only?
Great job on the transom! Love the color choices.
- MEDDO and Blue Ensign
2
Oil based wiping varnishes tend to add "warmth" to the wood. Water based poly leaves the wood "cold" looking, especially darker wood like cherry and walnut. I use water based only with very light woods like maple and birch. It dries crystal clear, while an oil based finish typically has an amber cast to it.
Halifax by rafine - FINISHED - The Lumberyard - 1:48 - semi-scratch schooner
Very nicely done, Bob!
