Posts posted by S.Coleman
- hof00, GrandpaPhil, Jonny 007 and 1 other
- 4
Yeah sounds about right. I've covered over that hole in the hope i can place it further forward. Plans are so vague on this one.
Started on the deck planking. Didn't like the way it looked with the caulking so ripped it up and started again. AOTS book has the hatches on the waist deck in differnt positions. It shows the main hatch closer to the aft deck step and another hatch a little bit forward from it. I will add in joins and scarf joints later as i find it easier that way.
- GrandpaPhil and grsjax
- 2
2 hours ago, Richard44 said:
Hi Scott,
I built this kit about 35 years ago, so my memory is a little vague. But I think that if you check the height of the mizzen mast as shown on the kit plan, it is quite a bit less than the height that Marquardt argues is correct. He goes into a fair bit of detail about this.
Cheers
Richard
Thanks for checking in. I will look into the mizzen mast dimensions a bit more now I think with that info. This book should help with a lot of small details that the kit has left out.
Removing the frames from the boards was a bit tricky, laser not cut all the way through. After removal a quick sand and now a dry fit. Instructions have the bulkheads numbered but not on the actual pieces so it was a bit of a jigsaw getting the correct order.
I have the AOTS book to help along the way.
- Jonny 007, ccoyle, GrandpaPhil and 4 others
- 7
Ok first of all hello guys and gals. It's been almost three years since my last log on here. I had built the Friesland by mamoli. The build log is still here.
So I got this kit awhile ago on a buy, swap and sell page. It's an old one but the wood inside is very well preserved. No warping, The rubber bands holding the strips together has long since perished.
Decide to have a crack at it and see where we go from there.
- ccoyle, Edwardkenway, GrandpaPhil and 1 other
- 4
Hull looks superb. I like the deck planking patterns
Looking really well done, sharp, clean and neat.
Lots of detail for this kit. Really nice looking build. How did you etch the plates into the hull?
- cog, popeye the sailor, mtaylor and 2 others
- 5
Looking very clean. It's great when all goes together smoothly.
Those grates are very brittle and fiddly. I remember doing these on my Mamoli Friesland. Yours are looking good though. Nice work.
Absolute stunning build. She's massive. I do like your attention to detail.
- mtaylor, Kevin, popeye the sailor and 1 other
- 4
Good to see another mamoli build. These are good builds.
Looks great. Off to a good start. Everything looks neat.
I rekon once the first planks of the hull are on and all looks aligned it will come up very solid.
That looks good. With the bulkheads hollowed out and the keel only going up so far it looks flimsy. Take your time it shall be good.
- popeye the sailor, src and mtaylor
- 3
I do like a Mamoli build. Looks like a beautiful ship to build. Hope the bulkheads come right.
- Old Collingwood and zappto
- 2
Victory as a first wooden build will be an eye opener. Looking good.
Looking at great start. Im looking at starting this kit too.
Looking very neat and fine.
Ratlines look amazing. A real peice of work. Good job
HMB Endeavour 1768 by S.Coleman - Artesania Latina - 1:60 scale
Cheers Harry. Downloads opened no problem. I like how it even has the degrees for mast angles. This will help out a ton.
