Posts posted by DocBlake
Glad to see you start another project, Jon!
Is there any rule of thumb as to what vessel (size, type) would have mast bands or rope wouldings and which would not. Size is an obvious criteria. I've not seen a colonial schooner wither those features, but they would be visually appealing. Should I consider adding them to my "Indepence" masting, or are they too over the top for such a small vessel?
Magnificent job, Jon. A real inspiration!
- CaptainSteve and Jack12477
- 2
That's correct, Greg. The framing (and a lot of the other wood) is boxwood. CNC cut so no laser char to deal with. I've got her on my shelf for a future build.
- Canute and zoly99sask
- 2
I decided to make my masts and sprit out of swiss pear. They need to be 5/16" in diameter at the base, and tapered. Obviously there is no commercial source so I'll make my own. The first step is to drill a 21/64" hole in some mild steel. Then I cut out mast blanks on the table saw a hair larger that the hole. I sharpened the tip of the blanks, then chucked them into my 1/2" electric drill. Using the steel as a drawplate, I pushed the spinning wood through the hole. The resulting dowels were a bit rough, bu I have at least 1/64 to play with and they clean up easily. Once they're at 5/16", I'll taper them. Here's a photo of the blanks and the resulting unsanded dowels. I also linked to a You Tube video showing the technique.
- Larry Cowden, zoly99sask, mrshanks and 2 others
- 5
With the completion of the elm tree pumps, the deck furniture is complete. The pumps in the kit were cast metal and awful! I just received my cannons today. I bought 6 pewter cannons from the Lumberyard: Their 1/4" scale 4 pounders are exactly as long as a 3 pounder in 5/16" scale which is what I need . The carriages are supposed to be swiss pear, but they aren't terribly pink, and the wood itself isn't surfaced the best - kingd of rough. I may need to make these from scratch.
Thanks, Stoyne!
I'm looking ahead to masting and rigging. I'll need to fabricate the masts from scratch. They are 5/16" diameter at the base and this size is not generally commercially available. I don't want to use the walnut supplied in the kit because of the big pore/wide open grain. My choice is down to cherry or swiss pear. The areas of the mast doublings will be dyed black. Black spars will definitely be made of swiss pear, natural spars of birch. Because of the black doublings, I'm leaning toward swiss pear for the masts. Any opinions?
Thanks, guys. The bell came with the kit - I just redesigned and rebuilt the belfry. As to the catheads, since the deck is bowood, I'd like a little more contrast. The quarterdeck and poop deck railings are going to be rosewood, so maybe having the catheads rose wood is too much. I'm leaning toward the swiss pear.
- Ryland Craze, CharlieZardoz, KenW and 6 others
- 9
I completed two sets of bitts - one for each mast - and the ship's belfry (which also has running rigging belayed to it). I also finished the quarterdeck stairs. The plans call for a stairway on each side between the gun ports as well as boarding steps on the exterior hull above the wales. Neither Halifax, Sultana nor Chaleur had this feature, so I'm not adding the boarding stairs to this model, either! Next are the elm tree pumps, the catheads and the cannons.
- russ, Ryland Craze, GuntherMT and 6 others
- 9
Nice!
Good job fairing the hull.
- robert952, captain_hook and Sea Hoss
- 3
I prefer the 8X8 and 5X5, Charlie. The holes look good.
- mtaylor and CharlieZardoz
- 2
Thanks guys!
Given the simple transom and lack of carvings back there, I'm leaning toward no quarter badges/lights. I think either option has historical precedent.
Charlie: I haven't decided anything about a name yet!
Looking for some Syren pear wood blocks
in Traders, Dealers, Buying or Selling anything? - Discuss New Products and Ship Model Goodies here as well!!
I don't have any pear blocks, Clare, but I'm hoping your request means you plan to start work on Independence again! Don can help you out.
