Everything posted by shipman
Thank you druxey and wefalk for your perspectives. It's why I'm here, to learn from the 'team'. I do so enjoy these dialogues.
- 433 replies
- open boat
- small boat
Thank you, Druxey. So if the standards are fixed to both the thwart and the side of the boat.... I always understood the thwarts were removable, enabling nesting and making room for a cargo/storage load? Also weren't the thwarts 'set into' the risers, preventing the thwart moving fore and aft?
- 433 replies
- open boat
- small boat
What a delight this project is and as it's coming to a close I'm already getting withdrawal symptoms as builds of this quality are rare here. I've grown numb with the endless 'Medway Longboat' offerings, whatever their merits. Question.....the angled brackets (do they have a name?) at each end of and above thwarts: in real boats, are these made to 'wedge' the thwart in position, but can be knocked' out enabling the thwart to be removed when required? Observation......I don't recall many oared craft models which have the oarsman's foot rests included. Were these fittings a lot more common, but rarely depicted as they make a lot of practical sense? Thank you for the pleasure this continuing build has given to me and many others.
- 433 replies
- open boat
- small boat
Love the novel if not unique method turning the supports within the brass tube.
- 433 replies
- open boat
- small boat
Well done! It's easy when you know how. Big smile 😎
- 433 replies
- open boat
- small boat
Spent entire evening trying to find new photo's on the web, with no result. Is the boat still in the Venice museum? Keith is right; the drawing (at least for the grating) is fiction. That's what I was getting at. However you extemporise, I'm sure your solution will be a credit to the rest of your superb model.
- 433 replies
- open boat
- small boat
I'm usually a bit cock eyed with these things, but is it possible the original grating was in two haves? It may profit to study wefalks photo more closely.
- 433 replies
- open boat
- small boat
''one of the advantages of a pure pulling boat is that one avoids registration fees, high "oil spill" insurance costs, and the like''. NOT if you live in the UK! Everything from a paddle board upwards is regulated, requires registration, licencing, insurance...lalala...
- 433 replies
- open boat
- small boat
Whatever the dimensions; for a 1:48 boat model yours is spectangular! The craftsmanship is astonishing.....sometimes it's hard to realise how small this thing is. Often, when finding a build here, the first item I look for are the ships boats; if they aren't near your standard, then the rest is a disappointment. Are you intending to mast and rig it? Where would forums like this be without the miracle of digital photography and the internet.
- 433 replies
- open boat
- small boat
The boat in 'Neptune' is emphatically 26'. Yours is 28'. So not a copy of the boat in Venice, but one in the style of? Sorry to be so pedantic.
- 433 replies
- open boat
- small boat
It's also worth noting there are many grades of S/S, some I've encountered are so hard right through and impossible to improve the milled finish. Most nuts and bolts seem to have a hard skin microns thick, once that has been removed the softer under surface takes a lovely polish rapidly. Avoid S/S plate which has a grey rolled grain surface....it can be levelled and polished but the effort isn't worth the effort. May I suggest getting a supplier to provide the type which already has a mirror finish, but cut to the size you require. This usually comes in plate 1-2mm thick. Be careful not to scratch it as removing that is a nightmare.
Which Scale 1/200 or 1/350 Kit is the most detailed
shipman replied to Guyuti's topic in Plastic model kits
There's detail. then there's accurate detail! If money isn't a problem, both scales offer superb detail sets. As always, research, research and more research. There are plenty of finished builds on the net.....it's up to you to decide which way to go. -
I have a 1956 BSA motorcycle. 30 years ago I replaced 99% of the fasteners, laboriously hand polishing each one, using files, emery and finally using a buffing wheel. That took me an entire winter but the results were exceptional. After all the years, being exposed to oil, road dirt and British weather, a quick wipe with an oily rag reveals all the glitter. Brilliant! If I'd gone with new cadmium plated steel it would be rust and need replacing again.
LOL, back in the day, part of my job was as a proof reader. AND I'M DYSLEXIC! 🤓
- 433 replies
- open boat
- small boat
What a pleasure to vicariously share your excellent build, 'Druxey'. Is there a reason why your version is 2' longer than the original?
- 433 replies
- open boat
- small boat
Canute, I'd just been viewing Kostas Kaseas latest build. If you take the time to look at his previous work on that site it will be very clear he's a cut above the rest. Probably the best.
- 1,090 replies
- showcase models
- vendetta
Swann Morton chisel blades.
shipman replied to harlequin's topic in Modeling tools and Workshop Equipment
Swann-Morton 'SUPATOOL' and a wide range of suitable blades. I've recommended these on the forum before. A proper handle and a stronger more stable scalpel style blade. Look them up! -
Bruma, your model is a delight and an education in so many ways. Kirill's recent comments have prompted a question lurking in the back of my mind..... No ship under sail would be seen without someone at the helm and someone else on watch.... and out of the water, stuck on a couple of pedestals?
- 399 replies
- cutty sark
- revell
How to connect yards to masts??
shipman replied to ObviousNewbie's topic in Masting, rigging and sails
I'm sorry if I have vexed some members on the copyright issue and sincere apologies to 'ON' for unintentionally using his post in this regard. My last word on the matter here is this googled response to my question applied to the USA..... ''Codified in Section 107 of the Copyright Act, fair use allows persons other than the copyright owner to make certain limited uses of copyrighted material without the copyright owner's permission (17 U.S.C. § 107). Fair use is an affirmative defense to copyright infringement. ... Nature of the copyrighted work''. -
Again......'fair use' allows the use of selected images to illustrate a point. In this 'educational' context, copy right issues are mute. Period. Guidelines. Fair use explicitly allows use of copyrighted materials for educational purposes such as criticism, comment, news reporting, teaching, scholarship, and research. ... Nature of the work: For copying paragraphs from a copyrighted source, fair use easily applies -
Some may think warships of this era are bland and colourless, generally being, well, 'battleship grey'. I admire the finish on your model, which is fine and consistent. One of my grandfathers was a cook in the merchant navy throughout WW2, living what must have been a charmed life, crossing the Atlantic umpteen times. Strange, he never talked about it. My other grandfather was not so lucky. His ship, the aircraft carrier 'Courageous' was sunk by a U-boat in the first week of the 'Phony War' and went down with over 500 of his shipmates; leaving a wife and five kids traumatised for the rest of their lives. He still has the dubious record for being the oldest Royal Marine (RNR) to be 'killed in action'.
