Posts posted by DocBlake
Beautiful model, David!
I took a little time to work on this build today . I'm using the rigging plans for "Halifax" so there three pair of shrouds per mast fixed to the channels rather than 4 as in the kit. The 4th shroud is secured to a cleat.
I made the chainplates from 20 gauge copper wire doubled up and soldered together. After blackening, I'll drill holes for the nails that will hold the chainplates to the wales. The channels are made of boxwood, as is the chainplate cover strip. there's a decorative profile cut into the channels and the cover strip.
- KenW, Ryland Craze, David Lester and 7 others
- 10
Very sorry to hear the news.
- Canute, Omega1234, Ryland Craze and 1 other
- 4
Nice job. I like the display, also!
Great progress. She's coming along quickly!
Incredible work! That ship is immense!
Don: The rigging has added a lot to the model already. Great job! Keep it up.
Nice work on the fittings, David. The Rattler is a beautiful ship. I love her lines and especially her sharp tumblehome!
With our deck project complete, I've freed up some time to get back to the shipyard. I decided to poly the fore and aft surfaces of the frames begore gluing them to the keel, when access is much more restricted. I do have a couple of questions for previous builders of this model:
1) Is bracing between each frame necessary or advisable? What should be the layout, and is there a historical precedent for this?
2) Should I cut the mortises for the gun port framing before assembly, or after the frames have been installed?
Here's a photo of the nine frames drying after the first coat of poly. The can of Minwax gives some perspective as to how big a 1/24 scale section is!
5 minute epoxy is the best thing since sliced bread! I use it ALL the time! Unless you have a very long tedious assembly to do, it's enough time to glue most things. Don't buy the stuff in the tin tubes or syrynges: the tubes crack and leak, and the syrynges are too difficult to measure the 1:1 mix you need accurately. I pick up a set with a separate bottle for hardener and resin (4.5 oz. each!) for $10 at Jo Ann's or Hobby Lobby. Should last years.
You did the right thing with the stove,Bob. In my POF AVS at 1/32 scale the stove is barely visible...I spent a lot of time on it, which is fine, but not a lot to show for it in it's effect in the model. Simpler is better at smaller scales. Overall your work continues to be stunning. Keep it up!
Great job on the longboat! Love the detail.
Great job on the detailing, Jon!
- Jack12477 and CaptainSteve
- 2
Great job, JP! Keep it up!
HMS Bounty by thomaslambo - Artesania Latina – Scale 1:48
I'm looking forward to seeing you starting up this log again. I have this kit in my stash, and although I've got a few irons in the fire, I am tempted to start her up. I love doing interior detailing, and your build is inspiring me. Good job!
